769-645
769-645
    WAGO(万可电子)
    接线端子
769-645 数据手册
Data sheet | Item number: 769-645 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 15pole; gray www.wago.com/769-645 i Picture differs from the item. Color: Data Electrical data Ratings per IEC/EN Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 500 V Rated surge voltage (III/2) 4 kV Rated current 32 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Pole No. 15 Total number of potentials 15 Number of levels 1 Physical data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 1/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Physical data Pin spacing 5 mm / 0.197 inch Width 78.6 mm / 3.094 inch Height from the surface 22.2 mm / 0.874 inch Depth 18.3 mm / 0.72 inch Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection No Mating direction to the PCB 90 ° PCB contact PCB Contact THT Material data Color gray Insulation material Polyamide (PA66) Fire load 0.314 MJ Weight 14.9 g Commercial data Product Group 18 (X-COM-System) Packaging type BOX Country of origin PL GTIN 4044918270809 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7626 CCA EN 61984 2190419.02 DEKRA Certification B.V. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 2/13 Data sheet | Item number: 769-645 www.wago.com/769-645 CCA EN 61984 2190419.02 CCA DEKRA Certification B.V. IEC 61984 NL-47799 /A1 CSA DEKRA Certification B.V. C22.2 No. 158 1101144 KEMA/KEUR DEKRA Certification B.V. EN 60947 2190419.01 DEKRA Certification B.V. Ship Approvals Logo Approval Additional Approval Text Certificate name DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 UL-Approvals Logo Certificate name Approval Additional Approval Text UR Underwriters Laboratories Inc. UL 1977 20151210E45171 UR Underwriters Laboratories Inc. UL 1059 20190731E45172 Compatible products Marking accessories Item no.: 210-831 Marking strips; on reel; 2.3 mm wide; plain; Self-adhesive; white www.wago.com/210-831 Item no.: 210-832 Marking strips; on reel; 3 mm wide; plain; Self-adhesive; white www.wago.com/210-832 Item no.: 210-833 Subject to changes. Please also observe the further product documentation! www.wago.com/210-833 WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 3/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Item no.: 210-833 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white www.wago.com/210-833 Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 Item no.: 769-101 1-conductor female plug; 4 mm²; 1-pole; 4,00 mm²; gray www.wago.com/769-101 Item no.: 769-102 1-conductor female plug; 4 mm²; 2-pole; 4,00 mm²; gray www.wago.com/769-102 Item no.: 769-102/000-036 1-conductor female plug; 4 mm²; 2-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-102 /000-036 Item no.: 769-102/000-037 1-conductor female plug; 4 mm²; 2-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-102 /000-037 Item no.: 769-103 1-conductor female plug; 4 mm²; 3-pole; 4,00 mm²; gray www.wago.com/769-103 Item no.: 769-103/000-036 1-conductor female plug; 4 mm²; 3-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-103 /000-036 Item no.: 769-103/000-037 1-conductor female plug; 4 mm²; 3-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-103 /000-037 Item no.: 769-103/000-038 1-conductor female plug; 4 mm²; 3-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-103 /000-038 Item no.: 769-103/000-039 1-conductor female plug; 4 mm²; 3-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-103 /000-039 Item no.: 769-104 1-conductor female plug; 4 mm²; 4-pole; 4,00 mm²; gray www.wago.com/769-104 Item no.: 769-104/000-036 1-conductor female plug; 4 mm²; 4-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-104 /000-036 Item no.: 769-104/000-037 1-conductor female plug; 4 mm²; 4-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-104 /000-037 Item no.: 769-104/000-038 1-conductor female plug; 4 mm²; 4-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-104 /000-038 Female plug Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 4/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Item no.: 769-104/000-039 1-conductor female plug; 4 mm²; 4-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-104 /000-039 Item no.: 769-105 1-conductor female plug; 4 mm²; 5-pole; 4,00 mm²; gray www.wago.com/769-105 Item no.: 769-105/000-036 1-conductor female plug; 4 mm²; 5-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-105 /000-036 Item no.: 769-105/000-037 1-conductor female plug; 4 mm²; 5-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-105 /000-037 Item no.: 769-105/000-038 1-conductor female plug; 4 mm²; 5-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-105 /000-038 Item no.: 769-105/000-039 1-conductor female plug; 4 mm²; 5-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-105 /000-039 Item no.: 769-106 1-conductor female plug; 4 mm²; 6-pole; 4,00 mm²; gray www.wago.com/769-106 Item no.: 769-106/000-006 1-conductor female plug; 4 mm²; 6-pole; 4,00 mm²; blue www.wago.com/769-106 /000-006 Item no.: 769-106/000-036 1-conductor female plug; 4 mm²; 6-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-106 /000-036 Item no.: 769-106/000-037 1-conductor female plug; 4 mm²; 6-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-106 /000-037 Item no.: 769-106/000-038 1-conductor female plug; 4 mm²; 6-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-106 /000-038 Item no.: 769-106/000-039 1-conductor female plug; 4 mm²; 6-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-106 /000-039 Item no.: 769-107 1-conductor female plug; 4 mm²; 7-pole; 4,00 mm²; gray www.wago.com/769-107 Item no.: 769-107/000-036 1-conductor female plug; 4 mm²; 7-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-107 /000-036 Item no.: 769-107/000-037 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 5/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Item no.: 769-107/000-037 1-conductor female plug; 4 mm²; 7-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-107 /000-037 Item no.: 769-107/000-038 1-conductor female plug; 4 mm²; 7-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-107 /000-038 Item no.: 769-107/000-039 1-conductor female plug; 4 mm²; 7-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-107 /000-039 Item no.: 769-108 1-conductor female plug; 4 mm²; 8-pole; 4,00 mm²; gray www.wago.com/769-108 Item no.: 769-108/000-036 1-conductor female plug; 4 mm²; 8-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-108 /000-036 Item no.: 769-108/000-037 1-conductor female plug; 4 mm²; 8-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-108 /000-037 Item no.: 769-108/000-038 1-conductor female plug; 4 mm²; 8-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-108 /000-038 Item no.: 769-108/000-039 1-conductor female plug; 4 mm²; 8-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-108 /000-039 Item no.: 769-109 1-conductor female plug; 4 mm²; 9-pole; 4,00 mm²; gray www.wago.com/769-109 Item no.: 769-109/000-036 1-conductor female plug; 4 mm²; 9-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-109 /000-036 Item no.: 769-109/000-037 1-conductor female plug; 4 mm²; 9-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-109 /000-037 Item no.: 769-109/000-038 1-conductor female plug; 4 mm²; 9-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-109 /000-038 Item no.: 769-109/000-039 1-conductor female plug; 4 mm²; 9-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-109 /000-039 Item no.: 769-110 1-conductor female plug; 4 mm²; 10-pole; 4,00 mm²; gray www.wago.com/769-110 Item no.: 769-110/000-036 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/769-110 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 6/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Item no.: 769-110/000-036 1-conductor female plug; 4 mm²; 10-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-110 /000-036 Item no.: 769-110/000-037 1-conductor female plug; 4 mm²; 10-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-110 /000-037 Item no.: 769-110/000-038 1-conductor female plug; 4 mm²; 10-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-110 /000-038 Item no.: 769-110/000-039 1-conductor female plug; 4 mm²; 10-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-110 /000-039 Item no.: 769-111 1-conductor female plug; 4 mm²; 11-pole; 4,00 mm²; gray www.wago.com/769-111 Item no.: 769-111/000-036 1-conductor female plug; 4 mm²; 11-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-111 /000-036 Item no.: 769-111/000-037 1-conductor female plug; 4 mm²; 11-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-111 /000-037 Item no.: 769-111/000-038 1-conductor female plug; 4 mm²; 11-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-111 /000-038 Item no.: 769-111/000-039 1-conductor female plug; 4 mm²; 11-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-111 /000-039 Item no.: 769-112 1-conductor female plug; 4 mm²; 12-pole; 4,00 mm²; gray www.wago.com/769-112 Item no.: 769-112/000-036 1-conductor female plug; 4 mm²; 12-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-112 /000-036 Item no.: 769-112/000-037 1-conductor female plug; 4 mm²; 12-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-112 /000-037 Item no.: 769-112/000-038 1-conductor female plug; 4 mm²; 12-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-112 /000-038 Item no.: 769-112/000-039 1-conductor female plug; 4 mm²; 12-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-112 /000-039 Item no.: 769-113 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 7/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Item no.: 769-113 1-conductor female plug; 4 mm²; 13-pole; 4,00 mm²; gray www.wago.com/769-113 Item no.: 769-113/000-036 1-conductor female plug; 4 mm²; 13-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-113 /000-036 Item no.: 769-113/000-037 1-conductor female plug; 4 mm²; 13-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-113 /000-037 Item no.: 769-113/000-038 1-conductor female plug; 4 mm²; 13-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-113 /000-038 Item no.: 769-113/000-039 1-conductor female plug; 4 mm²; 13-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-113 /000-039 Item no.: 769-114 1-conductor female plug; 4 mm²; 14-pole; 4,00 mm²; gray www.wago.com/769-114 Item no.: 769-114/000-036 1-conductor female plug; 4 mm²; 14-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-114 /000-036 Item no.: 769-114/000-037 1-conductor female plug; 4 mm²; 14-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-114 /000-037 Item no.: 769-114/000-038 1-conductor female plug; 4 mm²; 14-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-114 /000-038 Item no.: 769-114/000-039 1-conductor female plug; 4 mm²; 14-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-114 /000-039 Item no.: 769-115 1-conductor female plug; 4 mm²; 15-pole; 4,00 mm²; gray www.wago.com/769-115 Item no.: 769-115/000-036 1-conductor female plug; 4 mm²; 15-pole; 4,00 mm²; gray, green-yellow www.wago.com/769-115 /000-036 Item no.: 769-115/000-037 1-conductor female plug; 4 mm²; 15-pole; 4,00 mm²; green-yellow, gray www.wago.com/769-115 /000-037 Item no.: 769-115/000-038 1-conductor female plug; 4 mm²; 15-pole; 4,00 mm²; gray, blue, green-yellow www.wago.com/769-115 /000-038 Item no.: 769-115/000-039 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/769-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 8/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Item no.: 769-115/000-039 1-conductor female plug; 4 mm²; 15-pole; 4,00 mm²; green-yellow, blue, gray www.wago.com/769-115 /000-039 Item no.: 769-115/021-000 1-conductor female plug; Locking lever; 4 mm²; 15-pole; 4,00 mm²; gray www.wago.com/769-115 /021-000 Item no.: 769-121 2-conductor female connector; 4 mm²; 1-pole; 4,00 mm²; gray www.wago.com/769-121 Item no.: 769-122 2-conductor female connector; 4 mm²; 2-pole; 4,00 mm²; gray www.wago.com/769-122 Item no.: 769-123 2-conductor female connector; 4 mm²; 3-pole; 4,00 mm²; gray www.wago.com/769-123 Item no.: 769-124 2-conductor female connector; 4 mm²; 4-pole; 4,00 mm²; gray www.wago.com/769-124 Item no.: 769-125 2-conductor female connector; 4 mm²; 5-pole; 4,00 mm²; gray www.wago.com/769-125 Item no.: 769-126 2-conductor female connector; 4 mm²; 6-pole; 4,00 mm²; gray www.wago.com/769-126 Item no.: 769-127 2-conductor female connector; 4 mm²; 7-pole; 4,00 mm²; gray www.wago.com/769-127 Item no.: 769-128 2-conductor female connector; 4 mm²; 8-pole; 4,00 mm²; gray www.wago.com/769-128 Item no.: 769-129 2-conductor female connector; 4 mm²; 9-pole; 4,00 mm²; gray www.wago.com/769-129 Item no.: 769-130 2-conductor female connector; 4 mm²; 10-pole; 4,00 mm²; gray www.wago.com/769-130 Item no.: 769-131 2-conductor female connector; 4 mm²; 11-pole; 4,00 mm²; gray www.wago.com/769-131 Item no.: 769-132 2-conductor female connector; 4 mm²; 12-pole; 4,00 mm²; gray www.wago.com/769-132 Item no.: 769-133 2-conductor female connector; 4 mm²; 13-pole; 4,00 mm²; gray www.wago.com/769-133 Item no.: 769-134 2-conductor female connector; 4 mm²; 14-pole; 4,00 mm²; gray www.wago.com/769-134 Item no.: 769-135 2-conductor female connector; 4 mm²; 15-pole; 4,00 mm²; gray www.wago.com/769-135 Coding Item no.: 769-435 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/769-435 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 9/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Item no.: 769-435 Coding pin; for coding of female plugs; for carrier terminal blocks / male connectors; orange www.wago.com/769-435 Downloads Documentation Bid Text 769-645 2019 Feb 19 xml 3.0 kB Download 2017 Oct 4 doc 25.1 kB Download 2019 Apr 3 pdf 2.2 MB Download URL Download URL Download X81 - Datei 769-645 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 769-645 PCB Design Symbol and Footprint 769-645 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 10/13 Data sheet | Item number: 769-645 www.wago.com/769-645 PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 769-645 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 769-645 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 15-pole; gray Installation Notes Installation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 11/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Cutout Male headers with solder pins Application Male headers with straight solder pins and 1conductor female plugs (picture shows a relay module) Male headers with solder pins for printed circuit boards Pluggable PCB connection Connection to a relay module inside the switchgear cabinet Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 12/13 Data sheet | Item number: 769-645 www.wago.com/769-645 Male headers with solder pins: Integrating PCB components into the system wiring. Product family X-COM Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.03.2021    Page 13/13
769-645 价格&库存
很抱歉,暂时无法提供与“769-645”相匹配的价格&库存,您可以联系我们找货
