Data sheet | Item number: 280-502/281-588
Component terminal block; double-deck; with end plate; with varistor; for
DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/280-502_281-588
Color:
Item description
Short description:
This component terminal block with surge suppression device, end plate and direct connection to the DIN-35 rail is equipped with a varistor.
Features:
Protect your system against overvoltage
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.07.2020 Page 1/5
Slim, space-saving design
Control operational costs by preventing expensive, unplanned downtime
High operational reliability and system uptime
Data
Electrical data
Nominal operating voltage
AC 230 V
Continuous operating voltage (max.)
AC 275 V
Rated continuous current
20 A
Nominal discharge current (8/20 µs), line
1 kA
Discharge current (max.)
4.5 kA
Protection level (8/20 μs)
≤ AC 710 V
Response time (line/line)
Capacitance
≤ 320 pF
Connection data
Connection points (number)
2
Connection technology
CAGE CLAMP®
Solid conductor
0,08 … 2,5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Geometrical Data
Width
10 mm / 0.394 inch
Height from upper-edge of DIN-rail
39,5 mm / 1.555 inch
Depth
64 mm / 2.52 inch
Mechanical data
Design
with end plate; with direct connection to DIN-rail
Mounting type
DIN-35 rail
Material Data
Color
gray
Weight
13.1 g
Commercial
dataPlease also observe the further product documentation!
Subject to changes.
Hansastr. 27
32423 Minden
13.07.2020 Page 2/5
Commercial data
Product Group
1 (Rail Mounted Terminal Blocks)
Packaging type
BOX
Country of origin
DE
GTIN
4045454368401
Customs tariff number
85369010000
Counterpart
Compatible products
Jumper
Item no.: 280-482
Jumper; 2-way; insulated; gray
www.wago.com/280-482
Item no.: 280-483
Jumper; 3-way; insulated; gray
www.wago.com/280-483
Item no.: 280-484
Jumper; 4-way; insulated; gray
www.wago.com/280-484
Item no.: 280-485
Jumper; 5-way; insulated; gray
www.wago.com/280-485
Item no.: 280-490
Jumper; 10-way; insulated; gray
www.wago.com/280-490
Item no.: 280-492
www.wago.com/280-492
Insulation stop
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/280-471
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
www.wago.com/280-472
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
tools
Marking accessories
Hansastr. 27
32423 Minden
13.07.2020 Page 3/5
Marking accessories
Item no.: 2009-145
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-145/000-002
yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007
Item no.: 2009-145/000-012
orange
/000-012
Item no.: 2009-145/000-023
green
/000-023
Item no.: 2009-145/000-024
violet
/000-024
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Hansastr. 27
32423 Minden
13.07.2020 Page 4/5
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Downloads
Documentation
Bid Text
280-502/281-588
Feb 11, 2015
doc
26.6 kB
Download
Feb 19, 2019
xml
3.5 kB
Download
URL
Download
EPLAN Data Portal 280-502/281-588
URL
Download
WSCAD Universe 280-502/281-588
URL
Download
ZUKEN Portal 280-502/281-588
URL
Download
doc - Datei
280-502/281-588
GAEB X81 - Datei
CAD/CAE-Data
CAD data
2D/3D Models 280-502/281-588
CAE data
Installation Notes
Hansastr. 27
32423 Minden
13.07.2020 Page 5/5
很抱歉,暂时无法提供与“280-502/281-588”相匹配的价格&库存,您可以联系我们找货
