2060-901
2060-901
    WAGO(万可电子)
2060-901 数据手册
Data sheet  |  Item number: 2060-901 Board-to-Board Link; Pin spacing 4 mm; 1-pole; Length: 26 mm; light gray www.wago.com/2060-901 Color: Item description Board-to-board links simplify LED module assembly Easy push-in connection and disconnection Recommendation: Only suitable for 2060-40x, not for 2060-45x. Data Electrical data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 1/6 Data sheet  |  Item number: 2060-901 www.wago.com/2060-901 Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 63 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 9  A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1977 Rated voltage UL 1977 250 V Rated current UL 1977 9  A Connection data Pole No. 1 Total number of potentials 1 Geometrical Data Pin spacing 4 mm / 0.157 inch Width 3,4 mm / 0.134 inch Height 2,6 mm / 0.102 inch Depth 26 mm / 1.024 inch Mechanical data Mating cycles (max.) 10 Number of mating cycles max. 10 connections/disconnections Suitable for SMD PCB Terminal Blocks; 2060 Series Material Data Color light gray Material group I Insulation material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Copper alloy Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 2/6 Data sheet  |  Item number: 2060-901 www.wago.com/2060-901 Flammability class per UL94 V0 Contact material Copper alloy Contact plating silver-plated Fire load 0.001 MJ Weight 0.2 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Product Group 33 (Printed Circuit) Packaging type BOX GTIN 4050821460671 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7724 CCA DEKRA Certification B.V. EN 60998 NTR NL 7725 CCA DEKRA Certification B.V. EN 60838 NTR NL 2168246 KEMA/KEUR DEKRA Certification B.V. EN 60838 2168246.01 KEMA/KEUR DEKRA Certification B.V. EN 60998 71-108181 KEMA/KEUR DEKRA Certification B.V. EN 60947 71-108183 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 3/6 Data sheet  |  Item number: 2060-901 www.wago.com/2060-901 UL-Approvals Logo Approval Additional Approval Text cURus Underwriters Laboratories Inc. UL 1977 Certificate name 20160727E45171 Counterpart Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2060-901 Handling Instructions Installation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 4/6 Data sheet  |  Item number: 2060-901 www.wago.com/2060-901 Inserting a board-to-board link into the terminal block. Installation Assembly: Place PCBs on a flat surface and connect terminal blocks on adjoining PCBs via board-to-board link. Disassembly: Pull PCBs apart (max. 10 mating cycles). Installation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 5/6 Data sheet  |  Item number: 2060-901 www.wago.com/2060-901 The PCBs must be secured. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 6/6
2060-901 价格&库存
很抱歉,暂时无法提供与“2060-901”相匹配的价格&库存,您可以联系我们找货
