Data sheet | Item number: 2001-1302
3-conductor through terminal block; 1.5 mm²; suitable for Ex e II
applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Pushin CAGE CLAMP®; 1,50 mm²; orange
www.wago.com/2001-1302
Color:
Data
Electrical data
Ratings
per IEC/EN
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
21.06.2021 Page 1/19
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated current
18 A
Rated current 2
24 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
15 A
Ratings per CSA
Approvals per
C22.2 No 158
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group C)
15 A
Ex information
Ratings per
ATEX: PTB 05 ATEX 1094 U / IECEx: PTB 05.0034U (Ex eb IIC Gb)
Rated voltage EN (Ex e II)
550 V
Rated current (Ex e II)
17 A
Rated current (Ex e II) with jumper
16 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-in
Open Tool Slot
Connectable conductor materials
Copper
Nominal cross-section
1.5 mm²
Solid conductor
0.25 … 2.5 mm² / 22 … 14 AWG
Solid conductor; push-in termination
0.75 … 2.5 mm² / 18 … 14 AWG
Fine-stranded conductor
Hansastr. 27
32423 Minden
21.06.2021 Page 2/19
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor; with ferrule; push-in termination
0.75 … 1.5 mm² / 18 … 16 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
9 … 11 mm / 0.35 … 0.43 inch
Total number of connection points
3
Total number of potentials
1
Number of levels
1
Wiring type
Front-entry wiring
Number of jumper slots
2
Physical data
Width
4.2 mm / 0.165 inch
Height
59.2 mm / 2.33 inch
Depth from upper edge of DIN-rail
32.9 mm / 1.295 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Center/side marking
Material data
Color
orange
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.092 MJ
Weight
4.9 g
Commercial data
Product Group
22 (TOPJOB S)
Packaging type
BOX
Country of origin
DE
GTIN
4017332998642
Customs tariff number
85369010000
Approvals / Certificates
Hansastr. 27
32423 Minden
21.06.2021 Page 3/19
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
ATEx
Physikalisch Technische Bundesanstalt (PTB)
EN 60079
PTB 05 ATEX 1094
U (II 2 G Ex e II bzw.I
M 2 Ex e I)
CCCEx
CQST/CNEx
CNCA-C23-01
2020312313000159
EAC
Brjansker Zertifizierungsstelle
TP TC 012/2011
RU C-DE.AM02.B.
00127/19
IECEx
IEC 60079
IECEx PTB 05. 0034
U (Ex eb IIC Gb or Ex
eb I Mb)
Country specific Approvals
Logo
Approval
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2160584.07
CCA
EN 60947
NTR NL7084
CSA
C22.2 No. 158
1645434
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
Certificate
name
Hansastr. 27
32423 Minden
21.06.2021 Page 4/19
LR
Lloyds Register
EN 60947
91/20112
(E9)
UL-Approvals
Logo
Approval
UL
UL International Germany GmbH
UL 1059
Certificate
name
20190731E45172
Required accessories
End plate
Item no.: 2002-1391
End and intermediate plate; 0.8 mm thick; gray
www.wago.com/2002-1391
Item no.: 2002-1392
End and intermediate plate; 0.8 mm thick; orange
www.wago.com/2002-1392
Optional accessories
End plate
Item no.: 2002-1393
Seperator plate; 2 mm thick; oversized; gray
www.wago.com/2002-1393
Item no.: 2002-1394
Seperator plate; 2 mm thick; oversized; orange
www.wago.com/2002-1394
Item no.: 209-191
Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange
www.wago.com/209-191
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Ferrule
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
Hansastr. 27
32423 Minden
21.06.2021 Page 5/19
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Insulation stop
Item no.: 2001-171
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/2001-171
Testing and measuring
Item no.: 2001-511
Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 1,50 mm²; gray
www.wago.com/2001-511
Item no.: 2001-549
Spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/2001-549
Item no.: 2001-552
Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 1,50 mm²; gray
www.wago.com/2001-552
Item no.: 2001-553
Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 1,50 mm²; gray
www.wago.com/2001-553
Item no.: 2001-554
Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 1,50 mm²; gray
www.wago.com/2001-554
Item no.: 2001-555
Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 1,50 mm²; gray
www.wago.com/2001-555
Item no.: 2001-556
Modular TOPJOB®S connector; modular; for jumper contact slot; 6-pole; 1,50 mm²; gray
www.wago.com/2001-556
Item no.: 2001-557
Modular TOPJOB®S connector; modular; for jumper contact slot; 7-pole; 1,50 mm²; gray
www.wago.com/2001-557
Item no.: 2001-558
Modular TOPJOB®S connector; modular; for jumper contact slot; 8-pole; 1,50 mm²; gray
www.wago.com/2001-558
Item no.: 2001-559
Modular TOPJOB®S connector; modular; for jumper contact slot; 9-pole; 1,50 mm²; gray
www.wago.com/2001-559
Item no.: 2001-560
Modular TOPJOB®S connector; modular; for jumper contact slot; 10-pole; 1,50 mm²; gray
www.wago.com/2001-560
Item no.: 2009-174
Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray
www.wago.com/2009-174
Item no.: 2009-182
Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray
www.wago.com/2009-182
Item no.: 2001-402
Jumper; 2-way; insulated; light gray
www.wago.com/2001-402
Jumpers
Item no.: 2001-403
Hansastr. 27
32423 Minden
21.06.2021 Page 6/19
Item no.: 2001-403
Jumper; 3-way; insulated; light gray
www.wago.com/2001-403
Item no.: 2001-404
Jumper; 4-way; insulated; light gray
www.wago.com/2001-404
Item no.: 2001-405
Jumper; 5-way; insulated; light gray
www.wago.com/2001-405
Item no.: 2001-405/011-000
Star point jumper; 3-way; insulated; light gray
/011-000
Item no.: 2001-406
Jumper; 6-way; insulated; light gray
www.wago.com/2001-406
Item no.: 2001-406/020-000
Delta jumper; insulated; light gray
/020-000
Item no.: 2001-407
Jumper; 7-way; insulated; light gray
www.wago.com/2001-407
Item no.: 2001-408
Jumper; 8-way; insulated; light gray
www.wago.com/2001-408
Item no.: 2001-409
Jumper; 9-way; insulated; light gray
www.wago.com/2001-409
Item no.: 2001-410
Jumper; 10-way; insulated; light gray
www.wago.com/2001-410
Item no.: 2001-433
Jumper; from 1 to 3; insulated; light gray
www.wago.com/2001-433
Item no.: 2001-434
Jumper; from 1 to 4; insulated; light gray
www.wago.com/2001-434
Item no.: 2001-435
Jumper; from 1 to 5; insulated; light gray
www.wago.com/2001-435
Item no.: 2001-436
Jumper; from 1 to 6; insulated; light gray
www.wago.com/2001-436
Item no.: 2001-437
Jumper; from 1 to 7; insulated; light gray
www.wago.com/2001-437
Item no.: 2001-438
Jumper; from 1 to 8; insulated; light gray
www.wago.com/2001-438
Item no.: 2001-439
Jumper; from 1 to 9; insulated; light gray
www.wago.com/2001-439
Item no.: 2001-440
Jumper; from 1 to 10; insulated; light gray
Hansastr. 27
32423 Minden
www.wago.com/2001-440
21.06.2021 Page 7/19
Item no.: 2006-499
Step-down jumper; insulated; light gray
www.wago.com/2006-499
Item no.: 210-103
Wire commoning chain; insulated; black
www.wago.com/210-103
Item no.: 210-123
Wire commoning chain; insulated; blue
www.wago.com/210-123
Push-in type wire jumper
Item no.: 2009-412
Push-in type wire jumper; insulated; 60 mm long; black
www.wago.com/2009-412
Item no.: 2009-414
Push-in type wire jumper; 1.5 mm²; insulated; 110 mm long; black
www.wago.com/2009-414
Item no.: 2009-414/000-005
/000-005
Item no.: 2009-414/000-006
Push-in type wire jumper; insulated; 110 mm long; black
/000-006
Item no.: 2009-416
Push-in type wire jumper; 1.5 mm²; insulated; 250 mm long; black
www.wago.com/2009-416
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-647
Item no.: 210-648
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short
www.wago.com/210-648
Item no.: 210-719
www.wago.com/210-719
Tool
Carrier rail
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-118
Hansastr. 27
32423 Minden
21.06.2021 Page 8/19
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Marking accessories
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-114
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; white
www.wago.com/2009-114
Item no.: 2009-114/000-002
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-114/000-005
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-114/000-006
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-114/000-007
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-114/000-012
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-114/000-023
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-114/000-024
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; violet
/000-024
Item no.: 793-4501
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; white
www.wago.com/793-4501
Item no.: 793-4501/000-002
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; yellow
/000-002
Hansastr. 27
32423 Minden
21.06.2021 Page 9/19
Item no.: 793-4501/000-005
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-4501/000-006
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-4501/000-007
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-4501/000-012
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-4501/000-017
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; green
/000-017
Item no.: 793-4501/000-023
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; light green
/000-023
Item no.: 793-4501/000-024
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; violet
/000-024
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Hansastr. 27
32423 Minden
21.06.2021 Page 10/19
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Protective warning marker
Item no.: 2001-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2001-115
Downloads
Documentation
Bid Text
2001-1302
2018 Aug 2
docx
15.1 kB
Download
2019 Feb 19
xml
4.0 kB
Download
2019 Apr 3
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 2001-1302
URL
Download
ZUKEN Portal 2001-1302
URL
Download
WSCAD Universe 2001-1302
URL
Download
docx - Datei
2001-1302
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 2001-1302
CAE data
Hansastr. 27
32423 Minden
21.06.2021 Page 11/19
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2001-1302
URL
Download
3-conductor through terminal block; 1.5 mm²; suitable for Ex e II applications; side
and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 1,50
mm²; orange
Installation Notes
Inserting a conductor
All conductor types at a glance
Push-in termination of solid and ferruled
conductors
Inserting a conductor via push-in
termination:
Solid conductors with cross-sections from
either one size above, or up to two sizes
below, the rated cross-section can be simply
pushed in – no tools needed.
Hansastr. 27
32423 Minden
21.06.2021 Page 12/19
Inserting a conductor via operating tool:
Conductor termination – insulation stop
Connecting fine-stranded conductors
without ferrules, or small cross-sectional
conductors that cannot be pushed in, is
performed similarly to the original CAGE
CLAMP® – just use an operating tool.
Advantage:
To open the clamp, the operating tool is
inserted vertically. The conductor entry is
less than 15 degrees for easier wiring.
Commoning
Hansastr. 27
32423 Minden
21.06.2021 Page 13/19
The push-in type jumper bar system is based
on the common plug and socket principle.
Each terminal block is spring-loaded with a
double socket and a resilient CrNi steel
spring. The jumper contact material is pure
electrolytic copper, which allows for an
extremely small design capable of carrying
the full-rated current of the terminal block.
Ground terminal blocks can also be
commoned using the same jumper system.
Custom jumpers are created by breaking
and removing jumper contacts (2000, 2001,
2002, 2004 Series).
Removing a push-in type jumper bar:
Insert the operating tool between the jumper
and partition wall of the dual jumper slots,
then lift up the jumper.
Place the operating tool in the center of
jumpers for up to five contacts (see above),
or alternately on both sides for jumpers with
more than five contacts.
Commoning
This star point jumper has been specially
developed to create a “star point” and is
used on motor terminal boards equipped
with TOPJOB® S Rail-Mount Terminal Blocks.
This delta jumper has been specially
developed to create a delta configuration
and is used on motor terminal boards
equipped with TOPJOB® S rail-mount
terminal blocks.
Push down the wire jumper until fully
inserted. Lift the jumper with an operating
tool for rewiring.
Commoning
Hansastr. 27
32423 Minden
21.06.2021 Page 14/19
Step-down jumpers common terminal
blocks of different sizes, without losing a
conductor clamping point. This can be
beneficial on long conductor runs where
voltage drop can be a problem. A large
conductor can be easily connected to
smaller conductors at the distribution point.
Using step-down jumpers, an end plate
must be inserted between the terminal
blocks to be commoned.
Step-down jumper (2006-499) commons 6
/4 mm² (10/12 AWG) terminal blocks (2006
/2004 Series) with 4/2.5/1.5 mm² (AWG 12/14
/16) terminal blocks (2004/2002/2001
Series).
Commoning may be made in either direction
using the special thin end plate to cover the
open side. Additional through terminal
blocks having a smaller cross-section may
be commoned using push-in type jumper
bars.
Step-down jumper (2016‑499) commons 16
/10 mm² (16/8 AWG) terminal blocks (2016
/2010 Series) with 10/6/4/2.5 mm² (8/10/12
/14 AWG) terminal blocks (2010/2006/2004
/2002 Series).
Hansastr. 27
32423 Minden
21.06.2021 Page 15/19
Stepping down via push-in type jumper bar:
Note:
Commoning via open terminal side with end
plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and 10
mm² (8 AWG) and one cross-section size for
6/4/2.5 mm² (10/12/14 AWG). An example:
from 16 mm² (6 AWG) to 6 mm² (10 AWG)
(see illustration above) or from 10 mm² (8
AWG) to 4 mm² (12 AWG).
Commoning via closed terminal side with
end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to 6
mm² (10 AWG) or from 6 mm² (10 AWG) to
2.5 mm² (14 AWG) (see illustration above).
The total current of the outgoing circuits
must not exceed the nominal current of the
step-down jumper/push-in type jumper bar.
TOPJOB® S Connectors with a 2 mm Ø test
socket for testing voltage via 2-pole voltage
tester
Rail-mount terminal block assembly for
electric motor wiring
Testing
The modular TOPJOB® S connectors also
connect conductors of the same size as the
terminal blocks being used.
Hansastr. 27
32423 Minden
21.06.2021 Page 16/19
Test plug adapter (2009‑174, CAT I) for
4 mm Ø plugs – compatible with 2000 to
2016 Series
Testing tap (2009‑182) for tool-free
connection of test cables up to 2.5 mm² (12
AWG) – compatible with 2000 to 2016 Series
Marking
Snapping WMB Inline markers into marker
slots.
TOPJOB® S 2009‑193 Group Marker Carrier
(equipped with a marking strip) for all 2001 to
2016 Series TOPJOB® S Rail-Mount Terminal
Blocks
Do not use on an end plate!
Hansastr. 27
32423 Minden
21.06.2021 Page 17/19
Through terminal blocks with a blue
insulated housing are suitable for Ex i
applications.
All through and ground conductor terminal
blocks are suitable for Ex e II applications.
Separator plate for Ex e/Ex i applications
An end plate must be applied to the terminal
block located directly behind an Ex e/Ex i
separator plate.
Hansastr. 27
32423 Minden
21.06.2021 Page 18/19
Ex e II/Ex i terminal strip
A separator plate is located between the Ex
e II and Ex i terminal strip.
Note:
End plate
The movable feet of terminal blocks and
separator plates must face the same
direction.
Ex e II terminal blocks
End plate
Ex i terminal blocks
According to EN 50020, a minimum distance
of 50 mm must be kept between live parts of
Ex e and Ex i circuits. The use of Ex e/Ex i
separators is a space-saving solution when
Ex e and Ex i terminal blocks are mounted on
a common DIN-rail.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Hansastr. 27
32423 Minden
21.06.2021 Page 19/19
很抱歉,暂时无法提供与“2001-1302”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+15.43160100+1.92030
- 200+15.25320200+1.89810
- 300+15.16400300+1.88700
- 500+15.07480500+1.87590
- 1000+14.896401000+1.85370
