832-1105
832-1105
    WAGO(万可电子)
    P=10.16mm
    接线端子 1x5P 间距:10.16mm 排数:1 每排Pin数:5
832-1105 数据手册
PCB Terminal Blocks and Pluggable Connectors for Power Electronics More Power on Your PCB MORE POWER ON YOUR PCB More Power no Longer Means More Space The trend toward electronic miniaturization requires that both power and signal levels be integrated on PCBs. This results in increased power density, requiring connection technologies and pluggable connectors suited for both compact and high-performance PCB terminal blocks. Connection technology is also a basic criterion for selecting the right terminal block in demanding applications, such as power supplies, frequency inverters or servo drives. Additional decisive factors include simple and easy operation, as well as wiring flexibility. Every Advantage – All in One WAGO combines all these criteria into a comprehensive and varied range of PCB terminal blocks 2 for power electronics. WAGO‘s PCB terminal blocks are rated for 4 mm², 6 mm² and 16 mm² conductor cross-sections and can be operated either with or without a tool. The WAGO MCS MAXI 16 Pluggable Connector has a conductor size of 16 mm² (6 AWG). Integrated levers enable intuitive actuation without tools for simple, secure in-hand wiring. The blocks also offer a unique space-saving feature: Beyond their nominal cross-section, the PCB terminal blocks and pluggable connectors connect most solid and fine-stranded conductors up to the next larger cross-section size. This saves space on the PCB and reduces device connection costs. Thanks to WAGO’s innovative spring pressure connection technology, the WAGO PCB Terminal Blocks for all applications ideally blend ergonomics and safety. Push-in CAGE CLAMP® enables solid and ferruled conductors to be connected by simply pushing them into the unit, while guaranteeing secure and maintenance-free connections for all conductor types. Furthermore, our products are not only simple and easy to use, but also offer maximum wiring flexibility. Advantages: • Comprehensive product line ranging from 0.2 to 25 mm² • Push-in CAGE CLAMP® termination • Wider conductor range and higher current carrying capacity • Conductor connection and mating direction both horizontal and vertical to the PCB • Testing both parallel and perpendicular to conductor entry Learn more at: www.wago.com/powerelectronics 3 PCB TERMINAL BLOCKS WITH Push-in CAGE CLAMP® 2624, 2626, 2636 Series WAGO‘s PCB terminal blocks with Push-in CAGE CLAMP® are ideal for compact device connections. They are compatible with existing industrial solutions and can be perfectly integrated into both space-limited and panel feedthrough applications. Advantages: • Compact device connection • Ideal for panel feedthrough and spacerestricted applications • Operation parallel to conductor entry • Compatibility with existing industrial solutions • For applications complying with EN and UL 61800-5-1 (details upon request) Push-in CAGE CLAMP® is suitable for all conductor types and enables solid and ferruled conductors to be connected by simply pushing them into the unit. Tool-actuated termination is performed parallel to conductor entry. WAGO‘s PCB terminal blocks terminate conductors both horizontally and vertically to the PCB. Furthermore, they can be tested both parallel and perpendicular to conductor entry. Conductor Ranges: [mm2] 0.2 2626 Series All conductor types [AWG] 24 2624 Series 2636 Series 0.34 0.5 All conductor types 22 20 0.75 1.5 All conductor types 18 16 All conductor types including ferruled without restriction 4 2.5 14 “s” 4 12 6 “s” + “f-st” 10 Only solid conductors 10 16 “s” + “f-st” 8 6 25 “f-st” 4 [mm2] Pin spacing: 5 / 7.5 / 11.5 mm Pin spacing: 7.5 mm Pin spacing: 10 mm [AWG] “f-st” Only fine-stranded conductors PCB TERMINAL BLOCKS WITH Push-in CAGE CLAMP® AND LEVER 2604, 2606, 2616 Series WAGO‘s lever-equipped PCB terminal block variants offer faster and easier wiring. They combine a compact design, high current carrying capacity and the advantages of Push-in CAGE CLAMP® with the benefits of intuitive lever operation. The lever permits 100% tool-free operation and provides a secure connection when the easy-touse lever closes the clamping unit. The lever also clearly locks in position (open/close) with a tactile and audible click. WAGO‘s PCB terminal blocks with levers terminate conductors both horizontally and vertically to the PCB. Furthermore, they can be tested both parallel and perpendicular to conductor entry. Advantages: • Faster and easier wiring • Tool-free, intuitive lever operation • Secure connection via easy and effortless lever actuation into closed position • Lever clearly locks in position (open/close) Conductor Ranges: [mm2] 2604 Series 2606 Series 2616 Series [AWG] 0.2 0.34 0.5 All conductor types All conductor types 24 22 20 0.75 1.5 2.5 All conductor types 18 16 All conductor types including ferruled without restriction 14 “s” 4 “s” + “f-st” 12 6 10 16 “s” + “f-st” 10 Only solid conductors 8 6 25 “f-st” 4 [mm2] Pin spacing: 5 / 7.5 / 11.5 mm Pin spacing: 7.5 mm Pin spacing: 10 mm [AWG] “f-st” Only fine-stranded conductors 5 2624 SERIES • PCB terminal block (4 mm²) with tool operation and Push-in CAGE CLAMP® • Straight or angled type • Ideal for panel feedthrough applications via operation parallel to conductor entry Push-in termination of solid conductors Insert fine-stranded conductors and remove all conductor types via operating tool. PCB terminal block for panel feedthrough connections 5 mm Ratings per IEC/EN 60664-1 Conductor Data Connection technology Push-in CAGE CLAMP® Nominal voltage (III / 3) 320 V 630 V 1000 V Conductor range: solid 0.2 … 6 mm² Rated voltage (III / 2) 400 V 630 V 1000 V Conductor range: fine-stranded 0.2 … 6 mm² 630 V 1000 V 1000 V Conductor range: fine-stranded 0.25 … 2.5 mm² Rated surge voltage 4 kV 6 kV 8 kV Conductor range: fine-stranded 0.25 … 2.5 mm² Rated current 32 A AWG 24 … 10 26 A 150 V 26 A 600 V Strip length 10 … 12 mm 0.8 8.2 8.2 15.4 15.4 1 1.5 2.75 15.4 8.2 2624-3101 2624-3102 2624-3302 2624-3502 3 2624-1103 2624-1303 2624-1503 2624-3103 2624-3303 2624-3503 4 2624-1104 2624-1304 2624-1504 2624-3104 2624-3304 2624-3504 5 2624-1105 2624-1305 2624-1505 2624-3105 2624-3305 2624-3505 6 2624-1106 2624-1306 2624-1506 2624-3106 2624-3306 2624-3506 7 2624-1107 2624-1307 2624-1507 2624-3107 2624-3307 2624-3507 8 2624-1108 2624-1308 2624-1508 2624-3108 2624-3308 2624-3508 9 2624-1109 2624-1309 2624-1509 2624-3109 2624-3309 2624-3509 10 2624-1110 2624-1310 2624-1510 2624-3110 2624-3310 2624-3510 11 2624-1111 2624-1311 2624-1511 2624-3111 2624-3311 2624-3511 12 2624-1112 2624-1312 2624-1512 2624-3112 2624-3312 2624-3512 4.2 16.3 4.2 11.5 1 11.5 1.5 0.8 ) 5 4.2 > > 5 Ø 1.3 2624-1502 > 8.2 2.7 > ) 2624-1102 > 1 0.8 5.6 8.2 16.3 > 1.5 Pin spacing Pin spacing )4 1 4 11.5 mm Straight 4 7.5 mm 15.4 (with uninsulated ferrule) > 5 mm 11.5 __> 11.5 mm 11.5 > 7.5 mm Angled (with insulated ferrule) 4.2 ) < Conductor range: fine-stranded 16.7 25.8 > 630 V 1.5 1 _____> _____> Nominal voltage (II / 2) Conductor range: fine-stranded 1 Pin spacing Pin spacing 3.8 18.4 Conductor Data
832-1105 价格&库存
很抱歉,暂时无法提供与“832-1105”相匹配的价格&库存,您可以联系我们找货
    • 20+181.38613
    库存:36
