0221-2401
0221-2401
    WAGO(万可电子)
    WAGO - 0221-2401 - TERMINAL BLOCK, PLUGGABLE, 2POS, 12AWG
0221-2401 数据手册
Data sheet | Item number: 221-2401 Inline splicing connector with lever; for all conductor types; 12 AWG (max.); 2-con­ ductor; transparent housing; white cover; Surrounding air temperature: max 85°C (T85); 4.00 mm²; transparent https://www.wago.com/221-2401 Color: transparent This connector is 12 AWG capable and ideal for installations in the North American market. Notes Note Available January 2022 . Electrical data Ratings per IEC/EN Ratings per UL Ratings per EN 60664 Nominal voltage (II/2) 450 V Rated surge voltage (II/2) 4 kV Rated current 32 A Legend (ratings) (II / 2) ≙ Overvoltage category II / Polluti­ on degree 2 Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 20 A . . Connection data Total number of connection points 2 Connection 1 . Connection technology CAGE CLAMP® Actuation type Lever Connectable conductor materials Copper Solid conductor 0.2 … 4 mm² / 20 … 12 AWG Stranded conductor 0.2 … 2.5 mm² / 18 … 12 AWG Fine-stranded conductor 0.34 … 4 mm² / 18 … 12 AWG Strip length 11 mm / 0.43 inches . Page 1/4 Version 20.04.2022 Continued on next page Data sheet | Item number: 221-2401 https://www.wago.com/221-2401 Physical data Width 8.1 mm / 0.319 inches Height 8.9 mm / 0.35 inches Depth 35.5 mm / 1.398 inches . Material data Note (material data) Information on material data can be found here Color transparent Cover color white Flammability class per UL94 V2 Fire load 0 MJ Actuator color orange Weight of insulation material 0.84 g Weight 2.3 g . Commercial data PU (SPU) 600 (60) Pieces Packaging type Box Country of origin VKOrg Germany DE GTIN 4055144067040 Customs tariff number VKOrg Germany 85369010000 . Approvals and certificates Country specific Approvals UL-Approvals Approval Standard Certificate name Approval Standard Certificate name CCA DEKRA Certification B.V. EN 60998 NTR NL-7827 UL 486C E69654 KEMA/KEUR DEKRA Certification B.V. EN 60998 71-113253 REV. 1 UL Underwriters Laboratories Inc. . . Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 221-2401 . Page 2/4 Version 20.04.2022 Continued on next page Data sheet | Item number: 221-2401 https://www.wago.com/221-2401 Documentation Additional Information Technical Section pdf 2142.18 KB . CAD/CAE-Data CAD data CAE data 2D/3D Models 221-2401 ZUKEN Portal 221-2401 . . 1 Compatible products 1.1 Optional accessories 1.1.1 Installation 1.1.1.1 Mounting accessories Item no.: 221-2501 Mounting carrier with strain relief; 1-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2511 Mounting carrier with strain relief; 1-way; for inline splicing connector with lever; with snap-in mounting foot; gray Item no.: 221-2502 Mounting carrier with strain relief; 2-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2512 Mounting carrier with strain relief; 2-way; for inline splicing connector with lever; with snap-in mounting foot; gray Item no.: 221-2503 Mounting carrier with strain relief; 3-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2513 Mounting carrier with strain relief; 3-way; for inline splicing connector with lever; with snap-in mounting foot; gray Item no.: 221-2504 Mounting carrier with strain relief; 4-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2514 Mounting carrier with strain relief; 4-way; for inline splicing connector with lever; with snap-in mounting foot; gray Item no.: 221-2505 Mounting carrier with strain relief; 5-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2515 Mounting carrier with strain relief; 5-way; for inline splicing connector with lever; with snap-in mounting foot; gray Item no.: 221-2521 Mounting carrier; 1-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2531 Mounting carrier; 1-way; for inline splicing connector with lever; with snap-in moun­ ting foot; gray Item no.: 221-2522 Mounting carrier; 2-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2532 Mounting carrier; 2-way; for inline splicing connector with lever; with snap-in moun­ ting foot; gray Item no.: 221-2523 Mounting carrier; 3-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2533 Mounting carrier; 3-way; for inline splicing connector with lever; with snap-in moun­ ting foot; gray Item no.: 221-2524 Mounting carrier; 4-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2534 Mounting carrier; 4-way; for inline splicing connector with lever; with snap-in moun­ ting foot; gray Item no.: 221-2525 Mounting carrier; 5-way; for inline splicing connector with lever; for screw mounting; gray Item no.: 221-2535 Mounting carrier; 5-way; for inline splicing connector with lever; with snap-in moun­ ting foot; gray . Page 3/4 Version 20.04.2022 Continued on next page Data sheet | Item number: 221-2401 https://www.wago.com/221-2401 Installation notes Conductor termination Push up the lever to open the clamping unit and insert the conductor. Push the lever back down. . Installation Place the inline splicing connector on the carrier in front of the mounting position. Push the connector to the center position until it snaps into place. . Application Perfect for test setups Simple extension of lines Lighting connection in suspended cei­ lings . Subject to changes. Please also observe the further product documentation! Current addresses can be found at: w w w.wago.com Page 4/4 Version 20.04.2022 Multi-pole, fixed lighting fixture wiring
0221-2401 价格&库存
很抱歉,暂时无法提供与“0221-2401”相匹配的价格&库存,您可以联系我们找货
