0285-0635
    WAGO(万可电子)
0285-0635 数据手册
Printview: 2-conductor through terminal block; with integrated end plate - Item No.: 285-635 . 2-conductor through terminal block; with integrated end plate Item No.: 285-635 . 2-conductor through terminal block; with integrated end plate . Marking . Business data Supplier WAGO Item no. 285-635 GTIN / EAN 4045454218713 Content 1 Order amount 15 Customer item number . Notes Technical data Miscellaneous Total number of connection points 2 Total number of potentials 1 Color gray Ratings according to 1 IEC/EN 60947-7-1 Pollution degree (1) 3 Rated voltage EN (1) [V] 1000 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 125 [A] Connection technology (1) CAGE CLAMP® Nominal cross section 1 35 mm² WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 2-conductor through terminal block; with integrated end plate - Item No.: 285-635 Technical data Solid sizes 1 6 … 35 mm² / 8 … 2 AWG Fine-stranded wires 1 6 … 35 mm² / 8 … 2 AWG Strip length 1 23 mm / 0.91 in Strip length 2 16 mm / 0.63 in Type of wiring Front-entry wiring Design horizontal Marking level Center/Side marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 1.078 [MJ] Weight [g] 88.2 [g] Width 16 mm / 0.63 in Height from upper-edge of DIN-rail [mm] 53 [mm] Height from upper-edge of DIN-rail 53 mm / 2.087 in Length 100 mm / 3.937 in Type of mounting DIN 35 rail Safety information 1 only on DIN 35 x 15 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 2-conductor through terminal block; with integrated end plate - Item No.: 285-635 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 2-conductor through terminal block; with integrated end plate - Item No.: 285-635 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
0285-0635 价格&库存
很抱歉,暂时无法提供与“0285-0635”相匹配的价格&库存,您可以联系我们找货
