8002-0100/0000-0264
8002-0100/0000-0264
    WAGO(万可电子)
    WAGO - 8002-0100/0000-0264 - INTERFACE CONNECTOR, DSUB PLUG-TB
8002-0100/0000-0264 数据手册
Interface Module, 9-position D-Sub Male, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0264 Designation Pack. Unit 8002-0100/0000-0264 Interface Module, 9-pos D-Sub Male, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted 9-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 2 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 33 x 20 x 52 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/12/2015 Data Sheet 1 of 1 Interface Module, 9-position D-Sub Female, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0265 Designation Pack. Unit 8002-0100/0000-0265 Interface Module, 9-pos D-Sub Female, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted 9-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 2 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 33 x 19.2 x 51.7 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/12/2015 Data Sheet 1 of 1 Interface Module, 15-position HD D-Sub Male, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0471 Designation Pack. Unit 8002-0100/0000-0471 Interface Module, HD 15-pos D-Sub Male, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted high density 15-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 1.5 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 33 x 20 x 68 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1 Interface Module, 15-position HD D-Sub Female, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0472 Designation Pack. Unit 8002-0100/0000-0472 Interface Module, HD 15-pos D-Sub Female, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted high density 15-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 1.5 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 33 x 20 x 68 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1 Interface Module, 15-position D-Sub Male, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0477 Designation Pack. Unit 8002-0100/0000-0477 Interface Module, 15-pos D-Sub Male, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted 15-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 1.5 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 42 x 20 x 52 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1 Interface Module, 15-position D-Sub Female, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0478 Designation Pack. Unit 8002-0100/0000-0478 Interface Module, 15-pos D-Sub Female, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted 15-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 2 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 42 x 20 x 52 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1 Interface Module, 25-position D-Sub Male, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0479 Designation Pack. Unit 8002-0100/0000-0479 Interface Module, 25-pos D-Sub Male, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted 15-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 2 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 56 x 20 x 57 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1 Interface Module, 25-position D-Sub Female, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0480 Designation Pack. Unit 8002-0100/0000-0480 Interface Module, 25-pos D-Sub Female, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted 15-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 2 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 56 x 20 x 57 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1 Interface Module, 26-position HD D-Sub Male, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0481 Designation Pack. Unit 8002-0100/0000-0481 Interface Module, HD 26-pos D-Sub Male, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted high density 26-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 1.5 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 42 x 20 x 76 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1 Interface Module, 26-position HD D-Sub Female, Right-Angle, Multi-Mount Kit Description 8002-0100/0000-0482 Designation Pack. Unit 8002-0100/0000-0482 Interface Module, HD 26-pos D-Sub Male, Right-Angle, Multi-Mount Kit 1 Features Technical Data  This module is designed to interface directly with a fixed panelmounted high density 26-position D-Sub, or with a cable, when DIN rail mounting is selected. Operating voltage 30V AC/DC Nominal current 1.5 Amps A multi-mount hardware kit is provided, including captive #4-40 screws, #4-40 jackscrews, and snap-in 35mm DIN rail feet that can also be trimmed & used to provide a stable, non-marring wiring platform, for free-hanging applications. Connector contact Au flash Output wire connections Cage Clamp S 0.2 – 1.5mm² / AWG 24 – 16  RoHS compliant. Stripped wire length 8.5-9.5mm / 0.32-0.36”  Push-button WAGO CAGE CLAMP® S terminals.  Dimensions (mm) W x H x L (height from upper-edge of DIN rail) 42 x 20 x 76 For signal-level wiring, up to 30V.  Open-back, compact, low-profile construction.  Great for Din rail applications with limited enclosure depth. Minimum temperature Operating temperature Maximum Humidity -35C (without impact) -20°C to 50°C 95%  WAGO contact in the United States and Canada: N120 W19129 Freistadt Road P.O. Box 1015 Germantown, WI 53022 U . S . A . info.us@wago.com Phone: (800) 346-7245 Fax : (262) 255-3232 Rev. 10/19/2015 Data Sheet 1 of 1
8002-0100/0000-0264 价格&库存
很抱歉,暂时无法提供与“8002-0100/0000-0264”相匹配的价格&库存,您可以联系我们找货
