Data sheet | Item number: 2010-1307
3-conductor ground terminal block; 10 mm²; suitable for Ex e II applications;
side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE
CLAMP®; 10,00 mm²; green-yellow
www.wago.com/2010-1307
Color:
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-2
Connection
data
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
18.05.2021 Page 1/15
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-in
Open Tool Slot
Connectable conductor materials
Copper
Nominal cross-section
10 mm²
Solid conductor
0.5 … 16 mm² / 20 … 6 AWG
Solid conductor; push-in termination
4 … 16 mm² / 14 … 6 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor; with ferrule; push-in termination
4 … 10 mm² / 12 … 8 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
17 … 19 mm / 0.67 … 0.75 inch
Total number of connection points
3
Total number of potentials
1
Number of levels
1
Wiring type
Front-entry wiring
Number of jumper slots
2
Physical data
Width
10 mm / 0.394 inch
Height
89 mm / 3.504 inch
Depth from upper edge of DIN-rail
36.9 mm / 1.453 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Center/side marking
Material data
Color
green-yellow
Insulation material
Polyamide (PA66)
Fire load
0.376 MJ
Weight
35.6 g
Commercial
data
Hansastr. 27
32423 Minden
18.05.2021 Page 2/15
Commercial data
Product Group
22 (TOPJOB S)
Packaging type
BOX
Country of origin
DE
GTIN
4017332076340
Customs tariff number
85369010000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
AEx
UL International Germany GmbH c/o Physikalisch
Technische Bundesanstalt
UL 60079
E185892 sec.21
ATEx
Physikalisch Technische Bundesanstalt (PTB)
EN 60079
PTB 05 ATEX 1070
U (II 2 G Ex eII bzw.I
M2 Ex eI)
CCCEx
CQST/CNEx
CNCA-C23-01
2020312313000161
EAC
Brjansker Zertifizierungsstelle
TP TC 012/2011
RU C-DE.AM02.B.
00127/19
IECEx
IEC 60079
IECEx PTB 06.0003
U (Ex e IIC Gb and
Ex e I Mb)
Country specific Approvals
Logo
Certificate
name
Approval
CCA
DEKRA Certification B.V.
EN 60947
NTR NL
7737
CSA
C22.2 No. 158
70111238
KEMA/KEUR
EN 60947
Hansastr. 27
32423 Minden
71-
18.05.2021 Page 3/15
KEMA/KEUR
EN 60947
71108310
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
20HG1941090PDA
BV
Bureau Veritas S.A.
EN 60947
38586/A0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
UL-Approvals
Logo
Approval
UL
Underwriters Laboratories Inc.
UL 1059
Certificate
name
20190731E45172
Required accessories
End plate
Item no.: 2010-1391
End and intermediate plate; 1 mm thick; gray
www.wago.com/2010-1391
Item no.: 2010-1392
End and intermediate plate; 1 mm thick; orange
www.wago.com/2010-1392
Hansastr. 27
32423 Minden
18.05.2021 Page 4/15
Compatible products
End plate
Item no.: 209-191
Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange
www.wago.com/209-191
Item no.: 2010-402
Jumper; 2-way; insulated; light gray
www.wago.com/2010-402
Item no.: 2010-403
Jumper; 3-way; insulated; light gray
www.wago.com/2010-403
Item no.: 2010-404
Jumper; 4-way; insulated; light gray
www.wago.com/2010-404
Item no.: 2010-405
Jumper; 5-way; insulated; light gray
www.wago.com/2010-405
Item no.: 2010-405/011-000
Star point jumper; 3-way; insulated; light gray
/011-000
Item no.: 2010-433
Jumper; from 1 to 3; insulated; light gray
www.wago.com/2010-433
Item no.: 2010-434
Jumper; from 1 to 4; insulated; light gray
www.wago.com/2010-434
Item no.: 2010-435
Jumper; from 1 to 5; insulated; light gray
www.wago.com/2010-435
Item no.: 285-430
Step-down jumper; insulated; gray
www.wago.com/285-430
Jumper
Protective Warning Marker
Item no.: 2010-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2010-115
Item no.: 2016-115
www.wago.com/2016-115
Item no.: 216-284
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-284
Item no.: 216-286
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-286
ferrule
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
acc. to DIN 46228, Part 4/09.90; gray
Hansastr. 27
32423 Minden
18.05.2021 Page 5/15
Item no.: 216-288
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-289
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289
acc. to DIN 46228, Part 4/09.90; red
protection
Item no.: 2010-100
Finger guard; touchproof cover protects unused conductor entries; yellow
www.wago.com/2010-100
Marking accessories
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-145
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-145/000-002
Hansastr. 27
32423 Minden
18.05.2021 Page 6/15
yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007
Item no.: 2009-145/000-012
orange
/000-012
Item no.: 2009-145/000-023
green
/000-023
Item no.: 2009-145/000-024
violet
/000-024
Item no.: 2009-191
Group marker carrier
www.wago.com/2009-191
Item no.: 2009-192
www.wago.com/2009-192
Item no.: 2009-193
www.wago.com/2009-193
Item no.: 2009-198
Adaptor; gray
www.wago.com/2009-198
Item no.: 248-501
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Hansastr. 27
32423 Minden
18.05.2021 Page 7/15
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
Hansastr. 27
32423 Minden
18.05.2021 Page 8/15
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501/000-007
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
check
Item no.: 2009-174
Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray
www.wago.com/2009-174
Item no.: 2009-182
Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray
www.wago.com/2009-182
Item no.: 2010-511
Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 10,00 mm²; gray
www.wago.com/2010-511
Item no.: 2010-549
Spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/2010-549
tools
Item no.: 210-721
Hansastr. 27
32423 Minden
18.05.2021 Page 9/15
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-721
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Carrier rail
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Downloads
Documentation
Bid Text
2010-1307
Apr 17, 2019
docx
15.2 kB
Download
Apr 17, 2019
xml
3.9 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 2010-1307
URL
Download
WSCADto
Universe
2010-1307
Subject
changes.
URL
Download
docx - Datei
2010-1307
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 2010-1307
CAE data
Hansastr. 27
32423 Minden
18.05.2021 Page 10/15
WSCAD Universe 2010-1307
URL
Download
ZUKEN Portal 2010-1307
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2010-1307
3-conductor ground terminal block; 10 mm²; suitable for Ex e II applications; side and
center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 10,00 mm²;
green-yellow
Installation Notes
Conductor termination
All conductor types at a glance
Push-in termination of solid and ferruled
conductors
Inserting a conductor via push-in
termination:
Solid conductors with cross-sections from
either one size above, or up to two sizes
below, the rated cross-section can be simply
pushed in – no tools needed.
Hansastr. 27
32423 Minden
18.05.2021 Page 11/15
Inserting a conductor via operating tool:
Connecting fine-stranded conductors
without ferrules, or small cross-sectional
conductors that cannot be pushed in, is
performed similarly to the original CAGE
CLAMP® – just use an operating tool.
Advantage:
To open the clamp, the operating tool is
inserted vertically. The conductor entry is
less than 15 degrees for easier wiring.
Commoning
Hansastr. 27
32423 Minden
18.05.2021 Page 12/15
The push-in type jumper bar system is based
on the common plug and socket principle.
Each terminal block is spring-loaded with a
double socket and a resilient CrNi steel
spring. The jumper contact material is pure
electrolytic copper, which allows for an
extremely small design capable of carrying
the full-rated current of the terminal block.
Ground terminal blocks can also be
commoned using the same jumper system.
Custom jumpers are created by breaking
and removing jumper contacts (2000, 2001,
2002, 2004 Series).
Removing a push-in type jumper bar:
Insert the operating tool between the jumper
and partition wall of the dual jumper slots,
then lift up the jumper.
Place the operating tool in the center of
jumpers for up to five contacts (see above),
or alternately on both sides for jumpers with
more than five contacts.
Commoning
This star point jumper has been specially
developed to create a “star point” and is
used on motor terminal boards equipped
with TOPJOB® S Rail-Mount Terminal Blocks.
Testing
Hansastr. 27
32423 Minden
18.05.2021 Page 13/15
The modular TOPJOB® S connectors also
connect conductors of the same size as the
terminal blocks being used.
TOPJOB® S Connectors with a 2 mm Ø test
socket for testing voltage via 2-pole voltage
tester
Test plug adapter (2009‑174, CAT I) for
4 mm Ø plugs – compatible with 2000 to
2016 Series
Testing tap (2009‑182) for tool-free
connection of test cables up to 2.5 mm² (12
AWG) – compatible with 2000 to 2016 Series
Rail-mount terminal block assembly for
electric motor wiring
Marking
Snapping WMB Inline markers into marker
slots.
Hansastr. 27
32423 Minden
18.05.2021 Page 14/15
TOPJOB® S 2009‑193 Group Marker Carrier
(equipped with a marking strip) for all 2001 to
2016 Series TOPJOB® S Rail-Mount Terminal
Blocks
Do not use on an end plate!
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Hansastr. 27
32423 Minden
18.05.2021 Page 15/15
很抱歉,暂时无法提供与“2010-1307”相匹配的价格&库存,您可以联系我们找货
