Fastening Options
chassis
sten onto screw
a
F
m
o
g
Fasten fr lf by self tappin
se
om top
ia screw
ia
v
fr
v
n
e
w
Ø
st
lo
m
a
F
(2.9 m
Ø) be
m
w
m
re
(3
sc
t
and nu
tapping
) into
from top
(2.9 mm Ø sing
hou
terminal
mmØ)
screw (3
ia
v
n
e
st
ssis
Fa
ad in cha
into thre
nut
24
0.94”
36
1 .42”
24
0.94”
12
0.47”
and
ia screw
Fasten v
Ø
(3 mm
from top
48
1 .89”
ounting
ap-in m
ing via sn
Fasten
feet
Ferrules
Insulated ferrules
Uninsulated ferrules
Sleeve
for mm2
AWG
Color
Stripped
length mm
L
0.5
0.75
1.0
1.5
0.5
0.75
1.0
1.5
22
16
22
16
white
grey
red
black
12.0
12.0
12.0
12.0
10
10
10
10
16.0
16.0
16.0
16.0
10
10
10
10
L1
D
mm
D
D2
Item
No.
Pack.-unit
pcs
10.0
10.0
10.0
10.0
3.1
3.3
3.5
4.0
2.1
2.3
2.5
2.8
2.6
2.8
3.0
3.5
1.0
1.2
1.4
1.7
1.0
1.2
1.4
1.7
216-241
216-242
216-243
216-244
216-141
216-142
216-143
216-144
1000
1000
1000
1000
1000
1000
1000
1000
Tools
Crimp Tool
206-204
0.25 - 4 mm2
AWG 24 - 12
Subject to design changes
Stripper / Cutter
206-101
0.5 - 6 mm2
AWG 28 - 8
WAGO Corporation N120 W19129 Freistadt Road; P.O. Box 1015; Germantown, WI 53022
1-800 DIN Rail (346-7245) Fax: (262) 255-3232 info.us@wago.com www.wago.us
51011208 0888-0153/0001-3601 rev2 10/05 Printed in the United States
Dimensions (mm)
862 Series
Terminal Blocks for Chassis Mounting
862 Series - Terminal Block for Chassis Mounting
4 x 0.5 – 4 mm2
500 V/6 kV/2
32 A
l
Available in black and white
without ground/
earth contact
4 x AWG 20 –12
300 V, 20 A
600 V, 5 A
2U
for fastening screw 3 mm /0.118 in Ø or
for self tapping screw 2.9 mm / 0.114 in Ø from top
without marking
L1-N (pre-marked)
N-L1 (pre-marked)
for self tapping screw 2.9 mm / 0.114 mm Ø from below
without marking
L1-N (pre-marked)
N-L1 (pre-marked)
1 snap-in foot per pole
without marking
L1-N (pre-marked)
N-L1 (pre-marked)
for fastening screw 3 mm / 0.008 in Ø or
without marking
PE-N-L1 (pre-marked)
N-PE-L1 (pre-marked)
(pre-marked) N-PE-L1
(pre-marked) PE-N-L1
without marking
snap-in feet at pos. 1+3
without marking
Item No.
black
l
10 – 11 mm / 0.41 in
2 poles /8 connection points
with ground/
earth contact
4 x 0.5 – 4 mm2
500 V/6 kV/2
32 A
Item No.
white
2U
862-0552
862-1552
862-2552
862-0652
862-1652
862-2652
500
500
500
862-0562
862-1562
862-2562
862-0662
862-1662
862-2662
500
500
500
862-0532
862-1532
862-2532
862-0632
862-1632
862-2632
500
500
500
Accessories
Item No.
black
Item No.
white
Pack.-unit
pcs
862-0503
862-1503
862-2503
862-8503
862-9503
862-0603
862-1603
862-2603
862-8603
862-9603
250
250
250
250
250
862-0533
862-1533
862-2533
862-8533
862-9533
862-0633
862-1633
862-2633
862-8633
862-9633
250
250
250
250
250
862-0593
862-1593
862-2593
862-8593
862-9593
862-0693
862-1693
862-2693
862-8693
862-9693
250
250
250
250
250
Comb-type jumper bar, can easily be inserted into the
wire entry, 32 A
862-482
5
Test plug, with cable 500 mm / 1'7.7"
2 mm /0.079 in Ø, red
210-136
1
2.3 mm /0.091 in Ø, yellow
210-137
50 (5 x 10)
Screwdriver, with partially inslated shaft
(3.5 x 0.5) mm (.14 x .0025) in
210-620
1
Marker strip, white, plain for central marking;
7.5 mm wide, on roll, 50 m long
709-178
1
7.5 mm wide, on roll, 300 m long
709-188
1
Cost-effective features:
The new 862 Series chassis mount terminal block was developed specifically to minimize wiring costs, while accommodating requirements for easy
mounting, multiple connection points, marking, and handling.
• The new 862 Series allows the connection of up to four conductors from wire size 20 to 12 AWG. Due to the multiple connection points per pole,
different wire sizes can be used within the same terminal block position.
• The CAGE CLAMP®S termination technology allows solid conductors, stranded conductors with ferrules, or ultrasonically bonded conductors to
be easily connected by simply pushing the conductor into the contact.
• An integrated push button, with molded-in slots, accommodates fast and easy wiring of all conductor types - either by hand, or with a slotted tip/
phillips screwdriver.
• Convenient automatic grounding contact available as an option (see page 3 for illustration).
• Snap-in mounting feet for fast assembly (see back page for illustration).
• Flexible marking options with standard marking (pre-marked), marker strip, or custom marked per your specifications with large quantity orders.
• Built-in test points simplify testing with 2 mm / 0.079 in diameter test plug.
4 x AWG 20 –12
300 V, 20 A
600 V, 5 A
2U
l 10 – 11 mm / 0.41 in
3 poles /12 connection points
Pack.-unit
pcs
4 x 0.5 – 4 mm2
500 V/6 kV/2
32 A
4 x AWG 20 –12
300 V, 20 A
600 V, 5 A
without ground/
earth contact
for fastening screw 3 mm Ø or
for self tapping screw 2.9 mm Ø from top
without marking
PE-N-L1-L2 (pre-marked)
N-PE-L1-L2 (pre-marked)
(pre-marked) N-PE-L1-L2
(pre-marked) PE-N-L1-L2
without marking
snap-in feet at pos. 1+4
without marking
without marking
PE-N-L1-L2-L3 (pre-marked)
L3-N-PE-L1-L2 (pre-marked)
(pre-marked) L3-N-PE-L1-L2
(pre-marked) PE-N-L1-L2-L3
1 snap-in feet at pos. 2+4
without marking
snap-in feet at pos. 1+3+5
without marking
4 x AWG 20 –12
300 V, 20 A
600 V, 5 A
2U
4 poles /16 connection points
with ground/
earth contact
4 x 0.5 – 4 mm2
500 V/6 kV/2
32 A
5 poles /20 connection points
Item No.
black
Item No.
white
Pack.-unit
pcs
862-0504
862-1504
862-2504
862-8504
862-9504
862-0604
862-1604
862-2604
862-8604
862-9604
200
200
200
200
200
862-0534
862-1534
862-2534
862-8534
862-9534
862-0634
862-1634
862-2634
862-8634
862-9634
200
200
200
200
200
862-0594
862-1594
862-2594
862-8594
862-9594
862-0694
862-1694
862-2694
862-8694
862-9694
200
200
200
200
200
Item No.
black
Item No.
white
Pack.-unit
pcs
862-0505
862-1505
862-2505
862-8505
862-9505
862-0605
862-1605
862-2605
862-8605
862-9605
200
200
200
200
200
862-0525
862-1525
862-2525
862-8525
862-9525
862-0625
862-1625
862-2625
862-8625
862-9625
200
200
200
200
200
862-0515
862-1515
862-2515
862-8515
862-9515
862-0615
862-1615
862-2615
862-8615
862-9615
200
200
200
200
200
Ground (earth) contact
Conductor connection
Marking and testing
• Makes an automatic contact to the
mounting plate
• Varnish coating is penetrated
automatically
• Four conductors per pole
• For solid and flexible conductors
• Mixed wiring with solid and flexible
conductors of different cross sections
• Marking by direct printing and/or
marker strips
• Testing with test plug 2 mm Ø
很抱歉,暂时无法提供与“862-0552/RN01-0000”相匹配的价格&库存,您可以联系我们找货
