Printview: 2-conductor through terminal block; suitable for Ex e II applications - Item No.: 2010-1201
Item No.: 2010-1201
Marking
Business data
Supplier
WAGO
Item no.
2010-1201
GTIN / EAN
4017332076005
Content
1
Order amount
25
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
2
Total number of potentials
1
Color
gray
Ratings according to 1
IEC/EN 60947-7-1
Pollution degree (1)
3
Rated voltage EN (1) [V]
800 [V]
Rated surge voltage (1) [kV]
8 [kV]
Nominal current [A]
57 [A]
Nominal current (2) [A]
76 [A]
Rated voltage EN (Ex e II) [V]
550 [V]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Nominal current (Ex e II) [A]
51 [A]
Connection technology (1)
Push-in CAGE CLAMP®
Nominal cross section 1
10 mm²
Solid sizes 1
0.5 … 16 mm² / 20 … 6 AWG
solid, directly pluggable 1
2.5 … 16 mm² / 14 … 6 AWG
Fine-stranded wires 1
min. fine-stranded with insulated ferrule, push-in terminati 2.5 mm² / 14 AWG
Strip length 1
17 … 19 mm / 0.67 … 0.75 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.289 [MJ]
Weight [g]
17.112 [g]
Width
10 mm / 0.394 in
Height from upper-edge of DIN-rail [mm]
36.9 [mm]
36.9 mm / 1.453 in
Length
67.8 mm / 2.669 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2010-1201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+76.978461+10.00932
- 10+54.5748410+7.09624
- 25+48.1184225+6.25672
- 50+44.1749150+5.74396
- 100+40.96600100+5.32671
- 250+37.68232250+4.89974
- 500+35.79511500+4.65435
- 1000+34.318341000+4.46233
