733-105
733-105
    WAGO(万可电子)
    P=2.5mm
    接线端子 1x5P 间距:2.5mm 排数:1 每排Pin数:5
733-105 数据手册
Data sheet  |  Item number: 733-105 1-conductor female plug; 100% protected against mismating; 0.5 mm²; Pin spacing 2.5 mm; 5-pole; 0,50 mm²; light gray www.wago.com/733-105 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 L = (pole no. x pin spacing) + 2.1 mm Item description Universal connection for all conductor types Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation Strain relief plates for factory and in-the-field assembly 100% protected against mismating Coding via coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 100 V Rated impulse voltage (III / 3) 2.5 kV Rated voltage (III / 2) 160 V Rated impulse voltage (III / 2) 2.5 kV Rated voltage (II / 2) 320 V Rated impulse voltage (II / 2) 2.5 kV Rated current Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 6  A Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Rated current 6  A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 150 V Rated current UL (Use Group B) 4  A Approvals per CSA Rated voltage CSA (Use Group B) 150 V Rated current CSA (Use Group B) 4  A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 0.34 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 0.34 mm² Strip length 5 … 6 mm / 0.2 … 0.24 inch No. of poles 5 Total number of connection points 5 Total number of potentials 5 Number of connection types 1 Number of levels 1 Conductor entry direction to mating direction 0  ° Geometrical Data Pin spacing 2.5 mm / 0.098 inch Width 14.6 mm / 0.574 inch Height 11.8 mm / 0.465 inch Depth 17.1 mm / 0.673 inch Plug connection Contact type (pluggable connector) Female connector/socket Connector connection type for conductors Mismating protection Yes Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Material Data Color light gray Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load 0.041 MJ Weight 2.2 g Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin DE GTIN 4044918294034 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 61984 2169534.01 CCA DEKRA Certification B.V. IEC 61984 NL-31141 CSA DEKRA Certification B.V. C22.2 1465035 Ship Approvals Certificate Logo Approval Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Additional Approval Text name Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Logo Approval Additional Approval Text name ABS American Bureau of Shipping - 19HG1869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z LR Lloyds Register IEC 61984 96/20035 (E5) UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 UR Underwriters Laboratories Inc. UL 1059 20190122E45172 Compatible products Strain relief plate Item no.: 734-128 Strain relief plate; 12.5 mm wide; light gray www.wago.com/734-128 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 ferrule Item no.: 216-151 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-151 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Marking accessories Item no.: 210-331/250-202 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /250-202 Item no.: 210-331/250-204 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /250-204 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/250-206 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /250-206 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/250-207 Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /250-207 Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Item no.: 210-251 Operating tool; for MCS MICRO & MINI with CAGE CLAMP® connection; yellow www.wago.com/210-251 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 233-331 Operating tool; insulated; yellow www.wago.com/233-331 Item no.: 233-332 Operating tool; made of insulating material www.wago.com/233-332 check tools Item no.: 233-335 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/233-335 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Item no.: 233-335 Operating tool www.wago.com/233-335 Item no.: 733-130 Operating tool; loose; natural www.wago.com/733-130 Item no.: 733-191 Operating tool; loose; yellow www.wago.com/733-191 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 733-105 CAE data EPLAN Data Portal 733-105 Download Installation Notes Protected Against Mismating Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Male headers and female connectors are 100 % protected against mismating. Only mating halves with the same pole number can be connected. Inserting a conductor Inserting a conductor via (2.5 x 0.4) mm screwdriver. Operation is performed perpendicular to conductor entry. Inserting a conductor via screwdriver (233335) – CAGE CLAMP® actuation parallel to conductor entry. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 8/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Inserting a conductor via 733-191 Operating Lever. Inserting a conductor via 210-251 Operating Tool. Coding Coding a female connector – removing coding finger(s). Assembly Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 9/10 Data sheet  |  Item number: 733-105 www.wago.com/733-105 Strain relief plates for factory or in-the-field assembly. Testing Testing via 1 mm Ø test pin ( 735-500) – touch contact. Product family MCS MICRO Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 10/10
733-105 价格&库存
很抱歉,暂时无法提供与“733-105”相匹配的价格&库存,您可以联系我们找货
    • 10+79.4027110+10.29211
    • 50+56.7994150+7.36229
    • 100+55.01079100+7.13045
    库存:160
    733-105
    • 1+20.81160
    • 10+17.52840
    • 30+15.57360
    • 100+13.59720
    库存:186
    733-105
    • 13+61.7746013+8.00717
    • 25+57.7844425+7.48997
    • 50+40.1290350+5.20149
    • 100+37.69193100+4.88560
    • 250+35.31215250+4.57713
    • 500+33.92600500+4.39746
    • 1000+31.008001000+4.01923
    库存:35
