2-CONDUCTOR THROUGH TERMINAL
BLOCK LATERAL MARKING WITH
INTEGRATED END PLATE
285-635
PDF Datasheet
© 1992 - 2011 CADENAS GmbH
285-635
PDF Datasheet
ITEM-NO. (ITEM-NO.)
285-635
Cross section1 (Cross section / mm²)
6 - 35
Cross section2 (Cross section / AWG)
8 - 02
Strip length (Strip length / mm)
23 - 23
Measured voltage (Measured voltage / V)
1000
Measured shock voltage (Measured shock voltage / kV)
8
Pollution degree (Pollution degree)
3
Current intensity (Current intensity / A)
125
Height (Height / mm)
53
Width (Width / mm)
16
Depth (Depth / mm)
100
No. of connection Points (No. of connection Points)
2
No. of potentials (No. of potentials)
1
COLOR (COLOR)
grau
WEIGHT (WEIGHT / g)
88
很抱歉,暂时无法提供与“285-635”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+211.714881+27.44228
