Data sheet | Item number: 288-368
Relay module; Nominal input voltage: 24 VDC; 1 break contact; Limiting
continuous current: 5 A; Module width: 13 mm; 2,50 mm²; gray
www.wago.com/288-368
Color:
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/6
Data
Technical Data
Control circuit
Nominal input voltage UN
DC 24 V
Input voltage range
±10 %
Nominal input current at UN
20 mA
Load circuit:
Number of break contacts/switch off contacts
1
Contact material (relay)
AgNi 0.15
Limiting continuous current
5 A
Max. make current (resistive)
(AC) 16 A / 4 s
Max. switching voltage
AC 250 V
Max. switching power (resistive)
AC 1250 VA
Pull-in time (typ.)
4 ms
Drop-out time (typ.)
6 ms
Bounce time (typ)
2 ms
Electrical life (N.O.; resistive load; 23 °C)
200 x 103 switching operations
Mechanical life
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/6
Mechanical life
30 x 106 switching operations
Safety and protection:
Overvoltage category
II
Pollution degree
2
Dielectric strength, control/load circuit (AC, 1 min)
4 kVrms
Insulation type (control/load circuit)
Reinforced insulation (safe isolation)
Insulation type (adjacent devices)
Connection data
Connection technology
CAGE CLAMP®
WAGO terminal
WAGO 236 Series
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Geometrical Data
Width
13 mm / 0.512 inch
Height from upper-edge of DIN-35 rail
47 mm / 1.85 inch
Depth
85 mm / 3.346 inch
Mechanical data
Type of mounting
DIN-35 rail
Material Data
Color
gray
Fire load
0.31 MJ
Weight
30.9 g
Environmental Requirements
Surrounding air (operating) temperature at UN
-25 … 40 °C
Surrounding air (storage) temperature
-25 … 70 °C
Processing temperature
-25 … +50 °C
Max. temperature rise of connection cable
30 K
Relative humidity
5 … 75 % (non condensing)
Max. operating altitude
Subject to changes.
Hansastr. 27
32423 Minden
2000 m
29.12.2019 Page 3/6
2000 m
Standards and specifications
Standards/specifications
EN 61810-2-201
Commercial data
Product Group
6 (Interface Electronics)
Packaging type
BOX
Country of origin
DE
GTIN
4045454319946
Customs Tariff No.
85364900990
Compatible products
Marking accessories
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent
www.wago.com/709-177
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Item no.: 709-196
Marking strips; for laser printer; translucent
www.wago.com/709-196
Item no.: 709-198
Marking strips; white
www.wago.com/709-198
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
tools
Downloads
Documentation
Bid Text
288-368
Feb 20, 2019
docx
16.1 kB
Download
Feb 19, 2019
xml
3.9 kB
Download
docx - Datei
288-368
X81 - Datei
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/6
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
pdf
265.8 kB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 288-368
CAE data
EPLAN Data Portal 288-368
Download
WSCAD Universe 288-368
Download
Installation Notes
Inserting a conductor
Connection of conductor – Operating tool
actuation parallel to conductor entry.
actuation perpendicular to conductor entry.
Assembly
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/6
Assembly of a module on the carrier rail
Removing a module from the DIN-rail.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/6
很抱歉,暂时无法提供与“288-368”相匹配的价格&库存,您可以联系我们找货
