| : 852-111/000-001
Industrial-ECO-Switch; 5-port 100Base-TX; black
https://www.wago.com/852-111/000-001
black
The 852-111/000-001 switch is an industrial unmanaged ETHERNET switch with 5 10/1000Base-TX ports. The ports of the industrial switch allow multi
ple segments to be formed to reduce network congestion, and each user node can be assigned its own bandwidth.
The slim design with DIN rail adapter allows easy installation in the control cabinet with high vibration and shock resistance. The automatic recognition
of the transmission rate (autonegotiation) as well as the automatic determination of the transmit and receive lines (Auto MDI-X) enable simple plug &
play operation and thus help to save costs and time during commissioning.
Features:
5 ETHERNET ports, 10/100 Mbps autonegotiation
Front-panel diagnostic LEDs
Supports Auto-MDI/MDI-X functions
Full/half-duplex transfer modes for each port
Store-and-forward switching method
Integrated address look-up table, supports 2000 absolute MAC addresses
Overvoltage protection
IEEE 802.3x flow control in full-duplex mode
Prioritization of PROFINET data packets (EtherType=0x8892) according to IEEE802.1p
DIN-35 rail mounting
Seite 1/2
Stand: 24.05.2022
Fortsetzung nächste Seite ››
| : 852-111/000-001
Technical data
Switching mode
Store‐and‐forward; non-blocking
Number of 100Base-TX ports
5
Communication standards
IEEE 802.3 10BASE-T
IEEE 802.3u 100BASE-TX
IEEE 802.3x Flow Control
IEEE 802.1p Prioritization
MAC table (size)
2000 addresses
Supply voltage
12 … 48 VDC
Power consumption (max.)
2W
Baud rate
Copper cable: 10/100 Mbit/s
Topology
Star
Indicators
Device: LED (PWR) green: Power supply; per port: LED (100, LNK/ACT) green: Status 100
Mbps, LNK/ACT port 1 … 5
Connection data
Connection technology: communication/fieldbus
Copper cable: 5 x RJ-45
Connection technology: supply
1 x Built-in male connector: 231-433/001-000; included female connector (MCS
Connectors): 231-103/026-000
Physical data
Width
23.4 mm / 0.921 inches
Height
109.2 mm / 4.299 inches
Depth
73.8 mm / 2.906 inches
Depth from upper-edge of DIN-rail
81 mm / 3.189 inches
Mechanical data
Weight
203 g
Color
black
Housing material
Sheet steel
Environmental requirements
Ambient temperature (operation)
-40 … +70 °C
Surrounding air temperature (storage)
-40 … +85 °C
Protection type
IP30
Relative humidity (without condensation)
95 %
Mounting type
DIN-35 rail
Vibration resistance
per IEC 60068-2-6
Shock resistance
per IEC 60068-2-27
Fire load
0 MJ
Commercial data
PU (SPU)
1 Pieces
Country of origin VKOrg Germany
TW
GTIN
4066966216288
Customs tariff number VKOrg Germany
85176200000
Änderungen vorbehalten. Bitte beachten Sie auch die weitere Produktdokumentation!
Adressen finden Sie unter: w w w.wago.com
Seite 2/2
Stand: 24.05.2022
很抱歉,暂时无法提供与“852-111/000-001”相匹配的价格&库存,您可以联系我们找货
