280-835/056-000
280-835/056-000
    WAGO(万可电子)
280-835/056-000 数据手册
Network Rail Approved WAGO Terminal Replacement for the 2BA Stud Terminal Block PI 04-11-12 Product Information WAGO Part No. 280-675 TS35 DIN rail-mounted terminal block with disconnect link facility 800V/8kV/3, 24A 0.08 - 2.5mm² Terminal block width 5mm Insulation stripping length: 8-9mm H L Length Height Height with disconnect jumper Width 93mm 28mm 44mm 5mm Red Insulation stop (part number 280-498) is available as an equivalent to the red dome nut and can be fitted into the jumper location once the disconnect link has been removed. Installation and removal of this part can be seen on the Operating Information page in Part 2. The 280-498 is based on the existing white disconnect link. However this new part only has one leg which is used for holding the stop in place. Its purpose is solely to blank off the centre jumper locations. The 231-126/011-000 is a test probe that can be used in the screwdriver entry point. This device is inserted in the same way as a screwdriver, by angling its entry into the terminal block. It is pushed down the back of the clamp making contact with the busbar and clamp simultaneously. PADS No. Description DIN Rail mounted terminal block with disconnect link facility. 086/042121 Part No 280-675 grey 086/042124 086/042125 Part No 280-325 - grey, 5mm thick Part No 280-333 - orange, 5mm thick End and intermediate plate Disconnect Jumper / Link with tab and without 006/042123 086/042134 Part No 280-495 - white (left, with tab) Part No 280-492 - grey (right, without tab) Insulation stop - for disconnect jumper point 086/042126 Part No 280-498 - red Screwless end stop for TS35 DIN rail 086/042126 Part No 249-117 - 10mm wide, grey Test Probe 086/042127 Part No 231-126/011-000 - grey WSB marker card - for marking of terminal blocks 086/042131 Part No 209-666 - white card vertically marked with 1-50 (x2). Other combinations available, details on request. DIN Rail Part No 210-146 - Aluminium DIN rail TS 35/15 Operating tools 209-130 - Insulated 210-657 - Short, blade 3x0.5mm 210-658 - Short angled, blade 3x0.5mm Product Information WAGO Part No. 280-833 TS35 DIN rail-mounted through terminal block 4-conductor 800V/8kV/3, 20A 0.08 - 2.5mm² Terminal block width 5mm Insulation stripping length: 8-9mm H L Length Height Width 75mm 28mm 5mm Please follow the operating information part 1 for connecting wires to the 280-833 terminal block. Adjacent jumpers can be inserted into the terminal block by simply pushing it into the jumper slot. The jumper will click into position and be flush to the top of the terminal. PADS No. Description DIN Rail mounted terminal block 0.5 - 2.5mm² (Non-disconnectable) 086/042129 Part No 280-833 grey 086/042132 Part No 280-835/056-000 - orange, 5mm thick End and intermediate plate Screwless end stop for TS35 DIN rail 086/042126 Part No 249-117 - 10mm wide, grey Adjacent Jumper Part No 280-402 - grey Group marker carriers - can be fitted to end-stops Part No 209-112 - group marker carrier (top) Part No 209-114 - protective cover transparent (middle) Part No 209-113 - marker card for self-marking, 100 markers per sheet (bottom) WSB marker card - for marking of terminal blocks 086/042131 Part No 209-666 - white card vertically marked with 1-50 (x2). Other combinations available, details on request. Operating Information Part 1: Connecting wires using a CAGE CLAMP® Step 1: Strip the cable 8-9mm using the stripping tool (206-124). Introduce the screwdriver, initially at a slightly curved angle, into the square operating slot and push down until it will go no further. You cannot damage the spring as positive ‘stops’ are built into the design of both the spring and terminal housing. Step 2: The screwdriver blade will then remain in place, automatically holding the spring open. Introduce the prepared cable, via the rounded entry hole. Step 3: The screwdriver can then be withdrawn, releasing the clamping spring onto the conductor to provide a secure connection with exactly the right level of tension. Part 2: Insertion of the disconnect jumper / link & insulation stop Step 1: Open the two central clamping springs using our 3.5 x 0.5mm flat blade operating tool, part number 210-130. Step 2: Insert the disconnect jumper / link or insulation stop, part numbers 280-495 or 280-498 respectively, fully into the open clamping springs. The contact legs of the link are notched and it should be possible to feel these click into place once it is in the correct position. Step 3: Remove the operating tool to close the clamps, leaving the jumper / link firmly held in position. Bunch strap tester for testing of WAGO CAGE CLAMP® terminals Bunch Strap Tester for 20 and 24 terminal units The WAGO bunch strap tester is specifically designed to be used with the WAGO CAGE CLAMP® terminals and can be used to Megger test up to 20 or 24 terminals at a time, The tester is constructed from silicon insulated wire, each of the arms has a replaceable connector attached that can be placed into the square hole of the terminal, thus allowing testing without disturbing the cabling. The Megger connection is via a 4mm stackable banana plug. The unit is supplied complete as shown above with either 20 or 24 terminal leads, each unit has unique serial number and date of manufacture. 231-126/011-000 Test Probe 51002153 Test Plug Serial number and date of manufacture 20 way strap tester WAGO part number 51002152 24 way strap tester WAGO part number 51002165 Other number of ways available upon request Production facilities Throughout, WAGO can offer a full service for customers including, technical information and support, AutoCAD drawings of specific custom terminal rail assemblies, quotes and lead times to full production of the rail assemblies and as well as inspection and packaging ready for delivery. Below examples of rails assemblies by WAGO. Above, 280-675 terminal assemblies in a typical LOC application. Above, 280-675 terminal assembly within a disconnection box used for signal gantries. Notes WAGO Limited Triton Park Swift Valley Industrial Estate Rugby, Warwickshire CV21 1SG Phone 01788 568008 Fax 01788 568050 ukmarketing@wago.com www.wago.com
280-835/056-000 价格&库存
很抱歉,暂时无法提供与“280-835/056-000”相匹配的价格&库存,您可以联系我们找货
