Printview: PCB terminal strip; 2 solder pins/pole; 10-pole; pin spacing 2.54 mm / 0.1 in; with push-button Item No.: 233-510
Item No.: 233-510
Marking
Business data
Supplier
WAGO
Item no.
233-510
GTIN / EAN
4045454050429
Content
1
Order amount
45
Customer item number
Notes
Terminal strips with push-button actuated CAGE CLAMP®Double solder pins for high mechanical stability on
PCBIdeal for in-the-field wiring thanks to simplified push-button actuationConvenient, tool-free operation
Technical data
Miscellaneous
No. of poles
10
Pin Spacing
2.54 mm / 0.1 in %
Total number of connection points
10
Total number of potentials
10
Color
orange
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
Pollution degree (1)
2
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Rated voltage EN (1) [V]
160 [V]
Rated surge voltage (1) [kV]
2.5 [kV]
Nominal current [A]
6 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
320 [V]
Rated surge voltage (2) [kV]
2.5 [kV]
Nominal current (2) [A]
6 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
63 [V]
Rated surge voltage (3) [kV]
2.5 [kV]
Nominal current (3) [A]
6 [A]
Number of individual connection objects at the product
1
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded wires 1
Fine-stranded wires with insulated ferrule 1
0.25 mm² / AWG
Fine-stranded wires with uninsulated ferrule 1
0.25 mm² / AWG
Strip length 1
5 … 6 mm / 0.2 … 0.24 in
Conductor entry angle to the PCB 1 [°]
30 [°]
Solder pin arrangement
in-line solder pin
Solder pin length [mm]
4 [mm]
Solder pin width A [mm]
0.5 [mm]
Solder pin width B [mm]
0.75 [mm]
Tolerance of drilled hole [mm]
1.1(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 105 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.074 [MJ]
2
Technical data
Weight [g]
4.062 [g]
Width
27.7 mm / 1.091 in
Height
19.5 mm / 0.768 in
Height from the surface
15.5 mm / 0.61 in
Length
13.9 mm / 0.547 in
3
Images & drawings
4
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
5
很抱歉,暂时无法提供与“0233-0510”相匹配的价格&库存,您可以联系我们找货
