736-304
736-304
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 脚间距:5.08mm 每排Pin数:8 排数:2
736-304 数据手册
Printview: Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in Item No.: 736-304 . Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in Item No.: 736-304 . Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in . Marking . Business data Supplier WAGO Item no. 736-304 GTIN / EAN 4044918914048 Content 1 Order amount 84 Customer item number . Notes Terminal strips with screwdriver-actuated CAGE CLAMP®High-density, double-deck design for space-efficient wiring of multiple conductors in confined areasCustom inkjet marking for all termination levelsTerminal strips with commoning strips for distribution of potential Technical data Miscellaneous No. of poles 4 Pin Spacing 5.08 mm / 0.2 in % Total number of connection points 8 Total number of potentials 8 Number of levels 2 Color orange Ratings according to 1 IEC/EN 60664-1 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in Item No.: 736-304 Technical data Overvoltage category EN 1 III Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 21 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 21 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 250 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 21 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 2.5 mm² / … Strip length 1 5 … 6 mm / 0.2 … 0.24 in Conductor entry angle to the PCB 1 [°] 45 [°] Solder pin length [mm] 4 [mm] Solder pin width A [mm] 0.7 [mm] Solder pin width B [mm] 0.7 [mm] Tolerance of drilled hole [mm] 1.3(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in Item No.: 736-304 Technical data Fire load [MJ] 0.148 [MJ] Weight [g] 9.41 [g] Width 21.32 mm / 0.839 in Height 30.5 mm / 1.201 in Height from the surface 26.5 mm / 1.043 in Length 21 mm / 0.827 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in Item No.: 736-304 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in Item No.: 736-304 . WAGO Kontakttechnik GmbH & Co. KG 5 Printview: Double-deck PCB terminal strip; 2 solder pins, in line; 4x2-pole; pin spacing 5.08 mm / 0.2 in Item No.: 736-304 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 6
736-304 价格&库存
很抱歉,暂时无法提供与“736-304”相匹配的价格&库存,您可以联系我们找货
