282-601
    WAGO(万可电子)
282-601 数据手册
Printview: 2-conductor through terminal block - Item No.: 282-601 . 2-conductor through terminal block Item No.: 282-601 . 2-conductor through terminal block . Marking . Business data Supplier WAGO Item no. 282-601 GTIN / EAN 4044918306836 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 2 Total number of potentials 1 Color gray Ratings according to 1 IEC/EN 60947-7-1 Pollution degree (1) 3 Rated voltage EN (1) [V] 800 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 41 [A] Connection technology (1) CAGE CLAMP® Solid sizes 1 0.2 … 6 mm² / 24 … 10 AWG WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 2-conductor through terminal block - Item No.: 282-601 Technical data Fine-stranded wires 1 0.2 … 6 mm² / 24 … 10 AWG Strip length 1 12 … 13 mm / 0.47 … 0.51 in Type of wiring Front-entry wiring Design horizontal Marking level Side marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.207 [MJ] Weight [g] 13.26 [g] Width 8 mm / 0.315 in Height from upper-edge of DIN-rail [mm] 31.5 [mm] Height from upper-edge of DIN-rail 31.5 mm / 1.24 in Length 62 mm / 2.441 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 2-conductor through terminal block - Item No.: 282-601 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 2-conductor through terminal block - Item No.: 282-601 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
282-601 价格&库存
很抱歉,暂时无法提供与“282-601”相匹配的价格&库存,您可以联系我们找货
    • 4+27.462324+3.41880
    • 20+26.8381720+3.34110
    • 50+26.4815250+3.29670
    • 125+26.12487125+3.25230
    • 300+25.41156300+3.16350
    库存:25
