804-104
804-104
    WAGO(万可电子)
    插件,P=5mm
    接线端子 间距:5.00mm 每排针脚数:4 排数:单排
804-104 数据手册
Supplementary Catalogue 4 to Full Line Catalog W4 Volume 1 and Volume 2 Rail-Mounted Terminal Block Systems PCB Terminal Blocks and Connectors Contents Volume 1 ? double potential terminal blocks with CAGE CLAMP®S connection 1.5 mm2/AWG 22 – 14 2.5 mm2/AWG 22 – 12 Series 2001 Series 2002 02 02 ? 3- and 4-conductor terminal blocks with CAGE CLAMP®S connection Series 2002 2.5 mm2/AWG 22 – 12 03 ? connectors with CAGE CLAMP®S connection 1.5 mm2 – 4 mm2/AWG 14 – 10 Series 20xx 04 – 05 ? double and triple deck terminal blocks with CAGE CLAMP®S connection Series 2002 2.5 mm2/AWG 22 – 12 06 – 07 ? multilevel installation term. blocks w. CAGE CLAMP®S connection 4 mm2/AWG 22 – 12 Series 2003 10 Series 2005 11 6 mm2/AWG 20 – 10 ? N-disconnect terminal blocks and power distribution disconnect terminal blocks with CAGE CLAMP®S connection Series 20xx 12 2.5 mm2 – 25 mm2/AWG 22 – 4 ? disconnect terminal blocks Series 2002 16 – 18 ? diode terminal blocks and double deck terminal blocks and triple deck terminal blocks Series 2002 19 – 21 Series 2002 22 – 25 ? accessoires ? group marker carriers Series 2009 Marking of ? rail-mounted terminal blocks Series 2009 26 – 27 27 Rail-mounted high current terminal blocks with POWER CAGE CLAMP® connection 35 mm2/AWG 8 – 2 50 mm2/AWG 8 – 2/0 Collective carrier for jumpers (suitable for longitudinal disconnect and transverse switch terminal blocks) 28 Series 285 Series 285 30 – 31 32 Series 282 33 X-COM® -SYSTEM 2-cond. /1-pin receptacle terminal blocks Series 769 0.08 mm2 – 4 mm2/AWG 28 – 12 1-cond. /1-cond. disconnect receptacle terminal blocks Series 769 0.08 mm2 – 4 mm2/AWG 28 – 12 36 X-COM® -SYSTEM 2-conductor/ 2-pin double deck receptacle terminal Series 870 37 X-COM® -SYSTEM Blue components Series 769 38 – 39 X-COM® -SYSTEM Female plugs for self-assembly Series 769 40 – 41 34 – 35 Compact connector for flexible conductors 2 x 0.08 mm2 – 2.5 mm2/AWG 28 – 12 and 5 x 0.08 mm2 – 2.5 mm2/AWG 28 – 12 Push-wire connectors for junction boxes 4 x 0.75 mm2 – 2.5 mm2/AWG 18 – 12 and 3 x 2.5 mm2 – 6 mm2/AWG 14 – 10 Series 222 42 Series 773 43 Shield (screen) clamps, Carrier with grounding foot, Busbar carriers Series 791 Series 790 Series 790 44 44 45 Shield termination Series 709 45 Wire and cable marking Series 211 46 – 49 Marker carriers for WCB combi marking system Series 2009 50 1 ? Double Potential Terminal Blocks 1.5 (2.5) mm2 /AWG 16 2.5 (4) mm2/AWG 12 Series 2001 Series 2002 0.25 –1.5 (2.5) mm2 ➊ AWG 22 – 14 800 V/8 kV/3 IN 18 A (24 A) Terminal block width 4.2 mm / 0.165 in L 9 – 11 mm / 0.39 in 0.25 – 2.5 (4) mm2 ➋ AWG 22 – 12 800 V/8 kV/3 IN 24 A (32 A) Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in ➊ can be connected: 0.25 mm2 – 2.52 mm2 “s + f-st”; 2 2 “s + f-st”; ➋ can be connected: 0.25 mm2 – 4 mm 2 2 can be pushed in directly: 0.75 mm – 4 mm “s” and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm /0.472 in” Item No. Pack.-unit pcs Double potential terminal block, 2001-1441 grey Item No. Double potential terminal block, grey 2002-1441 100 Attention! This double potential terminal block cannot be commoned with push-in type jumper bars! Accessoires mm / can be pushed in directly: 0.5 mm – 2.5 mm “s” and 0.75 mm2 – 1.5 mm2 “insulated ferrule, 12 mm /0.472 in” mm / VOLUME 1 1 appropriate marking system Pack.-unit pcs 100 Attention! This double potential terminal block cannot be commoned with push-in type jumper bars! WMB/Marker strips (see Full Line Catalog W4 Volume 1, Section 14) End and intermediate plate, 0.8 mm /0.331 in thick orange 2002-1492 100 (4 x 25) grey 2002-1491 100 (4 x 25) End and intermediate plate, 0.8 mm /0.331 in thick orange 2002-1492 100 (4 x 25) grey 2002-1491 100 (4 x 25) Insulation stop , 5 pcs/strip Insulation stop , 5 pcs/strip 200 strips light grey 2001-171 0.25-0.5 mm2 200 strips light grey 2001-171 0.25-0.5 mm2 dark grey2002-172 0.75-1 mm2 Protective warning marker, for 5 terminal block yellow 2002-115 100 (4 x 25) Double potential terminal blocks are space savers. Two independent through terminal blocks are placed in one insulated housing on one level. The width of the housing is only 4.2 mm/0.165 in. Compared to standard through terminal blocks, the width is only 2.1 mm/0.083 in. Input and output contacts of one circuit are placed on the same side of the terminal block. Both circuits can be individually marked according to input and output. Double potential terminal blocks are space savers. Two independent through terminal blocks are placed in one insulated housing on one level. The width of the housing is only 5.2 mm/0.205 in. Compared to standard through terminal blocks, the width is only 2.6 mm/0.103 in. Input and output contacts of one circuit are placed on the same side of the terminal block. Both circuits can be individually marked according to input and output. 2 ? 3- and 4-Conductor Rail-Mounted Terminal Blocks 2 2.5 (4) mm /AWG 12, Series 2002 * U2 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 800 V/8 kV/3 600 V, 20 A U 600 V, 20 A 2 IN 24 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in * U2 2 “s + f-st”; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 mm / mm / can be pushed in directly: 0.75 mm – 4 mm “s” and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm /0.472 in” Item Pack.-unit No. pcs 3-conductor through terminal blocks grey 2002-6301 100 blue 2002-6304 100 orange 2002-6302 100 more colors are being prepared 3-conductor ground (earth) terminal block 2002-6307 100 green-yellow approvals in preparation Suitable for Ex i applications 4 Item Pack.-unit No. pcs 4-conductor through terminal blocks 2002-6401 100 grey blue 2002-6404 100 orange 2002-6402 100 more colors are being prepared 4-conductor ground (earth) terminal block 2002-6407 100 green-yellow approvals in preparation Suitable for Ex i applications Attention! These terminal blocks cannot be commoned! 4 appropriate marker system WMB/Marker strips/WMB Inline (see Full Line Catalog W4 Vol. 1, Sec. 14) End and intermediate plate, 0.8 mm /0.031 in thick End and intermediate plate, 0.8 mm /0.031 in thick orange 2002-6392 100 (4 x 25) orange 2002-6392 100 (4 x 25) grey 2002-6391 100 (4 x 25) grey 2002-6391 100 (4 x 25) Accessories Insulation stop, 5 pcs/strip 200 strips Insulation stop, 5 pcs/strip light grey 2002-171 0.25-0.5 mm2 dark grey 2002-172 0.75-1 mm2 Push-in type jumper bars, light grey, insulated, IN 25 A 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) 200 strips light grey 2002-171 0.25-0.5 mm2 dark grey 2002-172 0.75-1 mm2 Push-in type jumper bars, light grey, insulated, IN 25 A Protective warning marker, for 5 terminal blocks yellow 2002-115 100 (4 x 25) Protective warning marker, for 5 terminal blocks yellow 2002-115 100 (4 x 25) Modular ? connector, for jumper contact slot 1 pole 2002-511 100 (4 x 25) Spacer, modular 3- and 4-conductor terminal blocks The new ? rail-mounted terminal blocks have a conductor entry angle of 35 degrees allowing for a very small bend radius and an extremely short wiring distance to the cable duct. For applications in switchgear and control cabinets using the LSC wiring system from Lütze, for example, the new terminal blocks offer a space and cost saving solution. This way, conductors can be placed very close to the terminal blocks and their height can be kept relatively low. Product characteristics 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) 2002-549 100 (4 x 25) Test plug adapter, for test plug 4 mm/0.157 in Ø 2009-174 100 (4 x 25) Testing tap, for max. 2.5 mm2 2009-182 100 (4 x 25) * Further approvals with corresponding ratings can be found at www.wago.com 3 1 VOLUME 1 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 800 V/8 kV/3 600 V, 20 A U 600 V, 20 A 2 IN 24 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in ! ® • CAGE CLAMP S connection for all types of conductors, with the additional benefit that stripped solid wires and fine-stranded ferruled wires can be simply pushed in • Vibration-proof, fast, maintenance-free connection • 3-conductor through and ground (earth) conductor terminal blocks equipped with dual jumper slot • 4-conductor terminal blocks allow for the multiplication of potentials without using any jumpers and any additional terminal blocks • 3- and 4-conductor terminal blocks have the same dimensions VOLUME 1 1 ? Modular Connectors Series 2001/2002/2004 0.25 – 1.5 (2.5) mm2 ➊ AWG 22 – 14 500 V/6 kV/3 300 V, 15 A U IN 18 A 300 V, 15 A 2 Terminal block width 4.2 mm / 0.165 in L 9 – 11 mm / 0.39 in * U2 0.25 – 2.5 (4) mm2 ➋ AWG 22 – 12 500 V/6 kV/3 300 V, 20 A U IN 24 A 300 V, 20 A 2 Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in AWG 20 – 10 0.5 – 4 (6) mm2 ➌ 500 V/6 kV/3 300 V, 30 A U IN 32 A 300 V, 30 A 2 Terminal block width 6.2 mm / 0.244 in L 11 – 13 mm / 0.47 in * U2 * U2 Item Pack.-unit No. pcs Modular TOPJOB®S connectors with CAGE CLAMP ®S connection, modular, grey, 1 pole 2001-511 100 (4 x 25) Item Pack.-unit No. pcs Modular TOPJOB®S connectors with CAGE CLAMP ®S connection, modular, grey, 1 pole 2002-511 100 (4 x 25) Item Pack.-unit No. pcs Modular TOPJOB®S connectors with CAGE CLAMP ®S connection, modular, grey, 1 pole 2004-511 100 (4 x 25) Spacer, for bridging over commoned terminal blocks, for example, modular, grey 2001-549 100 (4 x 25) ➊ can be connected: 0.25 mm2 – 2.5 mm2 “s + f-st“; can be pushed in directly: 0.5 mm2 – 2.5 mm2 “s“ and 0.75 mm2 – 1.5 mm2 “insulated ferrule, 12 mm /0.472 in“ Spacer, for bridging over commoned terminal blocks, for example, modular, grey 2002-549 100 (4 x 25) ➋ can be connected: 0.25 mm2 – 4 mm2 “s + f-st“; can be pushed in directly: 0.75 mm2 – 4 mm2 “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrules, 12 mm /0.472 in“ Spacer, for bridging over commoned terminal blocks, for example, modular, grey 2004-549 100 (4 x 25) ➌ can be connected: 0.5 mm2 – 6 mm2 “s + f-st“; can be pushed in directly: 1 mm2 – 6 mm2 “s“ and 0.75 mm2 – 4 mm2 “insulated ferrule, 12 mm /0.472 in“ Item-specific accessories Item-specific accessories Item-specific accessories End plate, 1.5 mm/0.059 in thick grey 2002-541 100 (4 x 25) End plate, 1.5 mm/0.059 in thick grey 2002-541 100 (4 x 25) End plate, 1.5 mm/0.059 in thick grey 2002-541 100 (4 x 25) WMB Multi marking card, 10 strips with 10 markers each, white with black printing, 4 – 4.2 mm/0.157 - 0.165 in wide 793-4 . . . 5 cards 794-4 . . . 5 cards see Full Line Catalog W4 Volume 1, Section 14 WMB Multi marking card, 10 strips with 10 markers each, white with black printing, 5 – 5.2 mm/0.197 - 0.205 in wide 793-5 . . . 5 cards 794-5 . . . 5 cards see Full Line Catalog W4 Volume 1, Section 14 WMB Multi marking card, 10 strips with 10 markers each, white with black printing, 5 – 5.2 mm/0.197 - 0.205 in wide 793-5 . . . 5 cards 794-5 . . . 5 cards see Full Line Catalog W4 Volume 1, Section 14 Snapping together of connectors and spacers to assemble a multi-pole connector Wire connection: Screwdriver actuation for connection of all conductor types, i.e. stripped stranded conductors, or push-in connection of solid or ferruled stranded conductors. Snapping on a strain relief plate Accessories for TOPJOB®S connectors Test plug, with cable 500 mm /1’7.7’’ 2.3 mm/0.091 in Ø yellow 210-137 Test plug, with cable 500 mm /1’7.7’’ 2 mm/0.079 in Ø red 210-136 appropriate marker system WMB/Marker strips (see Full Line Catalog W4 Volume 1, Section 14) Strain relief plate, grey snappable onto connector strips 50 (5 x 10) 50 (5 x 10) 734-327 734-328 734-329 734-326 6 mm /0.236 in wide 12.5 mm /0.492 in wide 25 mm /0.984 in wide 35 mm /1.378 in wide * Further approvals with corresponding ratings can be found at www.wago.com 4 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) Marker strips, withe, plain, on roll 11 mm /0.039 in wide 50 m 2009-110 1 Marker strips, withe, plain, on roll 11 mm /0.039 in wide 300 m 2009-130 1 ? Connector Strips Series 2001/2002/2004 1 0.25 – 1.5 (2.5) mm2 ➊ AWG 22 – 14 500 V/6 kV/3 300 V, 15 A IN 18 A 300 V, 15 A Terminal block width 4.2 mm / 0.165 in L 9 – 11 mm / 0.39 in 0.25 – 2.5 (4) mm2 ➋ AWG 22 – 12 500 V/6 kV/3 300 V, 20 A IN 24 A 300 V, 20 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in AWG 20 – 10 0.5 – 4 (6) mm2 ➌ 500 V/6 kV/3 300 V, 30 A IN 32 A 300 V, 30 A Terminal block width 6.2 mm / 0.244 in L 11 – 13 mm / 0.47 in Item Pack.-unit No. pcs Modular TOPJOB®S connector strips with CAGE CLAMP ®S connection, modular, grey, 2-pole 2001-552 3-pole 2001-553 4-pole 2001-554 5-pole 2001-555 6-pole 2001-556 7-pole 2001-557 8-pole 2001-558 9-pole 2001-559 10-pole 2001-560 ➊ can be connected: 0.25 mm2 – 2.5 mm2 “s + f-st“; can be pushed in directly: 0.5 mm2 – 2.5 mm2 “s“ and 0.75 mm2 – 1.5 mm2 “insulated ferrule, 12 mm /0.472 in“ Item Pack.-unit No. pcs Modular TOPJOB®S connector strips with CAGE CLAMP ®S connection, modular, grey, 2-pole 2002-552 3-pole 2002-553 4-pole 2002-554 5-pole 2002-555 6-pole 2002-556 7-pole 2002-557 8-pole 2002-558 9-pole 2002-559 10-pole 2002-560 ➋ can be connected: 0.25 mm2 – 4 mm2 “s + f-st“; can be pushed in directly: 0.75 mm2 – 4 mm2 “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrules, 12 mm /0.472 in“ Item Pack.-unit No. pcs Modular TOPJOB®S connector strips with CAGE CLAMP ®S connection, modular, grey, 2-pole 2004-552 3-pole 2004-553 4-pole 2004-554 5-pole 2004-555 VOLUME 1 ! ➌ can be connected: 0.5 mm2 – 6 mm2 “s + f-st“; can be pushed in directly: 1 mm2 – 6 mm2 “s“ and 0.75 mm2 – 4 mm2 “insulated ferrule, 12 mm /0.472 in“ Item-specific accessories Item-specific accessories Item-specific accessories WMB Multi marking card, 10 strips with 10 markers each, white with black printing, 4 – 4.2 mm/0.157 - 0.165 in wide 793-4 . . . 5 cards 794-4 . . . 5 cards see Full Line Catalog W4 Volume 1, Section 14 WMB Multi marking card, 10 strips with 10 markers each, white with black printing, 5 – 5.2 mm/0.197 - 0.205 in wide 793-5 . . . 5 cards 794-5 . . . 5 cards see Full Line Catalog W4 Volume 1, Section 14 Miniature WSB Quick marking card, 10 strips with 10 markers each, white with black printing, 5 mm /0.197 in wide 248- . . . 5 cards 249- . . . 5 cards see Full Line Catalog W4 volume 1, section 14 WMB Multi marking card, 10 strips with 10 markers each, white with black printing, 5 – 5.2 mm/0.197 - 0.205 in wide 793-5 . . . 5 cards 794-5 . . . 5 cards see Full Line Catalog W4 Volume 1, Section 14 WMB Inline, pitch 5 mm/0.197 in, strechable 5 mm – 5.2 mm/0.197 in – 0.205 in, on roll, 1,500 markers withe 2009-115 1 The modular connectors provide an additional connection option for conductors of the same cross section range as the terminal blocks being used. Accessories for TOPJOB®S connectors Test plug, with cable 500 mm /1’7.7’’ 2.3 mm/0.091 in Ø yellow 210-137 Test plug, with cable 500 mm /1’7.7’’ 2 mm/0.079 in Ø red 210-136 The connector has a test socket for 2 mm/0.079 in or 2.3 mm/0.091 in test plugs. appropriate marker system WMB/Marker strips (see Full Line Catalog W4 Volume 1, Section 14) Strain relief plate, grey snappable onto connector strips 50 (5 x 10) 50 (5 x 10) 734-327 734-328 734-329 734-326 6 mm /0.236 in wide 12.5 mm /0.492 in wide 25 mm /0.984 in wide 35 mm /1.378 in wide 5 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) Marker strips, withe, plain, on roll 11 mm /0.039 in wide 50 m 2009-110 1 Marker strips, withe, plain, on roll 11 mm /0.039 in wide 300 m 2009-130 1 ? Double Deck Terminal Blocks 2.5 (4) mm2 /AWG 12 Series 2002 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 500 V/6 kV/3 600 V, 20 A U 600 V, 20 A 2 IN 24 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 4-Zulassungen 2 in Vorbereitung *U 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 500 V/6 kV/3 600 V, 20 A U 600 V, 20 A 2 IN 24 A Terminal block width 5.2 / 0.205 in L 10 – 12 mm / 0.43 in 4-Zulassungen 2 in Vorbereitung *U 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm/0.472 in“ Item Item Pack.-unit Item Item Pack.-unit No. No. pcs No. No. pcs Double deck terminal blocks, for DIN 35 rail Double deck terminal blocks, for DIN 35 rail 4-conductor through terminal block, internal commoning, Through-/through terminal blocks, housing color grey, conductor entry position colored in violet housing color grey Marking carrier with without Marking carrier with without L 2002-2238 2002-2208 50 L /L 2002-2231 2002-2201 50 4-conductor through terminal block, N/L 2002-2232 2002-2202 50 internal commoning, housing color blue, L/N 2002-2233 2002-2203 50 conductor entry position colored in violet Housing color blue N 2002-2239 ➋ 2002-2209 ➋ 50 N/N 2002-2234 ➋ 2002-2204 ➋ 50 applications are being prepared applications are being prepared ➋ Suitable for Ex i applications ➋ Suitable for Ex i applications 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm can be pushed in directly: 0.75 mm2 – 4 mm2 “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm/0.472 in“ 4 4 VOLUME 1 1 Item Item Pack.-unit No. No. pcs Double deck terminal blocks, for DIN 35 rail Ground (earth) conductor/through terminal block, Housing color grey Marking carrier with PE/N 2002-2247 PE/L 2002-2257 without 2002-2217 2002-2227 50 50 4 applications are being prepared Accessories Item Item Pack.-unit No. No. pcs Double deck terminal blocks, for DIN 35 rail 4-conductor ground (earth) terminal block, internal commoning Housing color green-yellow Marking carrier with without PE 2002-2237 2002-2207 Item No. Pack.-unit pcs 50 4 applications are being prepared appropriate marking system WMB/marker strips/WMB Inline (see Full Line Catalog W4 Volume 1, Section 14) End and intermediate plate, 0.8 mm/0.032 in thick orange 2002-2292 100 (4 x 25) grey 2002-2291 100 (4 x 25) Two-way marking adapter, pivotable 2002-121 Push-in type jumper bars, light grey, insulated, IN 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) Push-in type jumper bars, light grey, insulated, IN 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) * Further approvals with corresponding ratings can be found at www.wago.com 6 50 (4 x 25) Protective warning marker, for 5 terminal blocks yellow 2002-115 100 (4 x 25) Marker strips, white, plain, for central marking, 11 mm/0.433 in wide, on roll 50 m 2009-110 1 300 m 2009-130 1 Insulation stop, see page 17 ? Catalog 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 500 V/6 kV/3 600 V, 20 A U 600 V, 20 A 2 IN 24 A Terminal block width 5.2 / 0.205 in L 10 – 12 mm / 0.43 in 4-Zulassungen 2 in Vorbereitung *U ! 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 500 V/6 kV/3 600 V, 20 A U 600 V, 20 A 2 IN 24 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 4-Zulassungen 2 in Vorbereitung *U 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 500 V/6 kV/3 600 V, 20 A U 600 V, 20 A 2 IN 24 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 4-Zulassungen 2 in Vorbereitung *U 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm/0.472 in“ Item Item Pack.-unit No. No. pcs Triple deck terminal blocks, for DIN 35 rail Through-/through-/through terminal blocks, housing color grey Marking carrier with without L /L /L 2002-3231 2002-3201 50 L /L /N 2002-3233 2002-3203 50 Housing color blue N/N/N 2002-3234➋ 2002-3204➋ 50 4 applications are being prepared Item Item Pack.-unit No. No. pcs Triple deck terminal block, for DIN 35 rail 6-conductor through terminal block, internal commoning, housing color grey, conductor entry position colored in violet Marking carrier with without L 2002-3238 2002-3208 50 6-conductor through terminal block, internal commoning, housing color blue, conductor entry position colored in violet N 2002-3239➋ 2002-3209➋ 50 applications are being prepared ➋ Suitable for Ex i applications 4 ➋ Suitable for Ex i applications 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 Item Item Pack.-unit No. No. pcs Triple deck terminal blocks, for DIN 35 rail Ground (earth)/through/through terminal blocks, housing color grey Marking carrier with PE/N/L 2002-3247 PE/L/L 2002-3257 without 2002-3217 2002-3227 50 50 4 applications are being prepared Accessories Item Item Pack.-unit No. No. pcs Triple deck terminal block, for DIN 35 rail Shield (screen)/through/through terminal blocks, housing color grey Marking carrier with Schirm/N/L 2002-3248 Schirm/L/L 2002-3258 without 2002-3218 2002-3228 50 50 4 applications are being prepared appropriate marking system can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm/0.472 in“ Item Item Pack.-unit No. No. pcs Triple deck terminal block, for DIN 35 rail 6-conductor ground (earth) terminal block, internal commoning housing color green-yellow Marking carrier with without PE 2002-3237 2002-3207 50 4 applications are being prepared WMB/marker strips/WMB Inline (see Full Line Catalog W4 Volume 1, Section 14)) End and intermediate plate, 0.8 mm/0.032 in thick orange 2002-3292 100 (4 x 25) grey 2002-3291 100 (4 x 25) Two-way marking adapter, pivotable 2002-131 Push-in type jumper bars, light grey, insulated, IN 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) Push-in type jumper bars, light grey, insulated, IN 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) 7 50 (2 x 25) Protective warning marker, for 5 terminal blocks yellow 2002-115 100 (4 x 25) Marker strips, white, plain, for central marking, 11 mm/0.433 in wide, on roll 50 m 2009-110 1 300 m 2009-130 1 Insulation stop, see page 17 ? Catalog 1 VOLUME 1 ? Triple Deck Terminal Blocks 2.5 (4) mm2 /AWG 12 Series 2002 VOLUME 1 Push-in type jumper bars with breakable contact lugs offer the same benefits to the ? installation terminal blocks as to the rail-mounted terminal blocks (e.g. individual jumper configuration on site, skipping of potentials, etc.). Very compact dimensions provide maximum wiring space in standard distribution boxes. The 2003 Series multilevel installation terminal blocks are the smallest terminal blocks with direct insertion wire connection on the market providing the full functionality of a 4 mm2/AWG 12 terminal block. The busbar carrier with end stop Screwless N-disconnect slide link for automatic and safe connection onto the function, which is only 7.5 mm / 0.295 in wide can replace end N-busbar by simply sliding the link. stop. The detachable separator plate on the carrier can be used both for separating the different potentials of N-busbars that are directly next to each other or as a touch-proof end plate for an N-busbar. The compact busbar carrier, which is placed every 200 mm /7.87 in, is used to additionally support the busbar on a long assembly. Perforations make it possible to fit the carrier to all ? installation terminal blocks using a single part. Each connection point has an individual marker receptacle for WMB markers. Additionally, the upper marker receptacle is suitable for marker strips that can be marked manually using a marker pen or automatically by a thermal transfer printer. 8 Commoning is done using the new staggered jumper system in one single ? jumper slot. The multilevel installation terminal blocks of Series 2003 are therefore suitable for use in very confined spaces. The optional busbar transparent cover (item no. 777-303) protects the busbar against accidental contact and makes it easy to see which terminal blocks are connected to the busbar. Removal of staggered jumpers Insert the screwdriver blade between the jumpers and lift them up. ? – The range of terminal blocks for all types of applications. ● The direct connection of solid wires in small distribution boxes saves time and money. ● Operating errors can be prevented as all types of terminal blocks for building installation are equipped with push-in connection technology. ● Terminal blocks for building installation expand circuit design possibilities. ● The use of standard accessories reduces order-processing and stock-holding costs. ● A high level of application safety is achieved through optimum knowledge of the small range of parts. ● As the position of the busbars is the same, the new ? installation terminal blocks are compatible with standard topJob installation terminal blocks. Environmentally friendly: ? terminal blocks are 100 % lead-free! The conductor entry holes of the multilevel installation terminal blocks are color marked, providing a clear arrangement of the terminals. The grounding foot automatically guarantees a safe connection to the carrier rail. 9 ? Multilevel Installation Terminal Blocks 4 mm2/AWG 12 Series 2003 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 250 V/4 kV ➋/3 400 V/6 kV ➌/3 IN 32 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in AWG 22 – 12 0.25 – 2.5 (4) mm2 ➊ 400 V/6 kV/3 IN 32 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 mm / Item Pack.-unit No. pcs Multilevel installation terminal block, grey with N-disconnect slide link 2003-7641 50 NT/L/PE Item Pack.-unit No. pcs Multilevel installation terminal blocks, grey L/L N/L 2003-7642 2003-7649 50 50 ➋ Potential-Ground ➌ Potential-Potential Item Pack.-unit No. pcs Multilevel installation terminal blocks, grey N/L/PE 2003-7646 50 L/L/PE 2003-7645 50 Staggered jumper with 7 contacts Breaking off contact lugs Commoning using staggered jumpers Individual jumper contacts can be broken off by bending them. The remaining piece of insulation meets the requirements for the air and creepage distance. This makes it possible to create custom staggered jumpers, e.g. for bridging over a terminal block with a different potential. When creating the jumpers, make sure that only one contact lug is in contact with the terminal block. Staggered jumper 1 – 3 – 5 – 7 Marking with a felttip pen That way, staggered jumpers are created whose contact lugs will make contact to the terminal block in the gaps of the second jumper. Insert the jumper into the jumper slot up to the stop. Two staggered jumpers Locate red stripes of the 1–3–5–7 staggered jumpers staggered for use in a on the inside jumper slot 10 Accessories for 2003 Series multilevel installation terminal blocks and 2002/2006/2016 Series N-conductor disconnect terminal blocks Item Pack.-unit No. pcs End and intermediate plate, 1 mm /0.039 in thick orange 2003-7692 100 (4 x 25) mm / can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm /0.472 in“ mm / VOLUME 1 1 Busbar carrier, for DIN rail 35 (not suitable for use as end stop) 1.5 mm/0.059 in thick 2009-304 100 (4 x 25) blue Busbar carrier with end stop function and detachable separator plate, for DIN rail 35; 7.5 mm / 0.295 in thick 2009-305 25 blue N-busbar, tinned see page 11 Cover for N-busbar, transparent see page 11 Neutral supply terminal block, IN 76 A, 16 mm2/AWG 6, blue 12 mm /0.472 in wide 2016-7114 25 Ground (earth) supply terminal block, IN 76 A, 16 mm2/AWG 6, green-yellow, 12 mm /0.472 in wide 2016-1207 20 ? tool, special blades 3.5 mm /0.137 in and 5.5 mm /0.217 in 2009-310 1 Connector, with blue cover see page 11 Connector, uninsulated, see page 11 Push-in type jumper bars, light grey, insulated, IN 25 A 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) Push-in type jumper bars, light grey, insulated, IN 25 A 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) Staggered jumper, light grey, insulated, IN 25 A 2-way 2002-472 100 (4 x 25) 3-way 2002-473 100 (4 x 25) 4-way 2002-474 100 (4 x 25) 5-way 2002-475 50 (2 x 25) : : 12-way 2002-482 50 (2 x 25) Pre-assembled staggered jumpers, with contact lugs that are factory removed with circuit printing, IN 25 A 1-3 2002-473/0011-0000 1-3-5 2002-475/0011-0000 1-3-5-7 2002-477/0011-0000 1-3-5-7-9 2002-479/0011-0000 1-3-5-7-9-11 2002-481/0011-0000 Test plug, Ø 2 mm /0.079 in 210-136 50 (5 x 10) Test plug adapter, for test plug Ø 4 mm /0.157 in 2009-174 100 (4 x 25) Testing tap, for max. 2.5 mm2/AWG 14 2009-182 100 (4 x 25) 0.5 – 4 (6) mm2 ➊ AWG 20 – 10 250 V/4 kV ➋/3 400 V/6 kV ➌/3 IN 36 A Terminal block width 6.2 mm / 0.244 in L 11 – 13 mm / 0.47 in mm / can be connected: 0.5 mm2 – 6 mm2 “s + f-st“; can be pushed in directly: 1 mm2 – 6 mm2 “s“ and 0.75 mm2 – 4 mm2 “insulated ferrule, 12 mm /0.472 in“ mm / ➊ AWG 20 – 10 0.5 – 4 (6) mm2 ➊ 400 V/6 kV/3 IN 36 A Terminal block width 6.2 mm / 0.244 in L 11 – 13 mm / 0.47 in Item Pack.-unit No. pcs Multilevel installation terminal block, grey with N-disconnect slide link 2005-7641 50 NT/L/PE Item Pack.-unit No. pcs Multilevel installation terminal blocks, grey L/L N/L 2005-7642 2005-7649 mm / ➋ Potential-Ground ➌ Potential-Potential 50 50 ! Accessories for 2005 Series multilevel installation terminal blocks and 2002/2006/2016 Series N-conductor disconnect terminal blocks Item Pack.-unit No. pcs End and intermediate plate, 1 mm /0.039 in thick orange 2005-7692 100 (4 x 25) Busbar carrier, for DIN rail 35 (not suitable for use as end stop) 1.5 mm /0.059 in thick 2009-304 100 (4 x 25) blue Busbar carrier with end stop function and detachable separator plate, for DIN rail 35; 7.5 mm /0.295 in thick 2009-305 25 blue N-busbar, tinned Copper 10 mm x 3 mm, IN 140 A, 1000 mm /39.37 in long 210-133 20 (20 x1) Cover for N-busbar transparent 1000 mm /39.37 in long 777-303 1 Neutral supply terminal block, IN 76 A, 16 mm2, blue 12 mm /0.472 in wide 2016-7114 25 Ground (earth) supply terminal block, IN 76 A, 16 mm2/AWG 6, green-yellow, 12 mm /0.472 in wide 2016-1207 20 14 Connector, with blue cover, for N-busbar 2.5 mm2 – 16 mm2/AWG 14 – 6 210-281 100 (2 x 50) Connector, uninsulated, for N-busbar 2.5 mm2 – 35 mm2/AWG 14 – 2 209-105 50 (2 x 25) ? tool, special blades 3.5 mm /0.137 in and 5.5 mm /0.217 in 2009-310 1 Item Pack.-unit No. pcs Multilevel installation terminal blocks, grey N/L/PE 2005-7646 50 L/L/PE 2005-7645 50 Push-in type jumper bars, light grey, insulated, IN 32 A 2-way 2004-402 100 (4 x 25) 3-way 2004-403 100 (4 x 25) 4-way 2004-404 100 (4 x 25) 5-way 2004-405 50 (2 x 25) : : 10-way 2004-410 50 (2 x 25) Push-in type jumper bars, light grey, insulated, IN 32 A 1 - 3 2004-433 100 (4 x 25) 1 - 4 2004-434 100 (4 x 25) 1 - 5 2004-435 50 (2 x 25) : : 1 - 10 2004-440 50 (2 x 25) Test plug, Ø 2 mm /0.079 in 210-136 50 (5 x 10) Test plug adapter, for test plug Ø 4 mm /0.157 in 2009-174 100 (4 x 25) Testing tap, for max. 2.5 mm2/AWG 14 2009-182 100 (4 x 25) 11 1 VOLUME 1 ? Multilevel Installation Terminal Blocks 6 mm2/AWG 8 Series 2005 ? N-Disconnect Terminal Blocks and Power Distribution Disconnect Terminal Blocks Series 2002, 2006 and 2016 0.5 – 16 (25 “f“) mm2 ➊ AWG 20 – 4 250 V/4 kV/3 IN 76 A Terminal block width 12 mm / 0.472 in L 18 – 20 mm / 0.75 in AWG 20 – 8 0.5 – 6 (10) mm2 ➊ 250 V/4 kV/3 IN 51 A Terminal block width 7.5 mm / 0.295 in L 13 – 15 mm / 0.55 in 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 250 V/4 kV/3 IN 32 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in VOLUME 1 1 < 35.5 mm /1.4 in > < 35.5 mm /1.4 in > < 37 mm /1.46 in > Item Pack.-unit No. pcs 1-conductor N-disconnect terminal block blue 2002-7114 ➋ 50 1-conductor power distribution disconnect terminal block grey 2002-7111 ➌ 50 Item Pack.-unit No. pcs 1-conductor N-disconnect terminal block blue 2006-7114 ➋ 50 1-conductor power distribution disconnect terminal block grey 2006-7111 ➌ 50 Item Pack.-unit No. pcs 1-conductor N-disconnect terminal block blue 2016-7114 ➋ 25 1-conductor power distribution disconnect terminal block grey 2016-7111 ➌ 25 End and intermediate plate, 0.8 mm /0.031 in thick orange 2002-7192 100 (4 x 25) End and intermediate plate, 1 mm /0.039 in thick orange 2006-7192 100 (4 x 25) End and intermediate plate, 1 mm /0.039 in thick orange 2016-7192 100 (4 x 25) For appropriate through and earth conductor terminal blocks see page 17 in ? catalog For appropriate through and earth conductor terminal blocks see page 17 in ? catalog For appropriate through and earth conductor terminal blocks see page 17 in ? catalog ➊ see also appropriate through terminal blocks ➋ For the construction and operation of power installations in fire hazardous locations or public buildings, such as meeting places, stores, hospitals, schools, theaters, hotels etc., the VDE 0100 or VDE 0108-1 standards must be observed. VDE 0100-482 must be observed for fire hazardous locations. Both VDE regulations determine that insulation testing must be possible for every circuit without disconnecting the N-conductor. WAGO N-disconnect terminal blocks meet this requirement. Testing with test plug Ø 2 mm Operation of the slide link using a simple screwdriver Removing the separator plate from the busbar carrier. Insertion of the separator plate. To protect the N-busbar against accidental contact 12 ➌ According to VDE 0107 “Installing and testing electrical installations in medical locations“, the equipotential bonding conductors must be connected to a potential equalization busbar. The potential equalization busbar and the protective earth conductor busbar must be accommodated in a common housing and be connected by means of a disconnectable connection using a copper conductor with a minimum cross section of 16 mm2/AWG 6. Furthermore, all equipotential bonding conductors must be connected to the potential equalization busbar in such a way that they are clearly arranged, that they can be disconnected individually and accessed at any time and, depending on their function, they must be provided with captive marking. The WAGO power distribution disconnect terminal blocks meet these requirements. VOLUME 1 1 13 VOLUME 1 Movable knife disconnects clearly indicate the circuit state. 2- and 4-conductor disconnect terminal blocks The 5.2 mm/0.205 in wide 2- and 4-conductor disconnect terminal blocks, that can be used in both control and process measurement systems as well as transformer circuits, are an addition to the range of ? rail-mounted terminal blocks. Two lateral and one center marker receptacle for WMB markers or marking strips. Dual jumper slots, in the same position as the other 2002 Series terminal blocks. Commoning options in front of or behind the knife disconnect, depending on which is the power supply side. Double deck double disconnect terminal blocks Disconnect terminal blocks of independent potentials are accommodated on two levels in a double deck disconnect terminal block. This results in a space saving arrangement without compromising the clarity of operation. The knife disconnects are located between the conductors and are therefore always in full view of the operator. Additional marking option using pivoting marking adapters. One disconnect and one through terminal block are accommodated on two levels in a terminal block that is only 5.2 mm/0.205 in wide. 14 Diode terminal blocks These diode terminal blocks have been specially developed for custom diode circuits such as lamp test and collective fault signal circuits. Using LED terminal blocks, monitoring units can be designed for control and operating circuits. The terminal blocks provide high density wiring maintaining a width of only 5.2 mm/0.205 in. Using push-in type jumper bars opens up additional possibilities when designing custom circuits. Polarized diode gate, common cathode Double deck diode terminal blocks + + ++ – Lamp test circuit Triple deck diode terminal blocks Open diode gate, can be connected individually. Using push-in type jumper bars, individual levels can be turned into polarized diode gates. 15 ? Disconnect Terminal Blocks for Test and Measurement with Movable Knife Disconnect and Through Terminal Blocks, Series 2002 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 400 V/6 kV/3 IN 16 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 400 V/6 kV/3 IN 16 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm /0.472 in“ Item Pack.-unit No. pcs 2-conductor disconnect terminal block for test and measurement 2002-1671 grey blue 2002-1674 orange 2002-1672 mm / mm / VOLUME 1 1 Item Pack.-unit No. pcs 2-conductor through terminal blocks, same profile as disconnect terminal block grey 2002-1601 blue 2002-1604 orange 2002-1602 Item-specific accessories End and intermediate plate, 1 mm /0.039 in thick orange 2002-1692 100 (4 x 25) grey 2002-1691 100 (4 x 25) Accessories Series 2002 End and intermediate plate, 1 mm /0.039 in thick orange 2002-1692 100 (4 x 25) grey 2002-1691 100 (4 x 25) appropriate marker system WMB/Marker strips/WMB Inline (see Full Line Catalog W4 Volume 1, Section 14) Insulation stop, 5 pcs/strip 200 strips light grey 2002-171 0.25-0.5 mm2 dark grey2002-172 0.75-1 mm2 Protective warning marker, for 5 terminal blocks yellow 2002-115 100 (4 x 25) Push-in type jumper bars, light grey, insulated, IN 25 A 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) Staggered jumper, light grey, insulated, IN 25 A 2-way 2002-472 100 (4 x 25) 3-way 2002-473 100 (4 x 25) 4-way 2002-474 100 (4 x 25) 5-way 2002-475 50 (2 x 25) : : 12-way 2002-482 50 (2 x 25) Push-in type jumper bars, light grey, insulated, IN 25 A Test plug adapter, for test plug Ø 4 mm /0.157 in 2009-174 100 (4 x 25) 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) Modular ? connector, for jumper contact slot 1 pole 2002-511 100 (4 x 25) Spacer, modular Testing tap, for max. 2.5 mm2/AWG 14 2009-182 Two-way marking adapter, pivotable 2002-121 2002-549 100 (4 x 25) Test plug, with cable 500 mm /1’7.7’’ Ø 2 mm/0.079 in red 210-136 50 (5 x 10) 16 100 (4 x 25) 50 (4 x 25) 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 400 V/6 kV/3 IN 16 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 400 V/6 kV/3 IN 16 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 Item Pack.-unit No. pcs 4-conductor disconnect terminal block for test and measurement 2002-1871 grey blue 2002-1874 orange 2002-1872 mm / mm / can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm /0.472 in“ Item Pack.-unit No. pcs 4-conductor through terminal blocks, same profile as disconnect terminal block grey 2002-1801 blue 2002-1804 orange 2002-1802 Item-specific accessories End and intermediate plate, 1 mm /0.039 in thick orange 2002-1892 100 (4 x 25) grey 2002-1891 100 (4 x 25) Accessories Series 2002 End and intermediate plate, 1 mm /0.039 in thick orange 2002-1892 100 (4 x 25) grey 2002-1891 100 (4 x 25) appropriate marker system WMB/Marker strips/WMB Inline (see Full Line Catalog W4 Volume 1, Section 14) Insulation stop, 5 pcs/strip 200 strips light grey 2002-171 0.25-0.5 mm2 dark grey2002-172 0.75-1 mm2 Protective warning marker, for 5 terminal blocks yellow 2002-115 100 (4 x 25) Push-in type jumper bars, light grey, insulated, IN 25 A 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) Staggered jumper, light grey, insulated, IN 25 A 2-way 2002-472 100 (4 x 25) 3-way 2002-473 100 (4 x 25) 4-way 2002-474 100 (4 x 25) 5-way 2002-475 50 (2 x 25) : : 12-way 2002-482 50 (2 x 25) Push-in type jumper bars, light grey, insulated, IN 25 A Test plug adapter, for test plug Ø 4 mm /0.157 in 2009-174 100 (4 x 25) 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) Modular ? connector**, for jumper contact slot 1 pole 2002-511 100 (4 x 25) Spacer, modular Testing tap, for max. 2.5 mm2/AWG 14 2009-182 Two-way marking adapter, pivotable 2002-121 2002-549 100 (4 x 25) Test plug, with cable 500 mm /1’7.7’’ Ø 2 mm/0.079 in red 210-136 50 (5 x 10) 17 100 (4 x 25) 50 (4 x 25) 1 VOLUME 1 ? Disconnect Terminal Blocks for Test and Measurement with ! Movable Knife Disconnect and Through Terminal Blocks, Series 2002 ? Double Deck Double Disconnect Terminal Blocks for Test and Measurement with Movable Knife Disconnect, Series 2002 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 400 V/6 kV/3 IN 16 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 400 V/6 kV/3 IN 16 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 400 V/6 kV/3 IN 16 A Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm /0.472 in“ Item Pack.-unit No. pcs 4-conductor double deck double disconnect terminal blocks grey blue grey N/L 2002-2951 2002-2954 2002-2952 mm / mm / mm / VOLUME 1 1 Item Pack.-unit No. pcs 4-conductor double deck double disconnect terminal blocks, lower deck and upper deck internally commoned on right side and with violet marking grey 2002-2958 blue 2002-2959 Item Pack.-unit No. pcs 4-conductor double deck disconnect terminal blocks, with disconnect on uper deck only, same profile as double deck double disconnect terminal blocks grey 2002-2971 blue 2002-2974 grey N/L 2002-2972 End and intermediate plate, 1 mm /0.039 in thick orange 2002-2992 100 (4 x 25) grey 2002-2991 100 (4 x 25) End and intermediate plate, 1 mm /0.039 in thick orange 2002-2992 100 (4 x 25) grey 2002-2991 100 (4 x 25) Item-specific accessories End and intermediate plate, 1 mm /0.039 in thick orange 2002-2992 100 (4 x 25) grey 2002-2991 100 (4 x 25) Accessories Series 2002 appropriate marker system WMB/Marker strips/WMB Inline (see also Full Line Catalog W4 Volume 1, Section 14) Insulation stop, 5 pcs/strip 200 strips light grey 2002-171 0.25-0.5 mm2 dark grey2002-172 0.75-1 mm2 Protective warning marker, for 5 terminal blocks yellow 2002-115 100 (4 x 25) Test plug, with cable 500 mm /1’7.7’’ Ø 2 mm/0.079 in red 210-136 Push-in type jumper bars, light grey, insulated, IN 25 A 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) Push-in type jumper bars, light grey, insulated, IN 25 A Staggered jumper, light grey, insulated, IN 25 A 2-way 2002-472 100 (4 x 25) 3-way 2002-473 100 (4 x 25) 4-way 2002-474 100 (4 x 25) 5-way 2002-475 50 (2 x 25) : : 12-way 2002-482 50 (2 x 25) Modular ? connector**, for jumper contact slot 1 pole 2002-511 100 (4 x 25) Test plug adapter, for test plug Ø 4 mm /0.157 in 2009-174 100 (4 x 25) Spacer, modular 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) 2002-549 100 (4 x 25) Testing tap, for max. 2.5 mm2/AWG 14 2009-182 100 (4 x 25) 18 50 (5 x 10) 0.25 – 1.5 (2.5) mm2 AWG 22 – 14 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current Terminal block width 4.2 mm / 0.165 in L 9 – 11 mm / 0.39 in 0,25 – 1,5 (2.5) mm2 AWG 22 – 14 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current Terminal block width 4.2 mm / 0.165 in L 9 – 11 mm / 0.39 in ! 0.25 – 1.5 (2.5) mm2 AWG 22 – 14 DC 24 V IF 0.025 A max. Terminal block width 4.2 mm / 0.165 in L 9 – 11 mm / 0.39 in 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 Item Pack.-unit No. pcs 2-cond. diode term. blocks with diode 1 N 4007 Circuit I, grey 2001-1211/1000-410 100 Circuit II, grey 2001-1211/1000-411 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2001-1201 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1292 100 (4 x 25) grey 2002-1291 100 (4 x 25) I mm / I II Item Pack.-unit No. pcs 3-cond. diode term. blocks with diode 1 N 4007 Circuit I, grey 2001-1311/1000-410 100 Circuit II, grey 2001-1311/1000-411 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2001-1301 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1392 100 (4 x 25) grey 2002-1391 100 (4 x 25) II Item Pack.-unit No. pcs 3-cond. LED term. blocks with red LED, DC 24 V Circuit I, grey 2001-1321/1000-434 100 Circuit II, grey 2001-1321/1000-413 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2001-1301 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1392 100 (4 x 25) grey 2002-1391 100 (4 x 25) mm / II mm / I mm / mm / can be pushed in directly: 0.5 mm – 2.5 mm “s“ and 0.75 mm2 – 1.5 mm2 “insulated ferrule, 12 mm /0.472 in“ I II Item Pack.-unit No. pcs 4-cond. diode term. blocks with diode 1 N 4007 Circuit I, grey 2001-1411/1000-410 100 Circuit II, grey 2001-1411/1000-411 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2001-1401 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1492 100 (4 x 25) grey 2002-1491 100 (4 x 25) 19 I II Item Pack.-unit No. pcs 4-cond. LED term. blocks with red LED, DC 24 V Circuit I, grey 2001-1421/1000-434 100 Circuit II, grey 2001-1421/1000-413 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2001-1401 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1492 100 (4 x 25) grey 2002-1491 100 (4 x 25) 1 VOLUME 1 ? Diode Terminal Blocks 1.5 (2.5) mm2 / AWG 14 and LED Terminal Blocks 1.5 (2.5) mm2 / AWG 14; Series 2001 ? Diode Terminal Blocks 2.5 (4) mm2 / AWG 12 and LED Terminal Blocks 2.5 (4) mm2; Series 2002 0.25 – 2.5 (4) mm2 AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current Terminal block width 5,2 mm / 0.205 in L 10 – 12 mm / 0.43 in 0.25 – 2.5 (4) mm2 AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 0.25 – 2.5 (4) mm2 AWG 22 – 12 DC 24 V IF 0.025 A max. Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 2 ➊ can be connected: 0.25 mm2 – 4 mm 2 mm / Item Pack.-unit No. pcs 2-cond. diode term. blocks with diode 1 N 4007 Circuit I, grey 2002-1211/1000-410 100 Circuit II, grey 2002-1211/1000-411 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2002-1201 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1292 100 (4 x 25) grey 2002-1291 100 (4 x 25) I I II Item Pack.-unit No. pcs 3-cond. diode term. blocks with diode 1 N 4007 Circuit I, grey 2002-1311/1000-410 100 Circuit II, grey 2002-1311/1000-411 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2002-1301 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1392 100 (4 x 25) grey 2002-1391 100 (4 x 25) II Item Pack.-unit No. pcs 3-cond. LED term. blocks with red LED, DC 24 V Circuit I, grey 2002-1321/1000-434 100 Circuit II, grey 2002-1321/1000-413 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2002-1301 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1392 100 (4 x 25) grey 2002-1391 100 (4 x 25) mm / II mm / I mm / “s + f-st“; can be pushed in directly: 0.75 mm – 4 mm2 “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm /0.472 in“ mm / VOLUME 1 1 I II Item Pack.-unit No. pcs 4-cond. diode term. blocks with diode 1 N 4007 Circuit I, grey 2002-1411/1000-410 100 Circuit II, grey 2002-1411/1000-411 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2002-1401 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1492 100 (4 x 25) grey 2002-1491 100 (4 x 25) 20 I II Item Pack.-unit No. pcs 4-cond. LED term. blocks with red LED, DC 24 V Circuit I, grey 2002-1421/1000-434 100 Circuit II, grey 2002-1421/1000-413 100 Examples of circuit configuration see page see 21 Through terminal block with the same shape grey 2002-1401 End and intermediate plate, 0.8 mm /0.032 in thick orange 2002-1492 100 (4 x 25) grey 2002-1491 100 (4 x 25) ? ! Accessories and Examples of Circuit Configuration Diode Terminal Blocks and LED Terminal Blocks; Series 2001/2002 Accessories Series 2002 Item Pack.-unit No. pcs Push-in type jumper bars, light grey, insulated, IN 18 A 2-way 2001-402 200 (8 x 25) 3-way 2001-403 200 (8 x 25) 4-way 2001-404 200 (8 x 25) 5-fway 2001-405 100 (4 x 25) : : 10-way 2001-410 100 (4 x 25) Item Pack.-unit No. pcs Push-in type jumper bars, light grey, insulated, IN 25 A 2-way 2002-402 200 (8 x 25) 3-way 2002-403 200 (8 x 25) 4-way 2002-404 200 (8 x 25) 5-way 2002-405 100 (4 x 25) : : 10-way 2002-410 100 (4 x 25) Push-in type jumper bars, light grey, insulated, IN 18 A Push-in type jumper bars, light grey, insulated, IN 25 A 1 - 3 2001-433 200 (8 x 25) 1 - 4 2001-434 200 (8 x 25) 1 - 5 2001-435 100 (4 x 25) : : 1 - 10 2001-440 100 (4 x 25) 1 - 3 2002-433 200 (8 x 25) 1 - 4 2002-434 200 (8 x 25) 1 - 5 2002-435 100 (4 x 25) : : 1 - 10 2002-440 100 (4 x 25) VOLUME 1 Accessories Series 2001 1 Examples of cuircuit configuration 2-conductor diode terminal block 3-conductor diode terminal block 4-conductor diode terminal block Open diode gate Polarized diode gate, common cathode Polarized diode gate, common cathode 3-conductor LED terminal block 4-conductor LED terminal block – – + – + + – – 21 + Voltage indication + + – Voltage indication ? Double Deck Diode Terminal Blocks / Double Deck LED Terminal Blocks 2.5 mm2/4 mm2 / AWG 12, Series 2002 VOLUME 1 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 < 52 mm /2.05 in > can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm/0.472 in“ Through terminal blocks with the same shape see page 6 Description Double deck diode terminal block and double deck LED terminal block, for DIN 35 rail Accessories I End and intermediate plate Push-in type jumper bars, light grey, insulated, IN 25 A Push-in type jumper bars, light grey, insulated, IN 25 A II I Item Pack. unit No. pcs Double deck diode terminal blocks with diode 1 N 4007 Circuit I, grey 2002-2211/1000-0410 50 Circuit II, grey 2002-2211/1000-0411 50 Appropriate marking system WMB/WMB < 52 mm /2.05 in > 1 II Item Pack. unit No. pcs Double deck diode terminal blocks with 2 diodes 1 N 4007 Circuit I, grey 2002-2214/1000-0492 50 Circuit II, grey 2002-2214/1000-0491 50 Inline (see also Full Line Catalog W4 Volume 1, Section 14) 0.8 mm /0.032 in thick orange 2002-2292 grey 2002-2291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 Two-way marking adapter, pivotable 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-121 50 (2 x 25) 100 (4 x 25) 0.8 mm /0.032 in thick orange 2002-2292 grey 2002-2291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-121 50 (2 x 25) 100 (4 x 25) Examples of circuit configuration + –+ –+ – + Used as recovery diodes Used in lamp test circuit 22 + ++ – 1 ! 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current 0.25 – 2.5 (4) mm2 ➊ DC 24 V IF 25 mA max. Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in II I II I – Item Pack. unit No. pcs Double deck diode terminal blocks with 2 diodes 1 N 4007 Circuit I, grey 2002-2214/1000-0489 50 Circuit II, grey 2002-2214/1000-0490 50 Appropriate marking system WMB/WMB 0.8 mm /0.032 in thick orange 2002-2292 grey 2002-2291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 + 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-121 50 (2 x 25) + Used in lamp test circuit + 100 (4 x 25) + – II + – + Item Pack. unit No. pcs Double deck diode terminal blocks with 2 diodes 1 N 4007 Circuit I, grey 2002-2213/1000-0487 50 Circuit II, grey 2002-2213/1000-0488 50 VOLUME 1 < 52 mm /2.05 in > < 52 mm /2.05 in > < 52 mm /2.05 in > I AWG 22 – 12 + + – – Item Pack. unit No. pcs Double deck LED terminal blocks with red LED, DC 24 V Circuit I, grey 2002-2221/1000-0434 50 Circuit II, grey 2002-2221/1000-0413 50 Inline (see also Full Line Catalog W4 Volume 1 Section 14) 0.8 mm /0.032 in thick orange 2002-2292 grey 2002-2291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-121 50 (2 x 25) + + + + + + Used for collective fault indication 23 100 (4 x 25) – 0.8 mm /0.032 in thick orange 2002-2292 grey 2002-2291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 – 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-121 50 (2 x 25) +– Used for voltage indication +– 100 (4 x 25) + ? Triple Deck Diode Terminal Blocks / Triple Deck LED Terminal Blocks 2.5 mm2/4 mm2 / AWG 12, Series 2002 VOLUME 1 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in 2 “s + f-st“; ➊ can be connected: 0.25 mm2 – 4 mm 2 2 can be pushed in directly: 0.75 mm – 4 mm “s“ and 0.75 mm2 – 2.5 mm2 “insulated ferrule, 12 mm/0.472 in“ Through terminal blocks with the same shape see page 7 Description Triple deck diode terminal block and Triple deck LED terminal block, for DIN 35 rail Accessories I Push-in type jumper bars, light grey, insulated, IN 25 A Push-in type jumper bars, light grey, insulated, IN 25 A Two-way marking adapter, pivotable II Item Pack. unit No. pcs Triple deck diode terminal blocks with diode 1 N 4007 Circuit I, grey 2002-3211/1000-0675 50 Circuit II, grey 2002-3211/1000-0676 50 Inline (see also Full Line Catalog W4 Volume 1, Section 14) 0.8 mm /0.032 in thick orange 2002-3292 grey 2002-3291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 I Item Pack. unit No. pcs Triple deck diode terminal blocks with diode 1 N 4007 Circuit I, grey 2002-3211/1000-0410 50 Circuit II, grey 2002-3211/1000-0411 50 Appropriate marking system WMB/WMB End and intermediate plate II 1 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-131 50 (2 x 25) 24 100 (4 x 25) 0.8 mm /0.032 in thick orange 2002-3292 grey 2002-3291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-131 50 (2 x 25) 100 (4 x 25) ! 0.25 – 2.5 (4) mm2 ➊ AWG 22 – 12 UN 250 V; URM 1000 V 1 N 4007 – 0.5 A continuous current 0.25 – 2.5 (4) mm2 ➊ DC 24 V IF 25 mA max. Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in Terminal block width 5.2 mm / 0.205 in L 10 – 12 mm / 0.43 in I II I Item Pack. unit No. pcs Triple deck diode terminal blocks with 3 diodes 1 N 4007 Circuit I, grey 2002-3212/1000-0673 50 Circuit II, grey 2002-3212/1000-0674 50 Item Pack. unit No. pcs Triple deck LED terminal blocks with red LED, DC 24 V Circuit I, grey 2002-3221/1000-0434 50 Circuit II, grey 2002-3221/1000-0413 50 Appropriate marking system WMB/WMB 0.8 mm /0.032 in thick orange 2002-3292 grey 2002-3291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-131 50 (2 x 25) 100 (4 x 25) II Inline (see also Full Line Catalog W4 Volume 1 Section 14) 0.8 mm /0.032 in thick orange 2002-3292 grey 2002-3291 2-way 2002-402 3-way 2002-403 4-way 2002-404 5-way 2002-405 : : 10-way 2002-410 1- 3 1- 4 1- 5 : 1 - 10 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 2002-433 2002-434 2002-435 : 2002-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 2002-131 50 (2 x 25) 25 100 (4 x 25) VOLUME 1 AWG 22 – 12 1 VOLUME 1 1 Push-in Type Wire Jumpers and Star Point Jumpers Wire jumpers Nominal voltage: Nominal current: Nominal cross section: Conductor lengths: 800 V/8 kV/3 16 A 1.5 mm2/AWG 16 60/110/250 mm 2.36/4.33/9.84 in Star point jumpers Nominal voltage: Nominal current: 800 V/8 kV/3 IN ^ = IN Terminal block of the relevant series Item Pack.-unit No. pcs Push-in type wire jumpers, insulated, conductor cross section 1.5 mm2/AWG 16, suitable for rail-mounted terminal blocks series 2001 and 2002 Item No. Star Point Jumpers, light grey, insulated Wire length 60 mm /2.36 in 2002 2002-0405/0011-000 2004 2004-0405/0011-000 2006 2006-0405/0011-000 2010 2010-0405/0011-000 2016 2016-0405/0011-000 2009-412 Pack.-unit pcs suitable for series 10 110 mm /4.33 in 2009-414 10 250 mm /9.84 in 2009-416 10 Applications notes Push down the wire jumper until fully inserted. Lift the jumper with a screwdriver for rewiring. This jumper has been specially developed to create a "star point" and is used on motor terminal boards equipped with ? rail-mounted terminal blocks. 26 Finger guard cover for ? rail-mounted terminal blocks Group Marker Carriers Series 2009 WAGO pivotable group marker carrier – for ? rail-mounted terminal blocks – for rail-mounted terminal blocks from 5 mm /0.197 in on and in spacer housings ? group marker carriers, Module width 5 mm / 0.197 in Module width 10 mm / 0.394 in Module width 15 mm / 0.591 in for marker cards and self-adhesive marker cards __> ___ ___ _ 35 __ Level a ___ _ _ ___ < Level b Item No. Pack.-unit pcs Finger guard cover, serves as touchproof protection for unused clamping units for ? rail-mounted terminal blocks series 2010 2010-100 100 (4 x 25) 2016 2016-100 100 (4 x 25) * from upper edge of terminal block Item No. Pivotable group marker carrier 249-105 Pack.-unit pcs 50 Marker card, 4 x 30 pcs per sheet 209-183 1 sheet Protection cover, transparent 209-184 50 Item No. ? group marker carriers, snap-on type for jumper slot 5 mm/0.197 in wide 2009-191 10 mm/0.394 in wide 2009-192 15 mm/0.591 in wide 2009-193 Pack.-unit pcs 50 50 50 WAGO Multi marking system WMB, miniature WSB Quick marking system, marker strips, 11 mm /0.433 in wide for marker cards and self-adhesive marker cards 2009-196 50 (see also Full Line Catalog W4 Volume 1, Section 14) Insert finger guard cover into unused clamping unit This pivotable group marker carrier has been developed for group marking of rail-mounted terminal blocks and brings together many requirements of our customers. ● Can be used in all multiprofile marker receptacles for rail-mounted terminal bocks from 5 mm width on or in spacer housings as shown in the picture ● Pivotable in 7 different stable positions, providing the best visual angle in case of difficult mounting conditions ● Two levels for different marking systems Level a: for marker card (4 x 34) mm (see picture) Level b: for 12 WCB-Combi markers (see left column) 27 ? group marker carrier (equipped with WMB Multi marking system). Suitable for all ? rail-mounted terminal blocks from Series 2001 to 2016 1 VOLUME 1 Finger Guard Cover Pivotable Group marker carrier WAGO Marking System WMB Inline Series 2009 VOLUME 1 1 Marking WMB or miniature WSB markers can be used in three positions of the ? products. Moreover, a full length marking strip can be used in the top position of a terminal block. The terminal blocks from 1.5 mm2/AWG 16 to 6 mm2/AWG 10 as well as 10 mm2/AWG 8 and 16 mm2/AWG 6 are at the same height which allows quick marking even of terminal blocks of different sizes. The WAGO “smart Designer“ software and a thermal transfer printer generate the marking. WMB – Inline ● Markers “from the roll” save time and money ● A thermal transfer printer and the WAGO “smart Designer“ software generate the marking ● Markers fit 5 mm /0.197 in and 5.2 mm / 0.205 in wide terminal blocks and can hence be used for all 2.5 mm2 WAGO rail-mounted terminal blocks ● Can be separated easily ● When separated they can also be fitted on all wider WAGO rail-mounted terminal blocks WMB Inline, pitch 5 mm /0.197 in, for 5 mm /0.197 in and 5.2 mm /0.205 in, on roll, 10 m white 2009-115 1 roll 1500 markers / roll 28 VOLUME 1 1 29 The Range of Rail Mounted Terminal Blocks for Wire Sizes Ranging from 6 mm2 – 95 mm2/AWG 8 to AWG 4/0 Connecting conductors up to 95 mm2 /AWG 4/0 with a turn of the hand The 285 Series of rail-mounted terminal blocks are suitable for applications with rated currents up to 232 A. Based on a unique patented technology, the largest version, 285-195, rated for 25-95 mm2/AWG 4 to AWG 4/0 has been holding its ground in the market for many years. Now, two additional terminal blocks for wire sizes down to 6 mm2 (AWG 8) have been added to the range: 285–135, 6 – 35 mm2/AWG 8 to AWG 2 285–150, 10– 50 mm2/AWG 8 to 2/0 (70 mm2 “f-st”). Operation of these new terminals is essentially the same as the 95 mm2 terminal block. The 35 mm2 terminal block has the following differences. Commoning adjacent terminal blocks using centrally positioned adjacent jumper. In addition to the WMB marking system, custom marking strips can also be used. Testing using plug adapters for Ø 4 mm plugs. Move the marking strip laterally to remove the jumper. Counter-clockwise rotation using a screwdriver 5.5 mm/ 0.217 in. Hold clamp in open position using the latch. Introduce stripped wire into the clamping unit up to the stop and hold it in position . . . The voltage tap is inserted into the jumper contact slot. It can be fitted with a strain relief plate and provides test option for Ø 2 mm test sockets. . . . A small counter-clockwise rotation releases the latch ➊. Once the screwdriver ➋ has been removed the conductor is safely clamped. Side entry wiring means that even larger cables, which are flexible to a limited degree, can be connected without a problem. 30 6– 35 mm2 AWG 8 – 2 Item Pack. unit No. pcs 2-conductor through terminal blocks grey 285-135 15 blue 285-134 15 Item Pack. unit No. pcs 2-conductor ground (earth) terminal blocks 285-137 15 green-yellow To be used exclusively on DIN 35 x 15; 2.3 mm / 0.091 in thick To be used exclusively on DIN 35 x 15; 2.3 mm / 0.091 in thick, Cu Accessories 0.2 – 6 mm2 AWG 24 – 10 800 V/8 kV/3 IN 32 A Terminal block width 8 mm / 0.315 in L 12 – 13 mm / 0.49 in Terminal block width 16 mm / 0.63 in L 25 – 26 mm / 0.98 in AWG 8 – 2 6 – 35 mm2 600 V, 115 A U 1000 V/8 kV/3 ➊ IN 125 A 600 V Terminal block width 16 mm / 0.63 in L 25 – 26 mm / 0.98 in } 2 Appropriate marking system WMB/Marker strips (see W4 Volume 1, Section 14) Adjacent jumper, insulated, I N 100 A for 1 jumper I N 85 A for 2 to 4 jumpers grey 285-435 50 (2 x 25) Screwdriver with partially insulated shaft, type 3, blade 5.5 x 0.8 mm / 0.217 in x 0.031 in 210-621 1 Protective warning marker, with high voltage symbol, black yellow 285-420 50 (2 x 25) Adjacent jumper, insulated, I N 100 A for 1 jumper A for 2 to 4 jumpers IN grey 285-435 50 (2 x 25) crewdriver with partially insulated shaft, type 3, blade 5.5 x 0.8 mm / 0.217 in x 0.031 in 210-621 1 Protective warning marker, with high voltage symbol, black yellow 285-420 50 (2 x 25) Finger guard cover, serves as touchproof protection for unused clamping units yellow 285-421 25 Finger guard cover, serves as touchproof protection for unused clamping units yellow 285-421 25 Test plug adapter, 11.6 mm/4.57 in wide, for test plug 4 mm /0.157 in Ø 283-404 25 Test plug adapter, 11.6 mm/4.57 in wide, for test plug 4 mm /0.157 in Ø 283-404 25 Test plug, Ø 4 mm /0.157 in, protected against accidental contact, not offered by WAGO e. g. Fa. Multi-Contact Deutschland GmbH Postfach 16 06 · 79551 Weil am Rhein Hegenheimerstraße 19 · 79576 Weil am Rhein Test plug, Ø 4 mm /0.157 in, protected against accidental contact, not offered by WAGO e. g. Fa. Multi-Contact Deutschland GmbH Postfach 16 06 · 79551 Weil am Rhein Hegenheimerstraße 19 · 79576 Weil am Rhein 31 Item No. Voltage tap, grey Pack. unit pcs 285-427 5 Appropriate marking system WMB Strain relief plate, snap-on type for voltage tap grey 769-410 100 (4 x 25) Test plug, with cable 500 mm /1’7.7’’ 2 mm Ø, red 210-136 50 (5 x 10) ➊ 1000 V = rated voltage 8 kV = rated surge voltage 3 = pollution degree (see also Full Line Catalog W4 Volume 1, Section 15) VOLUME 1 High Current Through/Ground (Earth) Conductor Terminal Blocks 35 mm2/AWG 2, Series 285, Side-entry High Current Through/Ground (Earth) Conductor Terminal Blocks 50 (70 “f-st”) mm2/AWG 2/0; Series 285, Side-entry 10 – 50 (70 “f-st”) mm2 AWG 8 – 2/0 Terminal block width 20 mm / 0.78 in L 30 mm / 1.18 in Item Pack. unit No. pcs 2-conductor ground (earth) terminal blocks 285-157 5 green-yellow To be used exclusively on DIN 35 x 15; 2.3 mm / 0.091 in thick To be used exclusively on DIN 35 x 15; 2.3 mm / 0.091 in thick, Cu Appropriate marking system WMB (see Full Line Catalog W4 Volume 1, Section 14) Adjacent jumper, insulated, I N 150 A grey 285-450 25 2 x 0,2 – 6 mm2 AWG 24 – 10 1000 V/8 kV/3 IN 41 A Module width 16 mm / 0.63 in L 12 – 13 mm / 0.49 in Item Pack. unit No. pcs 2-conductor through terminal blocks grey 285-150 5 blue 285-154 5 Accessories } 10 – 50 (70 “f-st”) mm2 AWG 8 – 2/0 600 V 1000 V/8 kV/3 ➊ 600 V IN 150 A Terminal block width 20 mm / 0.78 in L 30 mm / 1.18 in VOLUME 1 2 Adjacent jumper, insulated, I N 150 A grey Voltage tap, grey Hex wrench with partially insulated shaft 285-172 1 Protective warning marker, with high voltage symbol, black yellow 285-420 50 (2 x 25) Protective warning marker, with high voltage symbol, black yellow 285-420 50 (2 x 25) Finger guard cover, serves as touchproof protection for unused clamping units yellow 285-421 25 Finger guard cover, serves as touchproof protection for unused clamping units yellow 285-421 25 Test plug, Ø 4 mm /0.157 in, protected against accidental contact, not offered by WAGO e. g. Fa. Multi-Contact Deutschland GmbH Postfach 16 06 · 79551 Weil am Rhein Hegenheimerstraße 19 · 79576 Weil am Rhein Test plug, Ø 4 mm /0.157 in, protected against accidental contact, not offered by WAGO e. g. Fa. Multi-Contact Deutschland GmbH Postfach 16 06 · 79551 Weil am Rhein Hegenheimerstraße 19 · 79576 Weil am Rhein 285-447 Pack. unit pcs 5 Appropriate marking system WMB ➊ 285-450 25 Hex wrench with partially insulated shaft 285-172 1 32 Item No. 1000 V = rated voltage 8 kV = rated surge voltage 3 = pollution degree (see also Full Line Catalog W4 Volume 1, Section 15) Collective carrier for standard and special jumpers in longitudinal disconnect and transverse switch terminal blocks, Series 282, can be snapped onto DIN 35 rail Width 15.8 mm / 0.62 in (^ = 2 x pitch 8 mm) Storage mm / Safe storage for jumpers that are only needed temporarily in longitudinal disconnect and transverse switch terminal blocks. Jumpers are used as a “switch” for the transformer short circuit, for example with the longitudinal disconnect terminal blocks. Pre-locking positions in the terminal blocks hold the jumpers captive during normal operation. For users who prefer to store the jumpers outside the terminal block, the collective carrier is an ideal solution. Item No. Collective carrier for jumpers 282-369 Suitable for jumpers for transverse switch t. bl. 282-811 and longitudinal disc. t. bl. 282-821 Pack. unit pcs 25 Appropriate for the following jumpers: Jumpers, orange, IN 30 A 2-way 3 -way 4 -way 5-way 6 -way 7 -way 8 -way 9 -way 10-way 282-432 282-433 282-434 282-435 282-436 282-437 282-438 282-439 282-440 50 (5 x 10) 50 (5 x 10) 50 (5 x 10) 50 (5 x 10) 50 (5 x 10) 50 (5 x 10) 50 (5 x 10) 50 (5 x 10) 50 (5 x 10) Insertion of a jumper Transformer test circuits and complex wiring tasks... ...are no problem and only require minimum space. Customised jumpers are available on request Application areas: – Power supply – Transformer test circuits Jumpers, special version, orange, IN 30 A 3-way (1-3-5) 4-way (1-3-5-7) 282-435/011-000 50 (5 x 10) 282-437/011-000 50 (5 x 10) The collective carrier can be snapped onto DIN 35 rails. It serves as a depository for jumpers, e.g. during maintenance work. 33 VOLUME 1 7 Collective Carrier for Standard and Special Jumpers, Series 282 X-COM® SYSTEM 2-Conductor/1-Pin Receptacle Terminal Blocks 0.08 – 4 mm2 500 V/6 kV/3 ➊ IN 32 A* VOLUME 1 0.08 – AWG 28 – 12 300 V, 20 A U 300 V, 20 A 2 Terminal block width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in ➊ ➋ 500 V = rated voltage 6 kV = rated surge voltage 3 = pollution degree (see also Full Line Catalog W4 Volume 1, Section 15) See application notes in our Full Line Catalog W4 Volume 1, pages 2.43 – 2.45 Terminal block width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in * U2 Description 2-conductor/1-pin receptacle terminal block, suitable for DIN 35 rail acc. to EN 50 022 Item Pack. unit No. pcs 2-conductor/1-pin receptacle terminal block grey 769-251 50 Accessories Item Pack. unit No. pcs 2-conductor/1-pin ground (earth) receptacle terminal block green-yellow 769-257 50 appropriate marking system Mini-WSB (see also Full Line Catalog W4 Volume 1, Section 14) End and intermediate plate Screwless end stop Insulation stop 5 pcs/strip L AWG 28 – 12 mm / < 28.5 1.12 in > * U2 4 mm2 mm / < 28.5 1.12 in > 9 ➋, white light grey dark grey IN 24 A Adjacent jumper, insulated Alternate jumper Staggered jumper ➋, from 1 to 2 insulated, from 1 to 3 width 5 mm /0.197 in from 1 to 4 from 1 to 5 : from 1 to 8 Push-in type wire jumper ➋, insulated, 9 A – conductor cross section 0.75 mm2/AWG 18 Coding pin, for coding of female plugs Protective warning marker, for 5 terminal blocks, fits into screwdriver slot Test plug, w. cable 500 mm/1’7.7’’ 2 mm/0.079 in Ø 2.3 mm/0.091 in Ø Test plug module, for test using jumper position in current bar or cond. wire opening Test plug adapter 1.1 mm /0.043 in thick grey 769-320 orange 769-321 100 (4 x 25) 100 (4 x 25) 1.1 mm /0.043 in thick grey 769-320 orange 769-321 100 (4 x 25) 100 (4 x 25) 6 mm /0.236 in wide 249-116 10 mm /0.394 in wide 249-117 0.08 – 0.2 mm2 769-470 0.25 – 0.5 mm2 769-471 769-472 0.75 – 1 mm2 grey 280-402 100 (4 x 25) 50 (2 x 25) 200 strips 200 strips 200 strips 200 (8 x 25) 6 mm /0.236 in wide 249-116 10 mm /0.394 in wide 249-117 0.08 – 0.2 mm2 769-470 0.25 – 0.5 mm2 769-471 769-472 0.75 – 1 mm2 yellow-green 280-422 100 (4 x 25) 50 (2 x 25) 200 strips 200 strips 200 strips 200 (8 x 25) 280-409 780-452 780-453 780-454 780-455 : 780-458 L = 60 mm /2.362 in 249-125 L = 110 mm /4.331 in 249-126 L = 250 mm /9.843 in 249-127 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 50 (2 x 25) 280-409 780-452 780-453 780-454 780-455 : 780-458 L = 60 mm /2.362 in 249-125 L = 110 mm /4.331 in 249-126 L = 250 mm /9.843 in 249-127 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 50 (2 x 25) orange 769-435 100 (4 x 25) 769-435 100 (4 x 25) yellow 280-415 100 (4 x 25) grey IN 24 A orange 50 (2 x 25) 10 10 10 red 210-136 50 (5 x 10) yellow 210-137 50 (5 x 10) Item numbers and application notes see Full Line Catalog W4 Volume, pages 2.38 – 2.40 red 210-136 50 (5 x 10) yellow 210-137 50 (5 x 10) Item numbers and application notes see Full Line Catalog W4 Volume 1, pages 2.38 – 2.40 5 mm /0.197 in wide 5 mm /0.197 in wide 280-404 for test plug 210-137 (Ø 2.3 mm) 1-conductor female plug, straight or angled 50 (2 x 25) 10 10 10 grey IN 24 A 100 (4 x 25) 280-404 for test plug 210-137 (Ø 2.3 mm) 100 (4 x 25) see Full Line Catalog W4 Volume 1, pages 9.44/9.46 see Full Line Catalog W4 Volume 1, pages 9.44/9.46 see Full Line Catalog W4 Volume 1, page 9.45 see Full Line Catalog W4 Volume 1, page 9.45 2-conductor female plug * Further approvals with corresponding ratings can be found at www.wago.com 34 Types of Assembly 2-Conductor/1-pin Receptacle Terminal Blocks and 1-/2-Conductor Female Plugs Ground (earth) receptacle terminal block 1-conductor female plug Commoning possibility of receptacle straight and angled terminal blocks with jumper contact systems, series 280 and 780, and testing possibility with test plug adapter 280-4 . . Receptacle terminal block Operating lever, loose, for female plugs and male connectors with CAGE CLAMP® connection Item number: 769-434 Wire connection using operating lever 35 Commoning possibility of receptacle terminal blocks only with adjacent jumpers and alternate jumpers, series 280 2-conductor female plug 9 VOLUME 1 ° 0.08 – 4 mm2 AWG 28 – 12 300 V, 10 A 400 V/6 kV/3 ➊ IN 32 A Terminal block width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in Description 1-conductor/1-conductor disconnect receptacle terminal block without/with shield (screen) contact and 2 jumper positions, suitable for DIN 35 rail acc. to EN 60715 Accessories appropriate marking system Mini-WSB (see also Full Line Catalog W4 Volume 1, Section 14) 1.1 mm /0.043 in thick grey 769-317 orange 769-318 1.1 mm /0.043 in thick orange 769-319 End and intermediate plate Separator plate, oversized Screwless end stop Insulation stop ➋, 5 pcs /strip L Item Pack. unit No. pcs 1-cond./1-cond. disconnect receptacle term. block grey 769-242 50 1-cond./1-cond. disconnect receptacle term. block with shield (screen) contact (no picture) grey 769-243 50 white light grey dark grey IN 24 A Adjacent jumper, insulated Alternate jumper Staggered jumper ➋, from 1 to 2 insulated, from 1 to 3 width 5 mm /0.197 in from 1 to 4 from 1 to 5 : from 1 to 8 Push-in type wire jumper ➋, insulated, 9 A – conductor cross section 0.75 mm2/AWG 18 Protective warning marker, for 5 terminal blocks fits into screwdriver slot, Test plug, w. cable 500 mm/1’7.7’’ Ø 2 mm/0.079 in Ø 2.3 mm/0.091 in 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 6 mm /0.236 in wide 249-116 10 mm /0.394 in wide 249-117 0.08 – 0.2 mm2 769-470 0.25 – 0.5 mm2 769-471 769-472 0.75 – 1 mm2 grey 280-402 100 (4 x 25) 50 (2 x 25) 200 strips 200 strips 200 strips 200 (8 x 25) 280-409 780-452 780-453 780-454 780-455 : 780-458 L = 60 mm /2.362 in 249-125 L = 110 mm /4.331 in 249-126 L = 250 mm /9.843 in 249-127 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 50 (2 x 25) yellow 280-415 100 (4 x 25) red yellow 210-136 210-137 50 (5 x 10) 50 (5 x 10) grey IN 24 A 36 50 (2 x 25) 10 10 10 ➋ 500 V = rated voltage 6 kV = rated surge voltage 3 = pollution degree (see also Full Line Catalog W4 Volume 1, Section 15) See application notes in our Full Line Catalog W4 Volume 1, pages 2.43 – 2.45 ➊ mm / < 28.5 1.12 in > VOLUME 1 9 X-COM® SYSTEM 1-Conductor/1-Conductor Disconnect Receptacle Terminal Blocks with 2 Jumper Positions X-COM®-SYSTEM 2-Conductor/2-Pin Double Deck Receptacle Terminal Blocks Series 870 mm / Terminal block width 5 mm / 0.197 in mm / ➊ 500 V = rated voltage 6 kV = rated surge voltage 3 = pollution degree (see also Full Line Catalog W4 Volume 1, Section 15) Description 2-pin/2-pin double deck receptacle terminal block, suitable for DIN 35 rail Item No. Through/through terminal blocks, housing color grey L /L 870-151 Pack. unit pcs Item No. Pack. unit pcs 50 4-pin double deck receptacle terminal block, suitable for DIN 35 rail 4-pin ground (earth) conductor terminal block, internal commoning, housing color green-yellow PE Accessories VOLUME 1 500 V/6 kV/3 ➊ IN 16 A Terminal block width 5 mm / 0.197 in 9 870-157 50 appropriate marking system WMB/Mini-WSB (see also Full Line Catalog W4 Volume 1, Section 14) End and intermediate plate Push-in type jumper bars, light grey, insulated, IN 18 A Push-in type jumper bars, light grey, insulated, IN 18 A Miniature WSB quick marking card, 10 strips with 10 markers each, white with black printing 1-connector female plug, straight 1-connector female plug, angled 1 mm /0.039 in thick grey orange 2-way 3-way 4-way 5-way : 10-way 870-168 870-169 870-402 870-403 870-404 870-405 : 870-410 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) from 1 to 3 from 1 to 4 from 1 to 5 : from 1 to 10 870-433 870-434 870-435 : 870-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 1 mm /0.039 in thick grey orange 2-way 3-way 4-way 5-way : 10-way 870-168 870-169 870-402 870-403 870-404 870-405 : 870-410 100 (4 x 25) 100 (4 x 25) 200 (8 x 25) 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) from 1 to 3 from 1 to 4 from 1 to 5 : from 1 to 10 870-433 870-434 870-435 : 870-440 200 (8 x 25) 200 (8 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) see Full Line Catalog W4 Volume 1, Section 14 see Full Line Catalog W4 Volume 1, Section 14 see Full Line Catalog W4 Volume 1, Section 9 see Full Line Catalog W4 Volume 1, Section 9 see Full Line Catalog W4 Volume 1, Section 9 see Full Line Catalog W4 Volume 1, Section 9 37 VOLUME 1 9 X-COM®-SYSTEM Blue Components 0.08 – 4 mm2 AWG 28 – 12 300/600 V, 10/5 A U 500 V/6 kV/3 ➊ 300 V, 10 A 2 IN 32 A** Module width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in 0.08 – 4 mm2 AWG 28 – 12 500 V/6 kV/3 ➊ IN 32 A** Module width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in 0.08 – 4 mm2 AWG 28 – 12 500 V/6 kV/3 ➊ IN 32 A** Terminal block width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in No. of Item Pack. unit poles No. pcs 1-conductor female plug, with coding fingers, grey, blue, green-yellow, commoning possibility with miniature adjacent jumpers No. of Item Pack. unit poles No. pcs 1-conductor female plug, with coding fingers, grey, blue, green-yellow, commoning possibility with miniature adjacent jumpers * U2 No. of Item Pack. unit poles No. pcs 1-conductor female plugs, with coding fingers, blue, commoning possibility with miniature adjacent jumpers 1 pole 2 poles 3 poles 4 poles 5 poles 6 poles 7 poles 8 poles 9 poles 10 poles 11 poles 12 poles 13 poles 14 poles 15 poles ➊ 769-101/000-006 769-102/000-006 769-103/000-006 769-104/000-006 769-105/000-006 769-106/000-006 769-107/000-006 769-108/000-006 769-109/000-006 769-110/000-006 769-111/000-006 769-112/000-006 769-113/000-006 769-114/000-006 769-115/000-006 200 100 50 50 50 50 50 50 50 50 50 50 50 50 50 5 poles 3 poles 769-103/000-038 1-conductor female plug, with coding fingers, green-yellow, blue, grey commoning possibility with miniature adjacent jumpers 3 poles 769-103/000-039 500 V = rated voltage 6 kV = rated surge voltage 3 = pollution degree Miniature adjacent jumper, insulated, IN 24 A, grey, suitable for 1-conductor female plugs 769-402 100 (4 x 25) * Further approvals with corresponding ratings can be found at www.wago.com ** Current-carrying capacity curves and accessories see Full Line Catalog W4 Volume 1, Section 9 38 769-105/000-038 50 50 50 1-conductor female plug, with coding fingers, green-yellow, blue, grey commoning possibility with miniature adjacent jumpers 5 poles 769-105/000-039 50 0.08 – 4 mm2 AWG 28 – 12 300/600 V, 10/5 A U 500 V/6 kV/3 ➊ 300 V, 10 A 2 IN 32 A** Module width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in * U2 * U2 No. of Item Pack. unit poles No. pcs 1-conductor/1-pin receptacle terminal block, blue suitable for DIN 35 rail acc. to EN 60715 769-176/000-006 ➊ 0.08 – 4 mm2 AWG 28 – 12 300/600 V, 10/5 A U 500 V/6 kV/3 ➊ 300 V, 10 A 2 IN 32 A** Module width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in 100 0.08 – 4 mm2 AWG 28 – 12 300/600 V, 10/5 A U 500 V/6 kV/3 ➊ 300 V, 10 A 2 IN 32 A** Terminal block width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in * U2 No. of Item Pack. unit poles No. pcs 2-conductor/1-pin receptacle terminal block, blue suitable for DIN 35 rail acc. to EN 60715 769-251/000-006 500 V = rated voltage 6 kV = rated surge voltage 3 = pollution degree Adjacent jumper, unsulated, IN 24 A, grey 280-402 200 (8 x 25) Alternate jumper, unsulated, IN 24 A, grey 280-409 100 (4 x 25) 39 50 No. of Item Pack. unit poles No. pcs 2-conductor/2-pin receptacle terminal block, blue suitable for DIN 35 rail acc. to EN 60715 769-171/000-006 50 9 VOLUME 1 ° X-COM®-SYSTEM Female Plugs for Self-Assembly VOLUME 1 9 0.08 – 4 mm2 AWG 28 – 12 500 V/6 kV/3 ➊ IN 32 A** Module width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in 0.08 – 4 mm2 AWG 28 – 12 500 V/6 kV/3 ➊ IN 32 A** Module width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in Color Color Item No. Pack.-unit pcs 1-conductor base module with integrated end plate grey 769-501 blue 769-501/000-006 green-yellow 769-501/000-016 Pack.-unit pcs 250 250 250 2-conductor base module with integrated end plate grey 769-504 blue 769-504/000-006 green-yellow 769-504/000-016 250 250 250 1-conductor center module grey 769-502 blue 769-502/000-006 green-yellow 769-502/000-016 250 250 250 2-conductor center module grey 769-505 blue 769-505/000-006 green-yellow 769-505/000-016 250 250 250 1-conductor end module grey 769-503 blue 769-503/000-006 green-yellow 769-503/000-016 250 250 250 2-conductor end module grey 769-506 blue 769-506/000-006 green-yellow 769-506/000-016 250 250 250 Mounting tool Mounting tool 298-646 ➊ ** Current-carrying capacity curves and accessories see Full Line Catalog W4 Volume 1, Section 9 Item No. 500 V = rated voltage 6 kV = rated surge voltage 3 = pollution degree 40 1 298-6 41 1 ° Color Item No. VOLUME 1 0.08 – 4 mm2 AWG 28 – 12 500 V/6 kV/3 ➊ IN 32 A** Module width 5 mm / 0.197 in L 8 – 9 mm / 0.33 in Pack.-unit pcs 1-conductor base module, 45° angled, with integrated end plate grey 769-512 blue 769-512/000-006 green-yellow 769-512/000-016 250 250 250 Self-assembly of individual female plugs Female plugs with ground (earth) modules (green-yellow) Using modular female plugs from the X-COM-SYSTEM, female plugs can be customized for applications requiring varying numbers of poles (e.g. when designing prototypes). According to the "norm", connectors should be inserted and disengaged off load. This is why pre-mating the ground (earth) contact is required when connectors need to be connected or disengaged "under load". Modules and pole numbers This is guaranteed using a ground (earth) module in the middle of female plugs equipped with up to 7 poles or two ground (earth) modules at both ends of 8 - 15 pole female plugs to ensure a preceding ground (earth) connection. A self assembled female plug consists of a base module with integrated end plate, up to 13 center modules (corresponding to a 15pole female plug = maximum number of poles) as well as an end module. 1-conductor end module, 45° angled grey 769-513 blue 769-513/000-006 green-yellow 769-513/000-016 Mounting In order to guarantee that the individual modules are properly snapped into each other without damaging the locking latches, it is necessary to use the appropriate mounting tool. 250 250 250 Example of a 5-pole 1-conductor female plug 1-conductor end module, 45° angled grey 769-515 blue 769-515/000-006 green-yellow 769-515/000-016 250 250 250 Base module with integrated end plate 769-501/000-016 Center module 769-502/000-006 Mounting tool 298-642 9 1 Center modules 769-502 End module 769-503 41 Compact Connector for Flexible Conductors Series 222 2 x 0.08 – 2.5 mm2 ”s+f-st“ AWG 28 – 12 4 mm2 ”f-st“ 600 V, 20 Ar 400 V/4 kV/2** IN 32 A L 9 – 10 mm / 0.37 in *r 5 x 0.08 – 2.5 mm2 ”s+f-st“ AWG 28 – 12 4 mm2 ”f-st“ 600 V, 20 Ar 400 V/4 kV/2** IN 32 A L 9 – 10 mm / 0.37 in * r ENEC Item No. Pack.-unit pcs Compact connector, 2-wire connector, with levers max. continuous service temperature 85 °C grey 222-412 Item No. Pack.-unit pcs Compact connector, 5-wire connector, with levers max. continuous service temperature 85 °C grey 222-415 400 (10 x 40) (_12 ,4 _) Compact connector It clamps up to 5 stripped flexible wires of 0.08 mm2/AWG 28 to 4 mm2/AWG 12 or solid or stranded wires up to 2.5 mm2/AWG 14, without tools. VOLUME 1 10 _> 20,5 (__ 13 __> 9,5 __) __ 1 < Item No. Mounting carrier orange Marker strips, plain 773-332 210-334 Pack.-unit pcs 50 (5 x 10) 1 card < _14,2_ > Item Pack.-unit No. pcs Push-wire connectors for junction boxes, 3-wire connector, color of housing transparent, color of cover red 773-173 500 (10 x 50) Item Pack.-unit No. pcs Push-wire connector for junction boxes, 3-wire connector, black, max. continuous service temperature 150 °C 773-514 1000 (10 x 100) < ___ _2 5,6 ___ _> _> 0,1_ __2 < VOLUME 1 Shield (Screen) Clamps Length 790- 791- 790-110 15 mm /0.59 in max. 790-108 – 790-112 25 mm /0.98 in max. 790-116 791-111, 791-117 790-114 45 mm /1.772 in 790-108 to 790-140 791-111 to 791-124 see Full Line Catalog W4 Volume 1, Section 12 44 Busbar Carriers 12 Shield termination Busbar Carrier Shield termination VOLUME 1 Busbar Carrier Item No. Pack.-unit pcs Busbar Carrier for busbars Cu 10 mm x 3 mm Item No. Busbar Carrier for busbars Cu 10 mm x 3 mm 790-300 790-301 Remove the busbar carrier using a screwdriver (blade width 5.5 mm/0.217 in) To remove the busbar, compress the spring using pliers > 10 < Dimensions (in mm) Pack.-unit pcs 45 Item No. Shield termination including cable tie for shield diameter 5 mm /0.197 in to 10 mm /0.394 in 55 mm /2.17 in long 709-350 150 mm /5.9 in long 709-352 Pack.-unit pcs 100 (4 x 25) 100 (4 x 25) 14 WAGO Wire and Cable Marking . . . VOLUME 1 Wire marking The following marker cards are available: Marker cards for plotter marking ... ... or marker cards on roll for thermal transfer printing Remove the thermal transfer printed marker card from the roll … WAGO smart Marking software (see also Full Line Catalog W4 Volume 1, Section 14) Thermal transfer printer TP 298 Slide the plotted marker card into the marking sleeve receptacle. Changing the marking is also possible after the wire has been connected Compress the sleeve and slide it onto the wire to be marked Plotter IP 350 46 14 VOLUME 1 . . . Description and Handling … and slide it through the marker receptacle up to the end of the sleeve … … then remove the rest of the card by twisting it off Fix the marking sleeve 211-129 using cable ties to individual wire or cable Cable marking Self-laminating labels are available on A4 sheets for the laser printer (plotter) … … or are supplied on roll for the thermal transfer printer Remove the printed label from the sheet or roll … … and wrap it around the wire or cable 47 The transparent laminate protects the marking VOLUME 1 14 Wire Marking for Wire Sizes from AWG 24 to 4 (0.25 mm2 to 16 mm2) Wire marking sleeve, halogen-free for marker card, for wires ranging from AWG 24 to 4 (0.25mm2 to 16 mm2) (to be fitted before wire connection) Item No. Wire marking sleeve, halogen-free for marker card, for wires ranging from AWG 24 to 4 (0.25mm2 to 16 mm2) (to be fitted before wire connection) Pack.-unit pcs Item No. Pack.-unit pcs Marking sleeve 12 mm long /0.472 in Marking sleeve 23 mm long /0.9 in for wire Ø 1.6 – 3.2 mm or AWG 24 – 16 (0.25 mm2 – 1.5 mm2) 211-112 2000 for wire Ø 1.6 – 3.2 mm or AWG 24 – 16 (0.25 mm2 – 1.5 mm2) 211-122 2000 2000 for wire Ø 2.2 – 4.5 mm or AWG 20 – 12 (0.5 mm2 – 4 mm2) 211-123 2000 1000 for wire Ø 3.7 – 5.9 mm or AWG 14 – 10 (2.5 mm2 – 6 mm2) 211-124 1000 1000 for wire Ø 4.8 – 7.5 mm or AWG 10 – 4 (6 mm2 – 16 mm2) 211-125 1000 for wire Ø 2.2 – 4.5 mm or AWG 20 – 12 (0.5 mm2 – 4 mm2) 211-113 for wire Ø 3.7 – 5.9 mm or AWG 14 – 10 (2.5 mm2 – 6 mm2) 211-114 for wire Ø 4.8 – 7.5 mm or AWG 10 – 4 (6 mm2 – 16 mm2) 211-115 Article specific accessories Article specific accessories Marker card, for thermal transfer printer, 12 mm long /0.472 in, white 211-111 1 x 3000 Marker card, for thermal transfer printer, 23 mm long /0.9 in, white 211-121 1 x 3000 Marker card, for plotter, 12 mm long /0.472 in, white 211-110 18 x 57 Marker card, for plotter, 23 mm long /0.9 in, white 211-120 30 x Plotter receptacle, for marker card Plotter receptacle, for marker card 258-370 Accessories 1 34 258-370 1 258-350 1 (see also Full Line Catalog W4 Volume 1, Section 14) Thermal transfer printer, TP 298 Resolution 300 dpi 258-298 Thermal transfer printer, TP 297 Resolution 203 dpi 258-297 Plotter IP 350 1 WAGO plotter pen, line width 0.35 mm 1 1 WAGO disposable pen, line width 0.35 mm Ink ribbon, 90 mm /3.54 in width, 300 m roll 258-150 258-228 1 258-328 48 1 14 Cable marking sleeve, halogen-free for marker card, for wire sizes from AWG 8 (10 mm2) for cable tie (can also be fitted subsequently) Self-laminating labels on DIN A4 sheets or roll for cable marking. Item No. Marking sleeve, for cable tie 23 mm long /0.9 in Item No. Labels on DIN A4 sheets for laser printer Cable diameter approx. 3 mm/0.118 in – 14 mm/0.55 in Pack.-unit pcs for wires from AWG 8 (10 mm2) 211-129 VOLUME 1 Cable Marking 1000 Pack.-unit pcs Marker surface ”S” = 9 mm x ”B” = 17 mm ”L” = 35 mm for max. cable Ø 8 mm /0.315 in 70 labels per sheet 211-150 20 Marker surface ”S” = 13 mm x ”B” = 21 mm ”L” = 56 mm for max. cable Ø 14 mm /0.55 in 32 labels per sheet 211-151 25 Labels on roll for thermal transfer printer Article specific accessories Marker card, for thermal transfer printer, 23 mm /0.9 in long, white 211-121 1 x 3000 Marker card, for plotter, 23 mm /0.9 in long, white 211-120 30 x 34 Plotter receptacle, for marker card 258-370 Marker surface ”S” = 8 mm x ”B” = 18 mm ”L” = 35 mm for max. cable Ø 9 mm /0.354 in 9,000 labels per roll 211-155 1 Marker surface ”S” = 13 mm x ”B” = 23 mm ”L” = 51 mm for max. cable Ø 12 mm /0.472 in 5,000 labels per roll 211-156 1 1 Cable tie, (2,5 x 100) mm 807-0090/0101-0100 (see also Full Line Catalog W4 Volume 1, Section 14) Thermal transfer printer, TP 298 Resolution 300 dpi 258-298 Dimensions of self-laminating label (in mm) Plotter IP 350 258-350 1 1 Thermal transfer printer, TP 297 Resolution 203 dpi 258-297 1 Ink ribbon 90 mm /3.54 in width, 300 m roll 258-150 1 (_ B _) Accessories 25 WAGO plotter pen, line width 0.35 mm (_ S _) 258-228 1 WAGO disposable pen, line width 0.35 mm 258-328 49 1 max. Ø = (L–S)/3,14 min. Ø = S/3,14 VOLUME 1 14 Marker carriers for WCB Combi Marking System Marker carriers for 4 WCB markers WCB Combi marking system 20 markers with identical numbers/letters each tag Item No. Marker carriers for 4 WCB markers 2009-184 Pack.-unit pcs suitable for terminal blocks with WMB marking receptacle Marking per tag plain 1 (20x) 2 (20x) 3 (20x) 4 (20x) 5 (20x) 6 (20x) 7 (20x) 8 (20x) 9 (20x) 0 (20x) Item No. 249-200 249-201 249-202 249-203 249-204 249-205 249-206 249-207 249-208 249-209 249-210 1 . . . 0 (2x) 249-239 1. (20x) 2. (20x) 3. (20x) 4. (20x) 5. (20x) 6. (20x) 7. (20x) 8. (20x) 9. (20x) 0. (20x) 249-241 249-242 249-243 249-244 249-245 249-246 249-247 249-248 249-249 249-250 + (20x) — (20x) 249-237 249-238 Marking per tag A (20x) B (20x) C (20x) D (20x) E (20x) F (20x) G (20x) H (20x) I (20x) J (20x) K (20x) L (20x) M (20x) N (20x) O (20x) P (20x) Q (20x) R (20x) S (20x) T (20x) U (20x) V (20x) W (20x) X (20x) Y (20x) Z (20x) Item No. 249-211 249-212 249-213 249-214 249-215 249-216 249-217 249-218 249-219 249-220 249-221 249-222 249-223 249-224 249-225 249-226 249-227 249-228 249-229 249-230 249-231 249-232 249-233 249-234 249-235 249-236 Insert WCB Combi marker into marker carrier Pieces per packing unit: 10 tags Twist the marker carrier off the carrier holder . . . . . . and insert the marker carrier into the WMB marking receptacle of the terminal block 50 VOLUME 1 14 51 Contents Terminal strips for PCBs – Reflow Pin spacing 2.5 mm/0.098 in Pin spacing 2.54 mm/0.1 in Series 218 Series 218 54 54 Terminal strips for PCBs – Reflow Pin spacing 5 mm/0.197 in Pin spacing 2.5 mm/0.098 in Pin spacing 3.5 mm/0.138 in Series 236 Series 250 Series 250 55 55 55 Terminal strips with “internal commoning” Pin spacings 5 mm/0.197 in, 7.5 mm/0.295 in; 2.5 mm2/AWG 14 Series 804 57 2-conductor female connector strips with CAGE CLAMP®S connection 1.5 mm2/AWG 16 Series 806 58 2-conductor modular terminal blocks and terminal strips with CAGE CLAMP®S connection Pin spacing 75 mm/0.295 in; Series 746 6 (10) mm2/AWG 10 59 Modular terminal blocks and terminal strips without jumper slot with CAGE CLAMP® connection Pin spacing 5 mm/0.197 in; 4 mm2/AWG 12 Series 745 Pin spacing 7. 5 mm/0.295 in; 4 mm2/AWG 12 Series 745 Pin spacing 10 mm/0.394 in; 4 mm2/AWG 12 Series 745 Pin spacing 12.5 mm/0.492 in; 4 mm2/AWG 12 Series 745 60 60 – 61 60 – 61 60 – 61 Volume 2 Modular terminal blocks with spacers 6 mm2 Pin spacing 7.5 mm/0.295 in, 10 mm/0.394 in Terminal strips with spacers 6 mm2/AWG 10 Pin spacing 10 mm/0.394 in, 12.5 mm/0.492 in, 15 mm/0.591 in Series 745 62 Series 745 63 MULTI CONNECTION SYSTEM Male and female connectors with CAGE CLAMP® connection Pin spacing 2.5 mm/0.098 in Series 733 64 Headers with solder pins — Reflow Pin spacing 3.5 mm/0.138 in Series 734 66 – 67 Headers with solder pins — Reflow Pin spacing 5 mm/0.197 in Series 231 68 – 69 Extension of pole number - connectors, Pin spacing 3.5 mm/0.138 in Series 734 70 52 Combi strip with CAGE CLAMP® connection Pin spacing 3.5 mm/0.138 in Series 734 71 IP 20 protection using cover for male connectors Pin spacings 3.5 mm/0.138 in, 3.81 mm/0.15 in Series 734 72 Operating tools MINI MIDI Series 734 Series 231 73 73 Female connectors with solder pins Pin spacing 3.5 mm/0.138 in Pin spacing 3.81 mm/0.15 in Series 734 Series 734 74 75 Angled female connectors with CAGE CLAMP® connection Pin spacing 5 mm/0.197 in Series 722 76 Extension of pole number Pluggable connectors with right angle solder pins, Pin spacing 5 mm/0.197 in Series 231 Pluggable connectors with threaded/screw flanges, Pin spacing 5.08 mm/0.2 in Series 231 77 79 Comb type jumper bars Pin spacing 5 mm/0.197 in Series 231 78 Strain relief plates for 2-conductor female connectors Series 734 with CAGE CLAMP® connection 80 Headers with solder pins Pin spacing 7.62 mm/0.3 in Series 831 ® Headers with CAGE CLAMP connection Pin spacing 7.62 mm/0.3 in Series 831 ® Female connectors with CAGE CLAMP connection and locking device Pin spacing 7.62 mm/0.3 in Series 831 Operating tools Screw driver Series 210 53 81 82 83 84 PCB Terminal Strips for THR Soldering Terminal Strips with Locking Slide 0.5 mm2/AWG 20 Pin spacings 2.5 mm and 2.54 mm; Series 218 Pin spacing 2.5 mm / 0.098 in 0.08 – 0.5 mm2 ➊ AWG 28 – 20 ➊ 160 V/2.5 kV/2 150 V, 4 A U 150 V, 4 A 2 IN 6 A l 5 – 6 mm / 0.22 in * U2 Pin spacing 2.54 mm / 0.1 in 0.08 – 0.5 mm2 ➊ AWG 28 – 20 ➊ 160 V/2.5 kV/2 150 V, 4 A U 150 V, 4 A 2 IN 6 A l 5 – 6 mm / 0.22 in Terminal strips in tape on reel Pin pacing 2.5 mm Pin pacing 2.54 mm * U2 No. of Item Pack. unit poles No. pcs 1-conductor terminal strips with locking slide, 2 solder pins/pole in line, black, locking slide, white 2 218-102/000-604 1000 (10 x 100) 3 218-103/000-604 1000 (10 x 100) 4 218-104/000-604 500 (5 x 100) 5 218-105/000-604 500 (5 x 100) 6 218-106/000-604 280 (4 x 70) 7 218-107/000-604 240 (4 x 60) Other numbers of poles and pin spacings on request No. of Item Pack. unit poles No. pcs 1-conductor terminal strips with locking slide, 2 solder pins/pole in line, black, locking slide, white 2 218-502/000-604 1000 (10 x 100) 3 218-503/000-604 1000 (10 x 100) 4 218-504/000-604 500 (5 x 100) 5 218-505/000-604 500 (5 x 100) 6 218-506/000-604 280 (4 x 70) 7 218-507/000-604 240 (4 x 60) Other numbers of poles and pin spacings on request Accessories Test pin, Ø 1 mm/0.039 in 735-500 1 Test wire for sold. onto test plug Test pin, Ø 1 mm/0.039 in 735-500 1 Test wire for sold. onto test plug Screwdriver with partially insulated shaft, 2.5 x 0.4 mm /0.098 in x 0.016 in 210-619 1 Screwdriver with partially insulated shaft, 2.5 x 0.4 mm /0.098 in x 0.016 in 210-619 1 No. of Item Width of reel poles No. (W) 1-conductor terminal strips with locking slide, 2 solder pins/pole in line, black, locking slide, white Terminal strips with additional suction pad in a tape on reel according to IEC 60286-3, Reel diameter 330 mm /13 in Pin spacing 2.5 mm /0.098 in Pack. unit 250 pcs (mm) 2 218-102/000-604/997-403 16 3 218-103/000-604/997-405 32 4 218-104/000-604/997-405 32 5 218-105/000-604/997-405 32 6 218-106/000-604/997-405 32 7 218-107/000-604/997-405 32 Pin spacing 2.54 mm /0.1 in Pack. unit 250 pcs (mm) 2 218-502/000-604/997-403 16 3 218-503/000-604/997-405 32 4 218-504/000-604/997-405 32 5 218-505/000-604/997-405 32 6 218-506/000-604/997-405 32 7 218-507/000-604/997-405 32 Terminal strips with white printing upon request Dimensions (in mm) 1,05 > 12,8 < 1,05 > 2,8 2,5 > 2,8 VOLUME 2 1 ➋ Diameter of drilled hole: 1.1+0.1 mm L = (No. of poles x pin spacing) + 1.5 mm ➋ Diameter of drilled hole: 1.1+0.1 mm L = (No. of poles x pin spacing) + 1.5 mm * Further approvals with corresponding ratings can be found at www.wago.com 54 ➊ in adjacent positions 0.75 mm2/AWG 18 ➋ A groove at the back of the terminal block differentiates between the two pin spacings Pin spacing 5/ 0.197 in 0.08 – 2.5 mm2 AWG 28 – 12 ** Pin spacing 2.5 mm / 0.098 in Pin spacing 3.5 mm / 0.138 in 0.4 – 0.8 mm Ø “s” ➋ AWG 26 – 20 “sol.” 0.5 –1.5 mm2 “s+f-st“ AWG 20 – 16 “sol.“ 200 V/4 kV/3, IN 16 A 300 V, 15 A U 320 V/4 kV/2, IN 16 A L 5 – 6 mm / 0.22 in 250 V/2.5 kV/2 300 V, 5 A U IN 2 A l 8.5 – 9.5 mm / 0.35 in *U *U No. of Item Pack. unit poles No. pcs Terminal strips, reflow soldering technology, 2 solder pins / pole, black 236-402/334-604 236-403/334-604 236-404/334-604 236-405/334-604 236-406/334-604 2 3 4 5 6 420 (4 x 105) 280 (4 x 70) 220 (4 x 55) 160 (4 x 40) 140 (4 x 35) Other numbers of poles and pin spacings on request 400 V/4 kV/2 300 V, 5 A U IN 2 A l 8.5 – 9.5 mm / 0.35 in *U No. of Item Pack. unit poles No. pcs Terminal strips with push-button, reflow soldering technology, 1 solder pin/pole staggered, black, with test slot for test pin up to 1.3 mm Ø 2 250-402/350-604 720 (4 x180) 3 250-403/350-604 520 (4 x130) 4 250-404/350-604 400 (4 x100) 5 250-405/350-604 340 (4 x 85) 6 250-406/350-604 280 (4 x 70) 7 250-407/350-604 240 (4 x 60) 8 250-408/350-604 220 (4 x 55) ➋ 0.2 mm2 – 0.5 mm2 “f-st“ Other numbers of poles and pin spacings on request No. of Item Pack. unit poles No. pcs Terminal strips with push-button, reflow soldering technology, 1 solder pin/pole staggered, black, with test slot for test pin up to 1.3 mm Ø 2 250-202/350-604 560 (4 x 140) 3 250-203/350-604 400 (4 x 100) 4 250-204/350-604 300 (4 x 75) 5 250-205/350-604 240 (4 x 60) 6 250-206/350-604 200 (4 x 50) 7 250-207/350-604 180 (4 x 45) 8 250-208/350-604 160 (4 x 40) Other numbers of poles and pin spacings on request Accessories Operating tools ➊, Plastic 236-332 Metal 236-335 Test pin, Ø 1 mm/0.039 in 735-500 1 Test wire for sold. onto test plug 1 1 Test pin, Ø 1 mm/0.039 in 735-500 1 Test wire for sold. onto test plug Double savings are now available with WAGO PCB terminal blocks: as always, the time-saving CAGE CLAMP® and push-wire connections and now additional savings from their suitability for the THR solder process. This is achieved by changing the length of the solder pin which is adapted to the reflow process and by the use of high temperature resistant plastic for the insulating housing. The new terminal blocks are simply pushed into the solder paste filled PCB holes and then soldered along with the SMT components. The previous wave soldering process is no longer necessary. The result is a perfect connection both from the mechanical and the electrical point of view. Packings for pick and place applications on request Dimensions (in mm) > 3,6 > 3,6 0,4 < 2,3 < > 3,5 < 0,75 ___> < ___ first solder pin 0,7 > 3,5 < > 5 < L = (No. of poles x pin spacing) + 2.3 mm Diameter of metal plated hole 1.1+0,1 mm optimised for PCB width of up to 2 mm ** AWG 12: THHN, THWN 2,5 < solder pin < 5 < 1,3 __> < 0,4 (_ 2,3 < 5 ➊ for factory wiring L = (No. of poles x pin spacing) + 1.5 mm Diameter of metal plated hole 1.0+0,1 mm optimised for PCB width of up to 2 mm 55 1,75 L = (No. of poles x pin spacing) + 1.5 mm ___> < Diameter of metal plated hole 1.0+0,1 mm optimised for PCB width of up to 2 mm 1 VOLUME 2 ° PCB Terminal Strips for THR Soldering Series 236 and Series 250 Reflow Soldering The THR preparation and solder process Design and application recommendations for the THR solder process Metal plated PCB bore hole ( di ) In the manufacture of electronic products, Surface Mount Technology has led to a rapid rise in productivity. SMD positioning pattern By using high temperature resistant plastic and an optimized pin design, the WAGO Through Hole Reflow PCB terminal blocks meet the requirement for SMT process capability while maintaining the necessary stability. Application of solder paste > THR product series dA(mm) 2.5 2.5 2.2 2.0 H(mm) < ___> < 2,5 > 5 3,3 < __> < 0,8 __> < first solder pin rear side Diameter of drilled hole: 1+0.1 mm L = (No. of poles x pin spacing) + 1.5 mm Item No. Pack. unit pcs Marker cards, 100 self-adhesive strips per card Print - Pin spacing 5 mm /0.197 in 1–12 (300 x) 210-331/0500-0103 1 card 13–24 (300 x) 210-331/0500-0104 1 card Print - Pin spacing 7.5 mm /0.295 in 1–16 (100 x) 210-331/0750-0202 1 card Direct printing on request Test pin, Ø 1 mm/0.039 in 735-500 1 Test wire for sold. onto test plug Screwdriver with partially insulated shaft, 3.5 x 0.4 mm /0.137 in x 0.016 in 210-620 1 Pin spacing 10 mm (with spacer) on request > 4 < ___> < __> < 2,5 __> < > 5 3,3 < (_7,5 _) 5 < first solder pin rear side Diameter of drilled hole: 1+0.1 mm L = (No. of poles – 1) x pin spacing + 5 mm + 1.5 mm * Marks and approval data can be found on the Internet at www.wago.com. 57 1 Internal commoning For example, the requirement of not routing the ground (earth) conductors over the board is met by WAGO through the “internal commoning” of 804 Series terminal strips. This way, custom terminal strips can be commoned to each other and marked at the factory. 2-Conductor Female Connector Strips 1.5 mm2/AWG 16 Pin Spacing 5 mm/0.197 in, Series 806 Pin spacing 52 mm / 0.197 in Pin spacing 52 mm / 0.197 in 250 V/ 2.5 kV/3 ➊ IN 10 A 250 V/ 2.5 kV/3 ➊ IN 10 A 2 x 0.2 – 1.5 mm 2 x AWG 24 – 16 300 V, 10 A U l 9 – 10 mm / 0.37 in 2 x 0.2 – 1.5 mm ➊ 2 x AWG 24 – 16 300 V, 10 A U 250 V = rated voltage 2.5 kV = rated surge voltage 3 = pollution degree (see also Full Line Catalog W4 Volume 2, Section 12) l 9 – 10 mm / 0.37 in *U *U Connection of solid conductors: insert stripped wire up to the stop Connection/disconnection of fine-stranded conductors: open clamping unit using a screwdriver and insert stripped wire up to the stop No. of Item poles No. Female connector strips, grey for solder pin strip 2 806-102 3 806-103 4 806-104 5 806-105 6 806-106 7 806-107 8 806-108 9 806-109 10 806-110 11 806-111 12 806-112 No. of Item poles No. Female connector strips with removal aid, grey for solder pin strip 2 806-202 3 806-203 4 806-204 5 806-205 6 806-206 7 806-207 8 806-208 9 806-209 10 806-210 11 806-211 12 806-212 For other lengths, please contact factory For other lengths, please contact factory Additional item numbers for colored terminal strips blue . . . /000-006 orange . . . /000-012 Additional item numbers for colored terminal strips blue . . . /000-006 orange . . . /000-012 Connecting the conductor directly into the connector . . . . . . or pre-assembled Accessories connector pin Ø 1.3 mm solder pin Ø 1 mm 2 to 12 poles 806-902 to 806-912 Marker card, Solder pin strip, connector pin Ø 1.3 mm solder pin Ø 1 mm 2 to 12 poles 806-902 to 806-912 Marker card, with self-adhesive marker strips with self-adhesive marker strips Diameter of drilled hole: 1.3 mm L = No. of poles x pin spacing + 1.5 mm 1,5 < > 5 • 2,8 < 1 card 2,75 ___> Terminal strip insulation housings mixed in different colors on request Ø 1,3 > 5 • 2,8 < _> 3,4 < Dimensions (in mm) 1 – 16 (160 x) 210-332/0500-0202 Direct printing on request _> 2,7 < 1 – 16 (160 x) 210-332/0500-0202 1 card Direct printing on request 2,75 ___> Removing the terminal blocks to place the board Solder pin strip, VOLUME 2 1 A = (No. of poles - 1) x pin spacing B = (No. of poles - 1) x pin spacing + 4.8 mm * Further approvals with corresponding ratings can be found at www.wago.com 58 Modular Terminal Blocks and Terminal Strips 6 mm2/AWG 10 ! Pin Spacing 7.5 mm/0.295 in; Series 746 VOLUME 2 Pin spacing 7.5 mm / 0.295 in 2 x 0.5 – 6 (10) mm2 ➊ 2 x AWG 20 – 8 400 V/6 kV/3 600 V, 50 A U IN 41 A L 13 – 15 mm / 0.55 in *U ➊ Push-in conductor sizes:2 0,5 mm22 – 10 mm2 „e + f“; AWG 16 – 8 (1.5 mm – 10 mm ) “s“ and AWG 16 – 10 (1.5 mm2 – 6 mm2) “insulated ferrules, 12 mm/0.472 in“ Marking No. of poles No. of Item poles No. 2-conductor terminal strips, grey, 2 x 2 pins / pole staggered 2 746-2302 3 746-2303 4 746-2304 5 746-2305 6 746-2306 7 746-2307 8 746-2308 9 746-2309 10 746-2310 12 746-2312 Item No. Connecting flexible wires using a screwdriver 5.5 mm For other lengths, please contact factory Additional item numbers for colored terminal strips light grey . . . /000-009 blue . . . /000-006 green-yellow . . . /000-016 light green . . . /000-017 Accessories (Marking see Full Line Catalog W4 Volume 2, Section 11) Screwdriver with partially insulated shaft (5.5 x 0.8) mm 210-621 Test plug Solid wires and fine-stranded wires with ferrules can be simply pushed in Testing with test plug Ø 2 mm/0.079 in with cable 500 mm/1’7.7’’ 210-136 2 mm/0.079 in Ø, red 210-137 2.3 mm/0.091 in Ø, yell. Dimensions (in mm) Diameter of drilled hole: 2.2 +0.1 mm L = No. of poles x pin spacing + 2.7 mm 1,5 mm + 4 x 7,5 mm = 31,5 mm 3,85 > < Terminal blocks of different colors upon request 1,2 > 7,5 < 2,8 __> < 59 1,6 __> < > 3< >4,4 1,6 __> < > 3< 1,5 1,2 __> < > 7,5 5 < > > 4 0,8 __> > 5 < > 4 1,5 > VOLUME 2 Modular Terminal Blocks and Terminal Strips without Jumper Slot 4 mm2/AWG 12 Pin Spacing 5 mm/0.197 in; Series 745 > 1 (_10_) 6,2 < Diameter of drilled hole: 1.5 +0.1 mm L = No. of poles x pin spacing + 1.5 mm Pin spacing 7.5 mm / 0.295 in 0.08 – 4 mm2 AWG 28 – 12 500 V/6 kV/3 300 V, 20 A Y IN 32 A L 8 – 9 mm / 0.33 in *Y Pin spacing 10 mm / 0.394 in 0.08 – 4 mm2 AWG 28 – 12 630 V/8 kV/3 300 V, 20 A Y IN 32 A L 8 – 9 mm / 0.33 in *Y No. of Item poles No. Terminal strips without jumper slot, grey, 2 solder pins /pole No. of Item poles No. Terminal strips without jumper slot, grey, 2 solder pins /pole 745-3202 745-3203 745-3204 745-3205 745-3206 745-3207 745-3208 745-3209 745-3210 745-3212 2 3 4 5 6 7 8 9 10 12 For assemblies in other lengths and colors, please contact factory. 630 V/8 kV/3 600 V, 20 A Y IN 32 A L 8 – 9 mm / 0.33 in *Y No. of Item poles No. Terminal strips without jumper slot, grey, 2 solder pins /pole 745-3152 745-3153 745-3154 745-3155 745-3156 745-3157 745-3158 745-3159 745-3160 745-3162 2 3 4 5 6 7 8 9 10 12 Pin spacing 12.5 mm / 0.492 in 0.08 – 4 mm2 AWG 28 – 12 745-3252 745-3253 745-3254 745-3255 745-3256 745-3257 745-3258 745-3259 745-3260 745-3262 2 3 4 5 6 7 8 9 10 12 For assemblies in other lengths and colors, please contact factory. Additional item Nos. for colored terminal strips and end plates blue . . . /. . . -006 light grey . . . /. . . -009 green-yellow . . . /. . . -016 light green . . . /. . . -017 For assemblies in other lengths and colors, please contact factory. Ordering examples Terminal strip, pin spacing 5 mm /0.197 in 8 poles, light grey: 745-3108/000-009 Terminal strip pin spacing 12 mm /0.492 in 12 poles, blue: 745-3262/000-006 Suitable for EEx i applications (only suitable for pin spacings 7.5 mm /0.295 in; 10 mm /0.394 in and 12.5 mm /0.492 in) Dimensions (in mm) (Mounting shall provide flexibility for the PCB.) Diameter of drilled hole: 1.5 +0.1 mm L = (No. of poles – 1) x pin spacing + 5 mm + 1.5 mm 0,8 __> (_10_) 6,2 < Diameter of drilled hole: 1.5 +0.1 mm L = (No. of poles – 1) x pin spacing + 5 mm + 1.5 mm 61 2,8 > 12,5 < > > 4 2,8 > 10 < > 4 > 4 > (_10_) 6,2 < > 0,8 __> > 2,8 > 7,5 ( ) < (_12,5_)(_8_) Diameter of drilled hole: 1.8 +0.1 mm 1 > < > 7,5 < > 4,5 Higher rated voltages are possible using terminal strips with spacers so that. 600 V to UL 1059 can be achieved without limitation at only 12.5 mm / 0.492 in pin spacing. > 4,5 VOLUEM 2 1 > 10 < (_12,5_)(_8_) Diameter of drilled hole: 1.8 +0.1 mm * Further approvals with corresponding ratings can be found at www.wago.com 62 1 ° Terminal Strips 6 mm2/AWG 10 with Spacers Pin Spacings 10 mm/0.394 in, 12.5 mm/0.492 in and 15 mm/0.591 in; Series 745 630 V/8 kV/3 300 V, 10 A ➊ Y IN 32 A L 11 – 12 mm / 0.45 in *Y Pin spacing 12.5 mm / 0.492 in 0.2 – 6 mm2 AWG 24 – 10 Pin spacing 15 mm / 0.591 in 0.2 – 6 mm2 AWG 24 – 10 800 V/8 kV/3 600 V, 30 A Y IN 32 A L 11 – 12 mm / 0.45 in 1000 V/10 kV/3 600 V, 30 A Y IN 32 A L 11 – 12 mm / 0.45 in *Y No. of Item Pack.-unit poles No. pcs Terminal strips without fixing flanges, grey, with spacers 2 solder pins /pole 745-1352 745-1353 745-1354 745-1355 745-1356 745-1357 745-1358 745-1359 745-1360 745-1362 2 3 4 5 6 7 8 9 10 12 104 72 48 40 32 24 24 16 16 16 *Y No. of Item Pack.-unit poles No. pcs Terminal strips without fixing flanges, grey, with spacers 2 solder pins /pole 745-1402 745-1403 745-1404 745-1405 745-1406 745-1407 745-1408 745-1409 745-1410 745-1412 2 3 4 5 6 7 8 9 10 12 Additional item no. for terminal strips with fixing flanges . . . /005-000 VOLUME 2 Pin spacing 10 mm / 0.394 in 0.2 – 6 mm2 AWG 24 – 10 No. of Item Pack.-unit poles No. pcs Terminal strips without fixing flanges, grey, with spacers 2 solder pins /pole 745-1452 745-1453 745-1454 745-1455 745-1456 745-1457 745-1458 745-1459 745-1460 745-1462 2 3 4 5 6 7 8 9 10 12 Additional item no. for terminal strips with fixing flanges . . . /005-000 Additional item no. for terminal strips with fixing flanges . . . /005-000 For assemblies in other lengths and colors, please contact factory. For assemblies in other lengths and colors, please contact factory. ➊ Using jumpers, the UL current is reduced to 10 A at pin spacing 10 mm For assemblies in other lengths and colors, please contact factory. Ordering examples Terminal strip, pin spacing 12.5 mm/0.492 in 8 poles, light grey: 745-1408/000-009 Terminal strip with fixing flanges, pin spacing 15 mm/0.591 in 12 poles, blue: 745-1462/005-006 Additional item nos. for colored terminal strips and end plates blue . . . /. . . -006 light grey . . . /. . . -009 green-yellow . . . /. . . -016 light green . . . /. . . -017 Suitable for Ex i applications Dimensions (in mm) (Mounting shall provide flexibility for the PCB.) 4,2 _) > 9,1 < (9,2) 1,4 __> < > 8,2 < > 10 9,2 < 4,15 9,1 < (9,2) 1,4 __> < > 8,2 < > 12,5 9,2 < 4,15 < 4,2 _) 9,1 < (9,2) > 3,55 > < > 10,2 0,9 1,6 __< 15 4,5 13 3,55 > 10,2 0,9 1,6 __< 12,5 4,5 1 > < 3,55 > 4,5 > 10,2 0,9 1,6 __< 10 < > 8,2 < 15 9,2 < Diameter of drilled hole: 1.8 +0.1 mm L = (No. of poles – 1) x pin spacing + 7.5 mm L1 = L + 1.6 mm ^ = without fixing flanges MULTI CONNECTION SYSTEM MICRO Male and Female Connectors, 100 % Protected against Mismating, ° Pin Spacing 2.5 mm / 0.098 in Pin spacing 2.5 mm/0.098 in, light grey 0.08 – 0.5 mm2 AWG 28 – 20 250 V/2.5 kV/2 250 V, 4 A U IN 4 A 150 V, 4 A 2 L 5 – 6 mm / 0.22 in * U 2 CCA K b : ; { [ 5 q ABS 733-202 733-203 733-204 733-205 733-206 733-207 733-208 733-210 733-212 2 3 4 5 6 7 8 10 12 Pin spacing 2.5 mm/0.098 in, light grey 0.08 – 0.5 mm2 AWG 28 – 20 250 V/2.5 kV/2 250 V, 4 A U IN 4 A 150 V, 4 A 2 L 5 – 6 mm / 0.22 in Pin spacing 2.5 mm/0.098 in, light grey 0.08 – 0.5 mm2 AWG 28 – 20 250 V/2.5 kV/2 250 V, 4 A U IN 4 A 150 V, 4 A 2 L 5 – 6 mm / 0.22 in * U 2 D CCA K b : ; { [ 5 q ABS No. of Item poles No. Male connectors with CAGE CLAMP ® connection, 100 % protected against mismating, light grey No. of Item poles No. Female connectors with CAGE CLAMP ® connection, 100 % protected against mismating, with coding fingers, light grey 733-102 733-103 733-104 733-105 733-106 733-107 733-108 733-110 733-112 2 3 4 5 6 7 8 10 12 No. of Item poles No. Female connectors with CAGE CLAMP ® connection and locking levers, 100 % protected against mismating, with coding fingers, light grey 733-102/037-000 733-103/037-000 733-104/037-000 733-105/037-000 733-106/037-000 733-107/037-000 733-108/037-000 733-110/037-000 733-112/037-000 2 3 4 5 6 7 8 10 12 Accessories Operating tool, see Full Line Catalog W4 Volume 2, Section 11 Coding key, snap-on type, light grey 733-330 Operating tool, see Full Line Catalog W4 Volume 2, Section 11 Operating tool, see Full Line Catalog W4 Volume 2, Section 11 Marker card, Marker card, Marker card, 100 self-adhesive strips per card 100 self-adhesive strips per card Marking 1 – 16 (400x) 210-331/0250-0202 For further printings Full Line Catalog W4 Volume 2, Section 11 For direct printing please contact factory Marking 1 – 16 (400x) 210-331/0250-0202 For further printings Full Line Catalog W4 Volume 2, Section 11 For direct printing please contact factory 100 self-adhesive strips per card Marking 1 – 16 (400x) 210-331/0250-0202 For further printings Full Line Catalog W4 Volume 2, Section 11 For direct printing please contact factory < 2,5 __> < 1,5 2,5 > (_ 0,6 > 2 2,5 __> 2,5 > > T (2T) 2,5 __> _> )_ 1,5 T = 2.5 mm L = (No. of poles + 1) x pin spacing > )___ Dimensions (in mm) > 3,9 < VOLUME 2 4 1,5 2,5 > (_ > 5,9 5,9 < L = No. of poles x pin spacing VOLUME 2 4 65 MULTI CONNECTION SYSTEM MINI Headers with Solder Pins, Reflow Soldering 100 % Protected against Mismating, Pin Spacing 3.5 mm/0.138 in 250 V/2.5 kV/2 IN 10 A 300 V, 10 A U *U Pin spacing 3.5 mm/0.138 in, black 250 V/2.5 kV/2 IN 10 A 300 V, 10 A U *U No. of Item poles No. Headers with solder pins, 100 % protected against mismating, black, straight solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in 734-132/105-604 734-133/105-604 734-134/105-604 734-135/105-604 734-136/105-604 734-138/105-604 734-140/105-604 734-142/105-604 2 3 4 5 6 8 10 12 No. of Item Width of poles No. reel (W) Headers with solder pins, 100 % protected against mismating, black, straight solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in Headers in tape on reel acc. to IEC 60286-3 Reel diameter 330 mm /13 in (mm) 2 734-132/105-604/997-405 32 3 734-133/105-604/997-405 32 4 734-134/105-604/997-405 32 5 734-135/105-604/997-405 32 6 734-136/105-604/997-407 56 8 734-138/105-604/997-407 56 10 734-140/105-604/997-407 56 12 734-142/105-604/997-407 56 200 pieces per reel For use in reflow soldering processes in convection ovens based on EN 61760-1 ● apply solder paste ● place components on PCB ● begin reflow soldering process Accessories (fit after soldering) Coding key, light grey, snap-on type 734-130 Diameter of the plated through hole: 1.4 + 0,1 mm – optimized for PCB thickness up to 2 mm 3,5 ___> < < _ 10,3 _>2,4 < 1x1 0,5 __> < 3,1 < > 4,35 < 2,8 __> Coding key, light grey, snap-on type 734-130 > 15 < Dimensions >< VOLUME 2 Pin spacing 3.5 mm/0.138 in, black L = (No. of poles – 1) x pin spacing + 5.9 mm * Further approvals with corresponding ratings can be found at www.wago.com Note: These connectors can only be mated and unmated at voltages below 42 V and in the “No load” condition. For mating and unmating at low power values, please request data. 5 66 MULTI CONNECTION SYSTEM MINI Headers with Solder Pins, Reflow Soldering 100 % Protected against Mismating, Pin spacing 3.5 mm/0.138 in 250 V/2.5 kV/2 IN 10 A 300 V, 10 A U *U Pin spacing 3.5 mm/0.138 in, black 250 V/2.5 kV/2 IN 10 A 300 V, 10 A U VOLUME 2 Pin spacing 3.5 mm/0.138 in, black 5 *U No. of Item poles No. Headers with solder pins, 100 % protected against mismating, black, right angle solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in Headers in tape on reel acc. to IEC 60286-3 Reel diameter 330 mm /13 in (mm) 2 734-162/105-604/997-405 32 3 734-163/105-604/997-405 32 4 734-164/105-604/997-405 32 5 734-165/105-604/997-405 32 6 734-166/105-604/997-407 56 8 734-168/105-604/997-407 56 10 734-170/105-604/997-407 56 12 734-172/105-604/997-407 56 734-162/105-604 734-163/105-604 734-164/105-604 734-165/105-604 734-166/105-604 734-168/105-604 734-170/105-604 734-172/105-604 2 3 4 5 6 8 10 12 No. of Item Width of poles No. reel (W) Headers with solder pins, 100 % protected against mismating, black, right angle solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in 280 pieces per reel For use in reflow soldering processes in convection ovens based on EN 61760-1 ● apply solder paste ● place components on PCB ● begin reflow soldering process Accessories (fit after soldering) Coding key, light grey, snap-on type 734-130 1x1 2,4 __> < >< 3,5 ___> > 13,4 < _ 4,35 < _ 2,8 3,1 __> < > < Diameter of the plated through hole: 1.4 + 0,1 mm – optimized for PCB thickness up to 2 mm Position with even numbers of poles > 16 < Dimensions Coding key, light grey, snap-on type 734-130 Position with odd numbers of poles L = (No. of poles – 1) x pin spacing + 5.9 mm 67 MULTI CONNECTION SYSTEM MIDI – Reflow Soldering Headers with Solder Pins, Pin Spacing 5 mm/0.197 in 250 V/4 kV/3 IN 12 A 300 V, 10 A U *U Pin spacing 5 mm/0.197 in, black 250 V/4 kV/3 IN 12 A 300 V, 10 A U *U No. of Item poles No. Headers with solder pins, black, straight solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in 231-132/001-000/105-604 231-133/001-000/105-604 231-134/001-000/105-604 231-135/001-000/105-604 231-136/001-000/105-604 231-138/001-000/105-604 231-140/001-000/105-604 231-142/001-000/105-604 2 3 4 5 6 8 10 12 No. of Item poles No. Headers with solder pins, black, straight solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in Width of reel (W) Headers in tape on reel acc. to IEC 60286-3 Reel diameter 330 mm /13 in (mm) 2 231-132/001-000/105-604/997-405 32 3 231-133/001-000/105-604/997-405 32 4 231-134/001-000/105-604/997-407 56 5 231-135/001-000/105-604/997-407 56 6 231-136/001-000/105-604/997-407 56 8 231-138/001-000/105-604/997-407 56 10 231-140/001-000/105-604/997-409 88 12 231-142/001-000/105-604/997-409 88 170 pieces per reel For use in reflow soldering processes in convection ovens based on EN 61760-1 ● apply solder paste ● place components on PCB ● begin reflow soldering process Accessories (fit after soldering) Coding key, snap-on type, light grey 231-129 Coding key, snap-on type, light grey 231-129 Separator, for formation of groups, light grey 231-500 Separator, for formation of groups, light grey 231-500 > 16,8 < > 8,4 < 3,8 > 3,8< 0,6 __> < Diameter of the plated through hole: 1.4 + 0,1 mm – optimized for PCB thickness up to 2 mm Dimensions 2,4 __> VOLUME 2 Pin spacing 5 mm/0.197 in, black > 5 < > 4,1< > 4,1< A = (No. of poles x pin spacing) + 3.2 mm * Further approvals with corresponding ratings can be found at www.wago.com Note: These connectors can only be mated and unmated at voltages below 42 V and in the “No load” condition. For mating and unmating at low power values, please request data. 7 68 MULTI CONNECTION SYSTEM MIDI – Reflow Soldering Headers with Solder Pins, Pin Spacing 5 mm/0.197 in 250 V/4 kV/3 IN 12 A Pin spacing 5 mm/0.197 in, black 300 V, 10 A U 250 V/4 kV/3 IN 12 A *U 300 V, 10 A U VOLUME 2 Pin spacing 5 mm/0.197 in, black 7 *U No. of Item poles No. Headers with solder pins, black, right angle solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in No. of Item poles No. Headers with solder pins, black, right angle solder pin 1 mm x 1 mm, length of solder pin 2.4 mm/0.094 in Headers in tape on reel acc. to IEC 60286-3 Reel diameter 330 mm /13 in (mm) 2 231-432/001-000/105-604/997-405 32 3 231-433/001-000/105-604/997-405 32 4 231-434/001-000/105-604/997-407 56 5 231-435/001-000/105-604/997-407 56 6 231-436/001-000/105-604/997-407 56 8 231-438/001-000/105-604/997-407 56 10 231-440/001-000/105-604/997-409 88 12 231-442/001-000/105-604/997-409 88 231-432/001-000/105-604 231-433/001-000/105-604 231-434/001-000/105-604 231-435/001-000/105-604 231-436/001-000/105-604 231-438/001-000/105-604 231-440/001-000/105-604 231-442/001-000/105-604 2 3 4 5 6 8 10 12 Width of reel (W) 330 pieces per reel For use in reflow soldering processes in convection ovens based on EN 61760-1 ● apply solder paste ● place components on PCB ● begin reflow soldering process Accessories (fit after soldering) Coding key, snap-on type, light grey 231-129 Separator, for formation of groups, light grey 231-500 Separator, for formation of groups, light grey 231-500 > 4,1 5 < > 4,1< 7,5 < 0,5 __> < Diameter of the plated through hole: 1.4 + 0,1 mm – optimized for PCB thickness up to 2 mm > 12,2 < Dimensions Coding key, snap-on type, light grey 231-129 > 6,5 < >5< A = (No. of poles x pin spacing) + 3.2 mm B = A + 4.8 mm; C = B + 7.2 mm 6,4 >5< 2,4 Position with even numbers of poles Position with odd numbers of poles > 16 < 69 MULTI CONNECTION SYSTEM MINI – Extension of Pole Number Connectors, 100 % Protected against Mismating Pin Spacing 3.5 mm see also Full Line Catalog W4 Volume 2, pages 5.4 – 5.9 VOLUME 2 5 No. of Item poles No. Headers with solder pins, right angle solder pin 1 mm x 1 mm 734-144 3,1 < > 1,5 No. of Item poles No. Femal connector with CAGE CLAMP ® connection and locking device, coding fingers 734-114/037-000 14 > 2 2,8 3,1 )___ > > > T (2T) 3,5 1,4 ___> __> )_ No. of Item poles No. Femal connector with CAGE CLAMP ® connection, coding fingers 14 > 4,35 < 1x1 < > 14 < > 3,8 4,35 < _ 3,5 ___> _ 1x1 > 4,35 < < 2,8 3,1 __> < > >< 2,8 __> 734-174 14 >< 14 3,5 > (_ 0,7 > * Approvals with corresponding ratings see www.wago.com ** AWG 14: THHN, THWN > 5,9 < ( 10,5 ) L 4 = (No. of poles –1) x pin spacing + 5.9 mm + 0.45 mm > 6,6 ( 10,3 ) 3,5 4,35 3,65 ___> < L = No. of poles – 1 x pin spacing + 1.5 mm * Approvals with corresponding ratings see www.wago.com L = No. of poles – 1 x pin spacing + 1.5 mm 74 < 10,5 > < 10,5 > < 10,5 > 1,8 > Dimensions (in mm) 80 self-adhesive strips per card Marking 1 – 16 (240 x) 210-332/0350-0202 17 – 32 (240 x) 210-332/0350-0204 other markings see Full Line Catalog W4 Volume 2, Section 11 For direct printing, please contact factory 3,8 __> VOLUME 2 Pin spacing 3.5 mm/0.138 in, light grey 1,8 > L = No. of poles – 1 x pin spacing + 1.5 mm < 10,5 > 3,8 __> 3,65 ___> < L = No. of poles – 1 x pin spacing + 1.5 mm 75 < 10,5 > 3,8 __> < 10,5 > 1,8 > < 4 < 2,5 __> < < 5 VOLUME 2 6 < 3,8 5 < 3 > < > 7,1 < > 6,5 < < 3,8 __> 3,55 ___> < > 6,5 < 3,8 __> < 2,9 > 5,1< > 4,5< > 8,4 < For mating and unmating at low power values, please request data. 1,8 __> < > 6,9 < (_10_) A = (No. of poles x pin spacing) + 3.2 mm 77 VOLUME 2 7 MULTI CONNECTION SYSTEM MIDI Comb type jumper bars Pin Spacings 5 mm / 0.197 in and 5.08 / 0.2 in Pin spacings 5 mm/0.197 in, grey 5.08 mm/0.2 in, grey Attention! Insert jumper bar according to direction symbols.  Symbol shows direction to operating slot  Symbol shows direction to conductor entry Item Pack.-unit No. pcs Comb type jumper bars, insulated for straight and angled male and female connectors of Series 231 with CAGE CLAMP® connection Suitable for pin spacings 5 mm /0.197 in and 5.08 mm/0.2 in Attention! Not suitable for 2-conductor female connectors with CAGE CLAMP®S connection 231-903 231-905 231-907 231-910 3-way 5-way 7-way 10-way Insert comb type jumper bars with maximum 5 contacts using operating tool. Comb type jumper bars with more than 7 contacts are pre-assembled by WAGO Accessories Operating tool, insulated, 3-way 5-way 280-433 280-435 1 1 Individual comb type jumper bars are created by breaking out jumper contacts Note: The maximum wire size is reduced to 1.5 mm2/ AWG 16 solid and stranded (“s” + “f-st”) 78 MULTI CONNECTION SYSTEM MIDI – Extension of Pole Number Connectors with Screw/ Threaded flanges Pin Spacing 5.08 mm / 0.2 in see also Full Line Catalog W4 Volume 2, pages 7.32 – 7.33 VOLUME 2 7 2,3 > 8,4 < > 5,08 3,8 > 2,3 > 5 < < 12 > > 6,1 < 300 V, 20/5 A U L 9 – 10 mm / 0.37 in < 12 > No. of Item poles No. Female connectors with CAGE CLAMP ® and screw flanges, with coding fingers, with two latches, orange 7 231-307/107-000 : : 10 231-310/107-000 12 231-312/107-000 14 231-314/107-000 : : 16 231-316/107-000 231-637/109-000 : 231-640/109-000 231-642/109-000 231-644/109-000 : 231-646/109-000 7 : 10 12 14 : 16 5,08 No. of Item poles No. Male connectors with CAGE CLAMP® and threaded flanges, orange > Pin spacing 5.08 mm/0.2 in, orange 2 0.2 – 2.5 mm AWG 24 – 12 > 10,6 < 2,3 __> < > 5 < 3,8 __> > 5 < 12 > > 6,1 < 5,08 8,4 < > No. of Item poles No. Headers with right angle solder pins and threaded flanges, orange, solder pin 1 mm x 1 mm 7 231-537/108-000 : : 10 231-540/108-000 12 231-542/108-000 14 231-544/108-000 : : 16 231-546/108-000 2,3 __> < > 5 < > > 6,1 < 3,8 4,2 < > 4,2 < * Recommended cable ties and cable binding tool from Tyton or Hellermann, not offered by WAGO 80 >3< 1 >< > 6 < MULTI CONNECTION SYSTEM MAXI Headers with Solder Pins, 100 % Protected against Mismating, Pin Spacing 7.62 mm / 0.3 in 500 V/6 kV/3 IN 41 A 300/600 V, 42/5 A U 300/600 V, 50/5 A 2 * U2 Pin spacing 7.62 mm/0.3 in, light grey 500 V/6 kV/3 IN 41 A 300/600 V, 42/5 A U 300/600 V, 50/5 A 2 VOLUME 2 Pin spacing 7.62 mm/0.3 in, light grey * U2 No. of Item poles No. Headers with straight solder pins, 100 % protected against mismating, light grey, 3 x solder pins 1 mm x 1.2 mm 831-3602 831-3603 831-3604 831-3605 831-3606 831-3607 831-3608 2 3 4 5 6 7 8 No. of Item poles No. Headers with right angle solder pins, 100 % protected against mismating, light grey, 3 x solder pins 1 mm x 1.2 mm 831-3622 831-3623 831-3624 831-3625 831-3626 831-3627 831-3628 2 3 4 5 6 7 8 Break or cut-off coding pin on the female connector . . . Note: On request, headers with straight solder pins are also available with protection against positioning error on the PCB . . . Fit the coding pin into the connector (break first) so that the pin engages > 5,25 < 1 >< > 7,62 6,52 < * Further approvals with corresponding ratings can be found at www.wago.com 81 5,08 < 1,2 _> < 5,08 ___> Diameter of drilled hole: 1.7 + 0.1mm L = (No. of poles - 1) x pin spacing + 10.5 mm > 4 (_12,8_) (_14,8_) Dimensions (in mm) Printed female connector on request Pin spacing 7.62 mm/0.3 in, light grey 0.5 – 6 (10) mm2 ➊ AWG 20 – 8 800 V/8 kV/3 IN 41 A 300/600 V, 42/5 A U 300/600 V, 50/5 A 2 * U2 ! Pin spacing 7.62 mm/0.3 in, light grey 0.5 – 6 (10) mm2 ➊ AWG 20 – 8 800 V/8 kV/3 IN 41 A 300/600 V, 42/5 A U 300/600 V, 50/5 A 2 * U2 ➊ can be 2connected:2 0.5 mm – 10 mm “s + f-st“; can be pushed in directly: 1.5 mm2 – 10 mm2 “s“ and 1.5 mm2 – 6 mm2 “insulated ferrule, 12 mm /0.472 in“ No. of Item poles No. Male connectors with CAGE CLAMP ®S connection, 100 % protected against mismating, with coding fingers, light grey 831-3202 831-3203 831-3204 831-3205 831-3206 831-3207 831-3208 2 3 4 5 6 7 8 No. of Item poles No. Male connectors with CAGE CLAMP®S connection, for DIN 35 rail mounting 100 % protected against mismating, with coding fingers, light grey 2 831-3202/007-000 3 831-3203/007-000 4 831-3204/007-000 5 831-3205/007-000 6 831-3206/007-000 7 831-3207/007-000 8 831-3208/007-000 The new WAGO MULTI CONNECTION SYSTEM MAXI can be used as “high-power” sub-assemblies on carrier rails or printed circuit boards in such applications like drive technology, converters or power supply units. Accessories Test plug, with cable 500 mm /1’7.7’’ Ø 2 mm/0.079 in, red 210-136 Test plug, with cable 500 mm /1’7.7’’ Ø 2 mm/0.079 in, red 210-136 Marker card, Marker card, Equipped with CAGE CLAMP® S connection up to AWG 10/ AWG 8 (6 mm2/10 mm2) ➊, it handles a rated current of 41 A and has a pin spacing of 7.62 mm /0.3 in, which makes it ideally suited for such applications. 80 self-adhesive strips per card Height of marker strip 5 mm /0.197 in Marking 1 – 16 (100 x) 210-334/0762-0202 For direct printing, please contact factory Marker strip, white, plain, on roll for center marking 11 mm /0.039 in wide 2009-110 50 m 300 m 2009-130 80 self-adhesive strips per card Height of marker strip 5 mm /0.197 in Marking 1 – 16 (100 x) 210-334/0762-0202 For direct printing, please contact factory Marker strip, white, plain, on roll for center marking 11 mm /0.039 in wide 2009-110 50 m 300 m 2009-130 DIN 35 carrier rail adapter, for snap-fit mounting to male connectors with CAGE CLAMP®S connection 831-137 Screwdriver with partially insulated shaft, (5.5 x 0.8) mm /(0.217 x 0.031) in 210-621 > 7,5 7,62 < 2 _> < > 7,5 7,62 < 2 _> < * Further approvals with corresponding ratings can be found at www.wago.com 82 Product features • 100 % protected against mismating • Coding without the loss of poles • Male and female connectors with CAGE CLAMP®S connection for all conductor types Additional benefit: Time-saving push-in wiring of fine-stranded wires with ferrules • Vibration proof - fast - maintenance free • Male and female connectors with separate test slot for test plugs Ø 2.3 mm/0.091 in • Pole marking using marker strips or direct printing > 5 < L = (No. of poles - 1) x pin spacing + 9.5 mm Dimensions (in mm) VOLUME 2 MULTI CONNECTION SYSTEM MAXI Male Connectors, 100 % Protected against Mismating, Pin Spacing 7.62 mm / 0.3 in MULTI CONNECTION SYSTEM MAXI Female Connectors, 100 % Protected against Mismating, Pin Spacing 7.62 mm / 0.3 in 800 V/8 kV/3 IN 41 A 300/600 V, 42/5 A U 300/600 V, 50/5 A 2 * U2 Pin spacing 7.62 mm/0.3 in, light grey 0.5 – 6 (10) mm2 ➊ AWG 20 – 8 800 V/8 kV/3 IN 41 A 300/600 V, 42/5 A U 300/600 V, 50/5 A 2 * U2 ➊ can be 2connected:2 0.5 mm – 10 mm “s + f-st“; can be pushed in directly: 1.5 mm2 – 10 mm2 “s“ and 1.5 mm2 – 6 mm2 “insulated ferrule, 12 mm /0.472 in“ No. of Item poles No. Female connectors with CAGE CLAMP ®S connection, 100 % protected against mismating, with coding fingers, light grey 831-3102 831-3103 831-3104 831-3105 831-3106 831-3107 831-3108 2 3 4 5 6 7 8 VOLUME 2 Pin spacing 7.62 mm/0.3 in, light grey 0.5 – 6 (10) mm2 ➊ AWG 20 – 8 ! No. of Item poles No. Female connectors with CAGE CLAMP ®S connection and locking device, 100 % protected against mismating, with coding fingers, light grey 2 831-3102/037-000 3 831-3103/037-000 4 831-3104/037-000 5 831-3105/037-000 6 831-3106/037-000 7 831-3107/037-000 8 831-3108/037-000 Accessories Test plug, with cable 500 mm /1’7.7’’ 2 mm/0.079 in Ø, red 210-136 Test plug, with cable 500 mm /1’7.7’’ 2 mm/0.079 in Ø, red 210-136 Marker card, Marker card, 80 self-adhesive strips per card Height of marker strip 5 mm/0197 in Marking 1 – 16 (100 x) 210-334/0762-0202 For direct printing, please contact factory Marker strip, white, plain, on roll for center marking 11 mm /0.039 in wide 2009-110 50 m 300 m 2009-130 80 self-adhesive strips per card Height of marker strip 5 mm/0197 in Marking 1 – 16 (100 x) 210-334/0762-0202 For direct printing, please contact factory Marker strip, white, plain, on roll for center marking 11 mm /0.039 in wide 2009-110 50 m 300 m 2009-130 Screwdriver with partially insulated shaft, (5.5 x 0.8) mm /(0.217 x 0.031) in 210-621 Screwdriver with partially insulated shaft, (5.5 x 0.8) mm /(0.217 x 0.031) in 210-621 L = (No. of poles - 1) x pin spacing + 9.5 mm L1 = L + 24.8 mm > 7,5 7,62 < 2 > < Dimensions (in mm) 83 VOLUME 2 Operating Tools Screwdriver acc. to DIN 5264, for optimum handling in terminal blocks and connectors Item Pack.-unit No. pcs Short screwdriver, with partially insulated shaft, blade 3.5 x 0.5 mm /0.137 in x 0.020 in, suitable for series 260, 261, 262, 264, 280, 281, 869 210-657 1 Short angled screwdriver, with partially insulated shaft, blade 3.5 x 0.5 mm /0.137 in x 0.020 in, particularly suitable for actuator and sensor terminal blocks of Series 280 and also for Series 260, 261, 262, 264, 280, 281, 869, 870, 880 210-658 1 ? tool Item Pack.-unit No. pcs ? tool with partially insulated shaft, Special blades 3.5 mm /0.137 in and 5.5 mm / 0.217 in suitable for 2003 and 2005 Series multilevel installation terminal blocks 2009-310 1 Application notes The blade dimensions of the a. m. screwdrivers (DIN 5264) are particularly appropriate for easy operation of front-entry sensor and actuator terminal blocks of series 280. 84 Index of Item Nos. Item No. Page Series 209 209-105 209-183 209-184 Item No. Page 42 42 231-903 231-905 231-907 231-910 78 78 78 78 250-205/350-604 250-206/350-604 250-207/350-604 250-208/350-604 55 55 55 55 231-2302/107-000 231-2303/107-000 231-2304/107-000 231-2305/107-000 231-2306/107-000 231-2307/107-000 231-2308/107-000 231-2309/107-000 231-2310/107-000 231-2311/107-000 231-2312/107-000 231-2313/107-000 231-2314/107-000 231-2315/107-000 231-2316/107-000 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 250-402/350-604 250-403/350-604 250-404/350-604 250-405/350-604 250-406/350-604 250-407/350-604 250-408/350-604 55 55 55 55 55 55 55 222-412 222-415 Series 231 210-133 210-136 210-137 11 4 4 210-281 11 210-331/0500-0103 210-331/0500-0104 210-331/0750-0202 210-332/0350-0202 210-332/0350-0204 210-332/0381-0202 210-332/0381-0204 210-332/0500-0202 210-334 210-334/0762-0202 57 57 57 74 74 75 75 58 43 82 54 57 31, 82 84 84 Series 211 211-110 211-111 211-112 211-113 211-114 211-115 211-120 211-121 211-122 211-123 211-124 211-125 211-129 211-150 211-151 211-155 211-156 Page Series 222 11 27 27 Series 210 210-619 210-620 210-621 210-657 210-658 Item No. 48 48 48 48 48 48 48 48 48 48 48 48 49 49 49 49 49 Series 218 218-102/000-604 218-102/000-604/997-403 218-103/000-604 218-103/000-604/997-405 218-104/000-604 218-104/000-604/997-405 218-105/000-604 218-105/000-604/997-405 218-106/000-604 218-106/000-604/997-405 218-107/000-604 218-107/000-604/997-405 54 54 54 54 54 54 54 54 54 54 54 54 218-502/000-604 218-502/000-604/997-403 218-503/000-604 218-503/000-604/997-405 218-504/000-604 218-504/000-604/997-405 218-505/000-604 218-505/000-604/997-405 218-506/000-604 218-506/000-604/997-405 218-507/000-604 218-507/000-604/997-405 54 54 54 54 54 54 54 54 54 54 54 54 231-129 231-132/001-000/105-604 231-132/001-000/105-604/997-405 231-133/001-000/105-604 231-133/001-000/105-604/997-405 231-134/001-000/105-604 231-134/001-000/105-604/997-407 231-135/001-000/105-604 231-135/001-000/105-604/997-407 231-136/001-000/105-604 231-136/001-000/105-604/997-407 231-138/001-000/105-604 231-138/001-000/105-604/997-407 231-140/001-000/105-604 231-140/001-000/105-604/997-409 231-142/001-000/105-604 231-142/001-000/105-604/997-409 231-159 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 73 231-307/107-000 231-308/107-000 231-309/107-000 231-312/107-000 231-314/107-000 231-315/107-000 231-316/107-000 231-337/108-000 231-338/108-000 231-339/108-000 231-340/108-000 231-342/108-000 231-344/108-000 231-345/108-000 231-346/108-000 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 231-432/001-000/105-604 231-432/001-000/105-604/997-405 231-433/001-000/105-604 231-433/001-000/105-604/997-405 231-433/040-000 231-434/001-000/105-604 231-434/001-000/105-604/997-407 231-435/001-000/105-604 231-435/001-000/105-604/997-407 231-436/001-000/105-604 231-436/001-000/105-604/997-407 231-438/001-000/105-604 231-438/001-000/105-604/997-407 231-440/001-000/105-604 231-440/001-000/105-604/997-409 231-442/001-000/105-604 231-442/001-000/105-604/997-409 231-463/040-000 69 69 69 69 77 69 69 69 69 69 69 69 69 69 69 69 69 77 231-500 231-537/108-000 231-538/108-000 231-539/108-000 231-540/108-000 231-542/108-000 231-544/108-000 231-545/108-000 231-546/108-000 68 79 79 79 79 79 79 79 79 231-637/109-000 231-638/109-000 231-639/109-000 231-640/109-000 231-642/109-000 231-644/109-000 231-645/109-000 231-646/109-000 231-670 231-671 231-672 79 79 79 79 79 79 79 79 76 76 76 Series 236 236-332 236-335 55 55 236-402/334-604 236-403/334-604 236-404/334-604 236-405/334-604 236-406/334-604 55 55 55 55 55 Series 248 248- . . . 5 Series 249 249- . . . 249-105 249-116 249-117 249-125 249-126 249-127 5 27 34 34 34 34 34 249-200 249-201 249-202 249-203 249-204 249-205 249-206 249-207 249-208 249-209 249-210 249-237 249-238 249-239 249-241 249-242 249-243 249-244 249-245 249-246 249-247 249-248 249-249 249-250 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 Series 250 250-202/350-604 250-203/350-604 250-204/350-604 85 55 55 55 Item No. Page Series 258 258-150 48 258-228 258-297 258-298 48 48 48 258-328 258-350 258-370 48 48 48 Series 280 280-402 280-404 280-409 280-415 34 34 34 34 Series 282 282-369 33 282-432 282-433 282-434 282-435 282-435/011-000 282-436 282-437 282-437/011-000 282-438 282-439 282-440 33 33 33 33 33 33 33 33 33 33 33 Series 283 283-404 31 Series 285 285-134 285-135 285-137 285-150 285-154 285-157 285-172 31 31 31 32 32 32 32 285-420 285-421 285-427 285-435 285-440 285-441 285-447 285-450 31 31 31 31 32 32 32 32 Item No. Page Series 298 298-642 298-646 298-6 . . 41 40 40 Item No. Page 733-204 733-205 733-206 733-207 733-208 733-210 733-212 64 64 64 64 64 64 64 Series 709 709-350 709-352 45 45 Series 722 722-102/026-000 722-103/026-000 722-104/026-000 722-105/026-000 722-106/026-000 722-107/026-000 722-108/026-000 722-109/026-000 722-110/026-000 722-111/026-000 722-112/026-000 722-113/026-000 722-114/026-000 722-115/026-000 722-116/026-000 722-117/026-000 722-118/026-000 722-119/026-000 722-120/026-000 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 722-202/026-000 722-203/026-000 722-204/026-000 722-205/026-000 722-206/026-000 722-207/026-000 722-208/026-000 722-209/026-000 722-210/026-000 722-211/026-000 722-212/026-000 722-213/026-000 722-214/026-000 722-215/026-000 722-216/026-000 722-217/026-000 722-218/026-000 722-219/026-000 722-220/026-000 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 Series 733 733-102 733-102/037-000 733-103 733-103/037-000 733-104 733-104/037-000 733-105 733-105/037-000 733-106 733-106/037-000 733-107 733-107/037-000 733-108 733-108/037-000 733-109/037-000 733-110 733-110/037-000 733-111/037-000 733-112 733-112/037-000 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 733-202 733-203 64 64 Series 734 734-114 734-114/037-000 734-126 734-127 734-128 734-129 734-130 734-132/105-604 734-132/105-604/997-405 734-133/105-604 734-133/105-604/997-405 734-134/105-604 734-134/105-604/997-405 734-135/105-604 734-135/105-604/997-405 734-136/105-604 734-136/105-604/997-407 734-138/105-604 734-138/105-604/997-407 734-140/105-604 734-140/105-604/997-407 734-142/105-604 734-142/105-604/997-407 734-144 734-162/105-604 734-162/105-604/997-405 734-163/105-604 734-163/105-604/997-405 734-164/105-604 734-164/105-604/997-405 734-165/105-604 734-165/105-604/997-405 734-166/105-604 734-166/105-604/997-407 734-168/105-604 734-168/105-604/997-407 734-170/105-604 734-170/105-604/997-407 734-172/105-604 734-172/105-604/997-407 734-174 70 70 80 80 80 80 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 48 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 70 734-226 734-227 734-228 734-229 734-231 80 80 80 80 73 734-314 734-326 734-327 734-328 734-329 734-362 734-362/037-000 734-363 734-363/037-000 734-364 734-364/037-000 734-365 734-365/037-000 734-366 734-366/037-000 734-367 734-367/037-000 734-368 734-368/037-000 734-369 734-369/037-000 734-370 734-370/037-000 70 4 4 4 4 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 Item No. Page 734-372 734-372/037-000 71 71 734-420 734-426 734-427 734-428 734-429 734-430 734-431 734-462 734-463 734-464 734-465 734-466 734-467 734-468 734-469 734-470 734-472 734-473 734-474 734-476 734-478 734-480 734-484 72 80 80 80 80 80 80 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 734-502 734-503 734-504 734-505 734-506 734-507 734-508 734-509 734-510 734-512 734-514 734-516 734-520 734-532 734-533 734-534 734-535 734-536 734-537 734-538 734-539 734-540 734-542 734-543 734-544 734-546 734-548 734-550 734-554 734-562 734-563 734-564 734-565 734-566 734-567 734-568 734-569 734-570 734-572 734-574 734-576 734-580 75 75 75 75 75 75 75 75 75 75 75 75 75 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 75 75 75 75 75 75 75 75 75 75 75 75 75 Additional item nos. 734- . . . /037-000 74 Series 735 735-500 86 54 Item No. Page Series 745 745-300 745-338 745-340 745-345 745-380 745-381 745-382 745-383 745-384 745-385 745-390 745-391 745-392 745-393 745-394 745-395 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 745-831 745-833 745-834 745-837 745-838 745-841 745-843 745-844 745-847 745-848 62 62 62 62 62 62 62 62 62 62 745-1352 745-1353 745-1354 745-1355 745-1356 745-1357 745-1358 745-1359 745-1360 745-1362 63 63 63 63 63 63 63 63 63 63 745-1402 745-1403 745-1404 745-1405 745-1406 745-1407 745-1408 745-1409 745-1410 745-1412 745-1452 745-1453 745-1454 745-1455 745-1456 745-1457 745-1458 745-1459 745-1460 745-1462 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 745-3100 745-3102 745-3103 745-3104 745-3105 745-3106 745-3107 745-3108 745-3109 745-3110 745-3112 745-3138 745-3152 745-3153 745-3154 745-3155 745-3156 745-3157 745-3158 745-3159 745-3160 745-3162 60 60 60 60 60 60 60 60 60 60 60 60 61 61 61 61 61 61 61 61 61 61 Item No. Page 745-3202 745-3203 745-3204 745-3205 745-3206 745-3207 745-3208 745-3209 745-3210 745-3212 745-3252 745-3253 745-3254 745-3255 745-3256 745-3257 745-3258 745-3259 745-3260 745-3262 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 745-3801 745-3803 745-3804 745-3807 745-3808 60 60 60 60 60 Additional item nos. 745- . . . /005-000 745- . . . /000-006 745- . . . /000-009 745- . . . /000-016 745- . . . /000-017 63 61 61 61 61 Series 746 746-2302 746-2303 746-2304 746-2305 746-2306 746-2307 746-2308 746-2309 746-2310 746-2311 746-2312 59 59 59 59 59 59 59 59 59 59 59 Additional item nos. 746- . . . /000-006 746- . . . /000-009 746- . . . /000-016 746- . . . /000-017 Page Item No. Page Item No. Page 769-242 769-243 769-251 769-251/000-006 769-257 36 36 34 38 34 790-300 790-301 45 45 769-317 769-318 769-319 769-320 769-321 36 36 36 34 34 Series 791 806-205 806-206 806-207 806-208 806-209 806-210 806-211 806-212 58 58 58 58 58 58 58 58 769-402 769-434 769-435 769-470 769-471 769-472 38 35 34 34 34 34 769-501 769-501/000-006 769-501/000-016 769-502 769-502/000-006 769-502/000-016 769-503 769-503/000-006 769-503/000-016 769-504 769-504/000-006 769-504/000-016 769-505 769-505/000-006 769-505/000-016 769-506 769-506/000-006 769-506/000-016 769-512 769-512/000-006 769-512/000-016 769-513 769-513/000-006 769-513/000-016 769-515 769-515/000-006 769-515/000-016 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 41 41 41 41 41 41 41 41 41 806-902 806-903 806-904 806-905 806-906 806-907 806-908 806-909 806-910 806-911 806-912 58 58 58 58 58 58 58 58 58 58 58 Series 773 59 59 59 59 773-173 43 773-332 43 773-514 43 791-107 791-111 791-117 791-124 44 44 44 44 Series 793 793-4... 793-5... 4 4 Additional item nos. Series 794 794-4... 794-5... 4 4 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 Series 777 807-0090/0101-0100 804-102 804-103 804-104 804-105 804-106 804-107 804-108 804-109 804-110 804-111 804-112 804-113 804-114 804-115 804-116 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 804-302 804-303 804-304 804-305 804-306 804-307 804-308 804-309 804-310 804-311 804-312 57 57 57 57 57 57 57 57 57 57 57 777-303 11 Series 780 780-452 780-453 780-454 780-455 780-456 780-457 780-458 34 34 34 34 34 34 34 Series 790 790-110 790-112 790-114 44 44 44 804- . . . /000-005 804- . . . /000-006 804- . . . /000-012 804- . . . /000-017 57 57 57 57 Series 806 806-102 806-103 806-104 806-105 806-106 806-107 806-108 806-109 806-110 806-111 806-112 58 58 58 58 58 58 58 58 58 58 58 806-202 806-203 806-204 58 58 58 87 806- . . . /000-006 806- . . . /000-012 58 58 Series 807 Series 804 Additional item nos. Series 769 769-101/000-006 769-102/000-006 769-103/000-006 769-103/000-038 769-103/000-039 769-104/000-006 769-105/000-006 769-105/000-038 769-105/000-039 769-106/000-006 769-107/000-006 769-108/000-006 769-109/000-006 769-110/000-006 769-111/000-006 769-112/000-006 769-113/000-006 769-114/000-006 769-115/000-006 769-171/000-006 769-176/000-006 Item No. 49 Series 831 831-137 82 831-3102 831-3102/037-000 831-3103 831-3103/037-000 831-3104 831-3104/037-000 831-3105 831-3105/037-000 831-3106 831-3106/037-000 831-3107 831-3107/037-000 831-3108 831-3108/037-000 83 83 83 83 83 83 83 83 83 83 83 83 83 83 831-3202 831-3202/007-000 831-3203 831-3203/007-000 831-3204 831-3204/007-000 831-3205 831-3205/007-000 831-3206 831-3206/007-000 831-3207 831-3207/007-000 831-3208 831-3208/007-000 82 82 82 82 82 82 82 82 82 82 82 82 82 82 831-3602 831-3603 831-3604 831-3605 831-3606 831-3607 831-3608 81 81 81 81 81 81 81 831-3622 831-3623 831-3624 831-3625 831-3626 831-3627 831-3628 81 81 81 81 81 81 81 Item No. Page Series 2001 2001-511 2001-549 2001-552 2001-553 2001-554 2001-555 2001-556 2001-557 2001-558 2001-559 2001-560 4 4 5 5 5 5 5 5 5 5 5 2001-1201 2001-1211/1000-0410 2001-1211/1000-0411 2001-1291 2001-1292 19 19 19 19 19 2001-1301 2001-1311/1000-0410 2001-1311/1000-0411 2001-1321/1000-0413 2001-1321/1000-0434 2001-1391 2001-1392 19 19 19 19 19 19 19 2001-1401 2001-1411/1000-0410 2001-1411/1000-0411 2001-1421/1000-0413 2001-1421/1000-0434 2001-1441 19 19 19 19 19 2 Series 2002 2002-0405/0011-000 2002-115 2002-121 2002-131 2002-171 2002-172 2002-402 2002-403 2002-404 2002-405 2002-406 2002-407 2002-408 2002-409 2002-410 2002-433 2002-434 2002-435 2002-436 2002-437 2002-438 2002-439 2002-440 2002-472 2002-473 2002-473/0011-0000 2002-474 2002-475 2002-475/0011-0000 2002-476 2002-477 2002-477/0011-0000 2002-478 2002-479 2002-479/0011-0000 2002-480 2002-481 2002-481/0011-0000 2002-482 2002-511 2002-541 26 2 6 7 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 4 4 Item No. 2002-549 2002-552 2002-553 2002-554 2002-555 2002-556 2002-557 2002-558 2002-559 2002-560 Page 4 5 5 5 5 5 5 5 5 5 2002-1201 2002-1211/1000-0410 2002-1211/1000-0411 2002-1291 2002-1292 20 20 20 20 20 2002-1301 2002-1311/1000-0410 2002-1301/1000-0411 2002-1321/1000-0413 2002-1321/1000-0434 2002-1391 2002-1392 20 20 20 20 20 20 20 2002-1401 2002-1411/1000-0410 2002-1411/1000-0411 2002-1421/1000-0413 2002-1421/1000-0434 2002-1441 2002-1491 2002-1492 20 20 20 20 20 2 2 2 2002-1601 2002-1602 2002-1604 2002-1671 2002-1672 2002-1674 2002-1691 2002-1692 16 16 16 16 16 16 16 16 2002-1801 2002-1802 2002-1804 2002-1871 2002-1872 2002-1874 2002-1891 2002-1892 17 17 17 17 17 17 17 17 2002-2201 2002-2202 2002-2203 2002-2204 2002-2207 2002-2208 2002-2209 2002-2211/1000-0410 2002-2211/1000-0411 2002-2213/1000-0487 2002-2213/1000-0488 2002-2214/1000-0489 2002-2214/1000-0490 2002-2214/1000-0491 2002-2214/1000-0492 2002-2217 2002-2227 2002-2221/1000-0413 2002-2221/1000-0434 2002-2231 2002-2232 2002-2233 2002-2234 2002-2237 2002-2238 2002-2239 2002-2247 2002-2257 2002-2291 2002-2292 6 6 6 6 6 6 6 22 22 23 23 23 23 22 22 6 6 23 23 6 6 6 6 6 6 6 6 6 6 6 Item No. Page 2002-2951 2002-2952 2002-2954 2002-2958 2002-2959 2002-2971 2002-2972 2002-2974 2002-2991 2002-2992 18 18 18 18 18 18 18 18 18 18 2002-3201 2002-3203 2002-3204 2002-3207 2002-3208 2002-3209 2002-3211/1000-0410 2002-3211/1000-0411 2002-3211/1000-0675 2002-3211/1000-0676 2002-3212/1000-0673 2002-3212/1000-0674 2002-3221/1000-0413 2002-3221/1000-0434 2002-3217 2002-3218 2002-3227 2002-3228 2002-3231 2002-3233 2002-3234 2002-3237 2002-3238 2002-3239 2002-3247 2002-3248 2002-3257 2002-3258 2002-3291 2002-3292 7 7 7 7 7 7 24 24 24 24 25 25 25 25 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 2002-6301 2002-6302 2002-6304 2002-6307 2002-6391 2002-6392 3 3 3 3 3 3 2002-6401 2002-6402 2002-6404 2002-6407 3 3 3 3 2002-7111 2002-7114 2002-7192 12 12 12 Item No. Page 2004-433 2004-434 2004-435 2004-436 2004-437 2004-438 2004-439 2004-440 11 11 11 11 11 11 11 11 2004-511 2004-541 2004-549 2004-552 2004-553 2004-554 2004-555 4 4 4 5 5 5 5 Series 2005 2005-7641 2005-7642 2005-7645 2005-7646 2005-7649 2005-7692 11 11 11 11 11 11 Series 2006 2006-0405/0011-000 2006-7111 2006-7114 2006-7192 26 12 12 12 Series 2009 2009-110 2009-115 2009-130 2009-174 2009-182 2009-184 2009-191 2009-192 2009-193 2009-196 4 5 4 3 3 50 27 27 27 27 2009-304 2009-305 2009-310 11 11 84 2009-412 2009-414 2009-416 26 26 26 Series 2003 2003-7641 2003-7642 2003-7645 2003-7646 2003-7649 2003-7692 10 10 10 10 10 10 88 2010-100 27 2010-0405/0011-000 26 Series 2016 Series 2004 2004-402 2004-403 2004-404 2004-405 2004-406 2004-407 2004-408 2004-409 2004-410 2004-0405/0011-000 Series 2010 11 11 11 11 11 11 11 11 11 26 2016-100 27 2016-0405/0011-000 26 2016-1207 10 2016-7111 2016-7114 2016-7192 12 12 12 Item No. Page Item No. Page Item No. 89 Page Item No. Page Notes 90 Notes 91 Notes 92 Notes 93 WAGO Worldwide – Companies and Representations – Argentina Bruno Schillig S.A. Arenales 4030, B1604CFD Florida, PBA Phone +54 11 4730 1100 Fax +54 11 4761 7244 robertor@schillig.com.ar Columbia T.H.L. Ltda. Cra. 49 B # 91-33 Bogotá Phone +57 1 621 85 50 Fax +57 1 621 60 28 ventas-thl@thl-ltda.com Greece PANAGIOTIS SP. DIMOULAS - BIOMAT Kritis Str. 26 10439 Athen Phone +30 210 883 3337 Fax +30 210 883 4436 export@wago.com Australia NHP ELECTRICAL ENGINEERING PRODUCTS PTY LTD 43-67 River Street Richmond, Victoria, 3121 P.O. Box 199 Phone +61 3 9429 2999 Fax +61 3 9429 1075 export@wago.com Croatia M.B.A. d.o.o. za trgovinu i zastupanje Frana Supila 5 51211 Matulji HR Phone +00385 51 275-736 Fax +00385 51 275-066 mba@ri.htnet.hr Hong Kong National Concord Eng., Ltd. Unit A-B, 5/F. Southeast Industrial Building 611-619 Castle Peak Road Tsuen Wan, N.T. Phone +852 24292611 Fax +852 24292164 sales@nce.com.hk Austria WAGO Kontakttechnik Ges.m.b.H. Laxenburger Straße 244 1230 Wien Phone +43 1 6150780 Fax +43 1 6150775 info.at@wago.com Belgium WAGO Kontakttechnik Excelsiorlaan 11 1930 Zaventem Phone +32 2 7179090 Fax +32 2 7179099 info-be@wago.com Bosnia and Herzegovina please contact WAGO Bulgaria SC_Technik doo Kadić Mahala 47 Bosnia-Herzegovina Phone +387 35 821815 Fax +387 35 821816 sc_technik@yahoo.de Brasil WAGO Eletroeletrônicos Ltda Rua Américo Simões 1470 Sãu Roque da Chave Itupeva SP Brasil 13295-000 Phone +55 11 4591 0199 Fax +55 11 4591 0190 info.br@wago.com Bulgaria WAGO Kontakttechnik GmbH & Co. KG Representative Office Sofia Bulgaria Twardischiki Prohod 21, ap.5 1404 Sofia Phone +359 2 489 46 10 Fax +359 2 859 21 31 info-BG@wago.com RIM Project Ltd. Probuda - 12 A str., et. 7 Sofia Bulgaria Phone +359 2 9310666 Fax +359 2 9313839 office@rim-bg.com Canada WAGO CORPORATION N120 W19129 Freistadt Road Germantown, WI 53022 Phone +1 262 255 6222 Fax +1 262 255 3232 Toll-Free: 1-800 DIN Rail (346-7245) info.us@wago.com Czech Republic WAGO Elektro spol. sr. o. Nad lesem 21 14700 Praha 4 - Hodkovicky 61400 Brno - Husovice Phone +420 261 090 143 Fax +420 261 090 144 info.cz@wago.com Denmark WAGO Danmark Filial of WAGO Kontakttechnik GmbH & Co. KG Lejrvej 29 3500 Værløse Phone +45 44 357777 Fax +45 44 357787 salg.dk@wago.com Ecuador INSETEC CIA. LTDA. El Zurriago 177 y El Vengador P.O. Box 17-16-016 Quito Phone +593 2 2 26 91 48 Fax +593 2 2 46 18 33 g.castro@insetec.com.ec Egypt IBN Engineering Instrumentation & Control 71 a El Shaheed Ahmed Hamdi St. King Faisal, Giza Phone +20 2 7214350 Fax +20 2 7221709 sales@ibnengineering.com Estland Eltarko OÜ Laki 14 - 502 10621 Tallinn Phone +372 651 7731 Fax +372 651 7786 andres@eltarko.ee Finland WAGO Kontakttechnik GmbH & Co. KG Filial i Finland Vellamonkatu 30 B 00550 Helsinki Phone +358 9 7744 060 Fax +358 9 7744 0660 export@wago.com France WAGO CONTACT S.A. Paris Nord 2 83 Rue des Chardonnerets B.P. 55065 - Tremblay en France 95947 - ROISSY CDG CEDEX Phone +33 1 48172590 Fax +33 1 48632520 info-fr@wago.com Chile Desimat Chile Av Puerto Vespucio 9670 Pudahuel Santiago Phone +56 2 7470152 Fax +56 2 7470153 ventaschile@desimat.cl Germany WAGO Kontakttechnik GmbH & Co. KG Postfach 28 80 32385 Minden Hansastrasse 27 32423 Minden Phone +49 571 887-0 Fax +49 571 887-169 info@wago.com China WAGO ELECTRONIC (TIANJIN) Co. LTD No.5, Quan Hui Road Wuqing Development Area Tianjin 301700 Phone +86 22 59617688 Fax +86 22 59617668 info-cn@wago.com Great Britian WAGO Limited Triton Park, Swift Valley Industrial Estate RUGBY Warwickshire, CV21 1SG Phone +44 1788 568008 Fax +44 1788 568050 uksales@wago.com Hungary WAGO Hungá¡ria KFT Ipari Park, Gyár u. 2 2040 Budapest Phone +36 23 502-170 Fax +36 23 502-166 info@wago.hu Iceland S. Gudjonsson ehf. Audbrekku 9-11 202 Kopavogur Phone +354 520-4500 Fax +354 520-4501 export@wago.com India WAGO & CONTROLS (INDIA) LTD. C-27, Sector-58, Phase-III Noida-201 301 Gautam Budh Nagar (U.P) Phone +91 120 2 580409 10 Fax +91 120 2 580081 info@wagoindia.com Indonesia PT. Timur Agungmulia Kencana Graha Mulxindo Lt. 2 Jl. Sultan Iskandar Muda No. 88 L Jakarta Selatan 12240 Phone +62 21 722 8888 Fax +62 21 722 8565 tak_electric@cbn.net.id Iran Patsa Industry No. 2 Bahar St. South Shiraz Ave P.O. Box.: 15875-1698 14369 Tehran Phone +98 21 8726869 Fax +98 21 8719666 export@wago.com Ireland Drives & Controls Unit F4, Riverview Business Park Nangor Road Dublin 12 Phone +353 1 4604474 Fax +353 1 4604507 wago@drivesandcontrols.ie Israel Comtel Israel Electronic Solutions Ltd. Bet Hapaamon 20 Hataas Street P.O.Box 66 44425 Kefar-Saba Phone +972 9 76 77 240 Fax +972 9 76 77 243 sales@comtel.co.il Italy WAGO ELETTRONICA SRL Via Vittoria, 5/b 40068 San Lazzaro di Savena (BO) Phone +39 051 6272170 Fax +39 051 6272174 info-ita@wago.com Japan WAGO Co. of JAPAN Ltd. Nittetsu ND-Tower Building 4F Kameido 1-5-7 Koto-Ku Tokyo 136-0071 Phone +81 3 5627 2050 Fax +81 3 5627 2055 info-jp@wago.com Korea Hankuk Sangsa Co. & Mahani Electric Co. Ltd. 576-8, Bisan-2dong, Dongan-Ku Anyang-City Kyungki-Do., 431-821 Phone +82 31 4633300 Fax +82 31 4633398 9 export@wago.com Kosovo please contact WAGO Bulgaria Kuwait Kuwait Controls Company Al Sour Street, Above Lufthansa Airline Safat Kuwait 13062 Phone +965 822 522 Fax +965 243 3698 Latvia INSTABALT LATVIA SIA Vestienas iela 6 Rīga, LV-1035 Phone +371 790 1188 Fax +371 790 1180 info@instabalt.lv Lebanon G.T.C. Antonine Project – Block G P.O.BOX 70-1096 Antelias Lebanon Phone +961 4 521 029 Fax +961 4 521 029 rgemayel@inco.com.lb Lithuania INSTABALT LIT UAB Savanorių 187 Vilnius, 2053 Phone +370 52 322 295 Fax +370 52 322 247 info@instabalt.lt Luxembourg please contact WAGO Belgium Macedonia please contact WAGO Bulgaria Malaysia WAGO Representative Office Malaysia No 806, Block A4, Leisure Commerce Square, No 9, Jalan PJS 8/9, 46150 Petaling Jaya, Selangor Darul Ehsan, Malaysia Phone +60 3 7877 1776 Fax +60 3 7877 2776 kian.guan.tan@wago.com Mexico WAGO CORPORATION N120 W19129 Freistadt Road Germantown, WI 53022 Phone +52 55 26 44 69 16 Fax +52 55 26 44 69 15 Toll-Free: 001-800-309-5975 info.mx@wago.com Netherlands WAGO Nederland van Leeuwenhoekstraat 20-1 3846 CB Harderwijk Phone +31 341 439039 Fax +31 341 439030 info-nl@wago.com New Zealand NHP NZ 7 Lockhart Place Mt Wellington New Zealand Phone +64 9 2761967 Fax +64 9 2761992 export@wago.com Norway WAGO Norge NUF Jerikoveien 20 1067 Oslo Phone +47 22 30 94 50 Fax +47 22 30 94 51 info.no@wago.com Peru Desimat Peru Av. E. Salazar Barreto No. 280 Surco - Lima 33 Phone +51 1 2731892 Fax +51 1 2720054 export@wago.com Philippines WAGO Electronic Pte Ltd 10 Upper Aljunied Link, # 04-04 York International, Industrial Building Singapore 367904 Phone +65 62866776 Fax +65 62842425 info.sing@wago.com Poland WAGO ELWAG sp. z o. o. ul. Piękna 58 a 50-506 Wrocław Phone +48 71 3604670 78 Fax +48 71 3604699 wago.elwag@wago.com Portugal MORGADO & CA. LDA - SEDE Estrada Exterior da Circunvalação 3558/3560 Apartado 1057 4435 Rio Tinto Phone +351 22 9770600 Fax +351 22 9770699 export@wago.com Romania please contact WAGO Bulgaria VDR & Servicii srl Str. Valeriu Branişte, nr. 60, ap.1, sector 3 Romania Phone +40 21 3225074/76 Fax +40 21 3225075 office@componente-automatizari.ro ETA Automatizari Industriale SRL Str. Gh. Dima Nr. 1 Romania Phone +40 256 294608 Fax +40 256 294609 automatizari@eta2u.ro Russia ООО ВАГО Контакт Рус ул. Лесная, 43, офис 329 127055 Москва Phone +7 499 9786670 Fax +7 499 9786690 info@wago.ru Saudi Arabia Al Quraishi Electrical Services of S. A. P.O. Box 7386 Dammam-31462 Phone +966 3 85 725 37 Fax +966 3 85 725 41 export@wago.com Spain DICOMAT S.L. Avda. de la Industria, 36 Apartado Correos, 1.178 28108-Alcobendas (Madrid) Phone +34 91 6621362 (6 lineas) Fax +34 91 6610089 madrid@dicomat-asetyc.com Sweden WAGO Sverige WAGO Kontakttechnik GmbH Tyskland Filial Box 639, 17527 Järfälla Datavägen 9 A, 17543 Järfälla Phone +46 858410680 Fax +46 858410699 info.se@wago.com Switzerland WAGO CONTACT SA Rte. de I Industrie 19 Case Postale 168 1564 Domdidier Phone +41/26 676 75 86 (Phone German) Fax +41/26 676 75 88 (Phone Italian) info.switzerland@wago.com Syria Zahabi Co. 8/5 Shouhadaa St., P.O. Box 8262 Aleppo Phone +963 21 21 22 235 / 6 Fax +963 21 21 24 768 export@wago.com Taiwan R.O.C. WAGO Taiwan 8/F., No. 48, Jing-An Road Chung-Ho City, 23556 Taipei Hsien. T a i w a n Phone +886 2 2244 2569 Fax +886 2 2244 2658 Thailand WAGO Representative Office Thailand 4th Floor, KS Building 213/6-8 Rachada-Phisek Road Dingdaeng Bangkok 10320 Phone +66 2 6935611 Fax +66 2 6935612 pote.c@wago.com Turkey WAGO Elektronik Sanayi ve Ticaret Ltd. Şti. Barbaros Mahallesi Mimar Sinan Caddesi No 169 34746 Yenisahra - Kadıköy Istanbul Turkey Phone +90 216 472 1133 Fax +90 216 472 9910 info.tr@wago.com Serbia please contact WAGO Bulgaria United Arab Emirates (UAE) Binghalib Engineering Ent. Trading Division Al Khabeshi Area P.O. Box 14743 Dubai Phone +971 4 2674555 Fax +971 4 2674117 export@wago.com Singapore WAGO Electronic Pte Ltd 10 Upper Aljunied Link, # 04-04 York International, Industrial Building Singapore 367904 Phone +65 62866776 Fax +65 62842425 info.sing@wago.com USA WAGO Corporation N120 W19129 Freistadt Road Germantown, WI 53022 Phone +1 262 255 6222 Fax +1 262 255 3232 Toll-Free: 1-800 DIN Rail (346-7245) info.us@wago.com Slovakia WAGO Elektrik spol.s r. o Odborárska 52 83102 Bratislava Phone +421 2 44458301 Fax +421 2 44458301 export@wago.com Venezuela PETROBORNAS, C.A. Av. Principal UD 304-Zona Ind. Los Pinos C.C. Los Pinos-Local E 8015-Puerto Ordaz-Edo, Bolivar Phone +58 286 994 3406 Fax +58 286 994 5249 info@petrobornas.net South Africa Shorrock Automation (Pty) Ltd Postnet Suite # 219 Private Bag X 8,Elardus Park 0047 PRETORIA Phone +27 12 3454449 Fax +27 12 3455145 sales@shorrock.co.za Vietnam please contact WAGO Singapore 20.08.07/E 51188216 · 0888-0125/4410-3601 · Suppl. to W4 Volume 1+2 E · 04/07 · JA 70468 · Printed in Germany · Subject to design changes 4 045454 505516
804-104 价格&库存
很抱歉,暂时无法提供与“804-104”相匹配的价格&库存,您可以联系我们找货
  • 2+20.045042+2.60579
  • 55+18.9619455+2.46499
库存:220
804-104
  • 5+14.85430
  • 25+14.25863
  • 50+13.66712
库存:20
