734-104/037-000
734-104/037-000
    WAGO(万可电子)
    P=3.5mm
    接线端子 间距:3.50mm 1x4P
734-104/037-000 数据手册
WAGO product LOCATOR 4.1 Data sheet 734-104/037-000 FEMALE PLUG WITH LOCKING LEVER PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODIG FINGERS Technical data Package size 50 pieces. Pin spacing from Pin spacing from pole count Cross section from [mm2] Cross section to [mm2] Cross section from [AWG] Cross section to [AWG] Voltage UL Voltage CSA Current UL Current CSA Measured voltage EN Measured shock voltage Pollution degree Current intensity EN Weight Color No. of connection Points No. of potentials Height Height Width Width Copyright WAGO. Technical changes reserved. 14.09.2012 10:40:18 3.5 mm 0.138 in 4 0.08 mm2 1.5 mm2 28 AWG 14 AWG 250 V 300 V 10 A 10 A 250 V 2.5 kV 2 10 A 3.655 g light grey 4 4 13.4 mm 0.528 in 25.8 mm 1.016 in Page 1 WAGO product LOCATOR 4.1 Data sheet 734-104/037-000 FEMALE PLUG WITH LOCKING LEVER PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODIG FINGERS Depth Depth Strip length from Strip length to Strip length 18.6 mm 0.732 in 7 mm 7 mm 0.28 in xxx-xxx/032-000 Strain relief plate 6 mm Copyright WAGO. Technical changes reserved. 14.09.2012 10:40:18 Page 2 WAGO product LOCATOR 4.1 Data sheet 734-104/037-000 Approval CCA CCA CSA KEMA UL UL FEMALE PLUG WITH LOCKING LEVER PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODIG FINGERS Voltage Current Approval number 250 250 300 250 250 300 10 10 10 10 10 10 123898-02 NL5641 154112-1465035 2077592.02 E45171 E45172 Copyright WAGO. Technical changes reserved. 14.09.2012 10:40:20 Notes Page 3 WAGO product LOCATOR 4.1 Data sheet 734-104/037-000 FEMALE PLUG WITH LOCKING LEVER PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODIG FINGERS Accessories OPERATING STICKER FOR MULTI CONNECTION SYSTEM PUSH BUTTON FOR FEMALE CONNECTORS AND MALE CONNECTORS SCREWDRIVER Type 1, bar (2,5 x 0,4) mm SCREWDRIVER WITH PARTIALLY INSULATED SHAFT Type 1, bar (2,5 x 0,4) mm SNAP-ON TYPE RELIEF HOUSING SUITABLE FOR PIN SPACING 3.5 MM / 0.138 IN STRAIN RELIEF PLATE FOR SERIES 734 Copyright WAGO. Technical changes reserved. 14.09.2012 10:40:46 Item number 210-199 734-230 210-119 210-619 734-604 734-127 Page 4 WAGO product LOCATOR 4.1 Data sheet 734-104/037-000 FEMALE PLUG WITH LOCKING LEVER PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODIG FINGERS Copyright WAGO. Technical changes reserved. 14.09.2012 10:40:47 Page 5 WAGO product LOCATOR 4.1 Data sheet 734-104/037-000 FEMALE PLUG WITH LOCKING LEVER PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODIG FINGERS L = No.of poles x pin spacing Copyright WAGO. Technical changes reserved. 14.09.2012 10:41:15 Page 6
734-104/037-000 价格&库存
很抱歉,暂时无法提供与“734-104/037-000”相匹配的价格&库存,您可以联系我们找货
  • 1+4073.51816
库存:200
734-104/037-000
  • 1+84.861231+11.02989
