8000-0100/1000-0363
8000-0100/1000-0363
    WAGO(万可电子)
    WAGO - 8000-0100/1000-0363 - METAL ENCLOSURE, 1PORT
8000-0100/1000-0363 数据手册
BULKHEAD INTERFACE PORT Through Panel Power and Programming Ports BIP SERIES - BULKHEAD INTERFACE PORT For Convenient Power Supply and Programming Safely access high voltage panels with the Bulkhead Interface Ports. The BIP Series provide a secure gateway to your control cabinet, enabling you to plug-in to power and program without putting you or your operation at risk. Ten different models feature a variety of connection options such as D-Sub, USB, RJ45, duplex, simplex, and GFI’s to support all your power and communication needs. Push-in CAGE CLAMP® connections provide simple, reliable and toolfree wiring on the duplex models for power connections. A metal on metal spring roller latch ensures a water tight seal. All bulkhead interface ports are encased in an all metal housing designed to withstand tough conditions and meet the safety requirements of cULus. Bulkhead WAGO information Interface displayed Port purpose on label and information clearly identified on the cover Push-in CAGE CLAMP® CAGE CLAMP® connections connections on backsidefor of product power wiring Metal on metal rolling spring clamp ensures water tight seal Approval: Rugged all metal housing Description Item No. Image Dimensional Drawing Dimensions Duplex outlet with one RJ45 and one USB interface connection with 3 A circuit breaker 8000-0100/ 1000-0357 5.0 x 3.6 in Duplex GFI outlet with one RJ45 interface connection 8000-0100/ 1000-0362 5.0 x 3.6 in Duplex outlet with one RJ45 interface connection with 3 A circuit breaker 8000-0100/ 1000-0359 5.0 x 3.6 in Duplex GFI outlet with one RJ45 interface connection with 3 A circuit breaker 8000-0100/ 1000-0361 5.0 x 3.6 in Simplex outlet with one RJ45 interface connection 8000-0100/ 1000-0354 4.5 x 1.8 in Simplex outlet with 9 pin D-Sub interface connection 8000-0100/ 1000-0363 4.5 x 1.8 in Simplex outlet with one RJ45 and two USB interface connections 8000-0100/ 1000-0355 4.5 x 1.8 in Simplex outlet with one RJ45 and one USB interface connection 8000-0100/ 1000-0356 4.5 x 1.8 in One RJ45 interface connection 8000-0100/ 1000-0358 3.2 x 1.8 in One 9 pin D-Sub interface connection 8000-0100/ 1000-0360 3.2 x 1.8 in WAGO SA DE CV Carretera estatal 431 Km. 2+200. Lote 99 6 Parque Industrial Tecnologico Innovacion Queretaro El Marques, Qro. 76246 Lada sin Costo: 01 800 288 WAGO (288-9246) Telefono: 422 / 221-5946 info.mx@wago.com www.wago.mx 5/2018 - Printed in the United States 0888-0832/0000-0374 WAGO Canada Inc. 4145 North Service Rd., Unit 224 Burlington, ON L7L 6A3 Telephone: 888 / WAGO 221 (924-6221) info.ca@wago.com www.wago.ca 60373585 WAGO Corporation N120 W19129 Freistadt Road Germantown, Wisconsin 53022 Telephone: 800 / DIN-Rail (346-7245) Fax: 262 / 255-3232 info.us@wago.com www.wago.us
8000-0100/1000-0363 价格&库存
很抱歉,暂时无法提供与“8000-0100/1000-0363”相匹配的价格&库存,您可以联系我们找货
