2091-1108
2091-1108
    WAGO(万可电子)
    P=3.5mm
    接线端子 间距:3.50mm 1x8P
2091-1108 数据手册
Data sheet  |  Item number: 2091-1108 1-conductor female plug; Gripping plate; 1.5 mm²; Pin spacing 3.5 mm; 8pole www.wago.com/2091-1108 L = (Polzahl – 1 ) x Rastermaß Color: Item description Universal connection for all conductor types Simple, push-in termination of solid and ferruled conductors Easy-to-use design does not require specialty tools Ability to wire while mated or unmated Test port parallel to conductor entry – touch contact Integrated locking latches prevent accidental disconnection 24.06.2019    Page 1/5 Data sheet  |  Item number: 2091-1108 www.wago.com/2091-1108 Integrated locking latches prevent accidental disconnection Safety information 1: The picoMAX® pluggable connection system is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 160 V Rated impulse voltage (III / 3) 2.5 kV Rated voltage (III / 2) 160 V Rated impulse voltage (III / 2) 2.5 kV Rated voltage (II / 2) 320 V Rated impulse voltage (II / 2) 2.5 kV Rated current 10 A Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.2 … 1.5 mm² / 24 … 14 AWG Fine-stranded conductor 0.2 … 1.5 mm² / 24 … 14 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 0.75 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 1.5 mm² Strip length 8 … 9 mm / 0.31 … 0.35 inch No. of poles 8 Total number of connection points 8 Total number of potentials 8 Number of connection types 1 Number of levels 1 Leiterquerschnitte eindrähtig 0.2 mm² 24.06.2019    Page 2/5 Data sheet  |  Item number: 2091-1108 www.wago.com/2091-1108 Geometrical Data Pin spacing 3.5 mm / 0.138 inch Width 28 mm / 1.102 inch Height 33 mm / 1.299 inch Depth 11.4 mm / 0.449 inch Mechanical data Design With gripping plate Plug connection Contact type (pluggable connector) Female connector/socket Connector connection type for conductors Mismating protection No Material Data Color light gray Material group I Insulating material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.094 MJ Weight 3.8 g Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 26 (picoMAX) Country of origin DE GTIN 4050821160724 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB IEC 61984 NL-49736 24.06.2019    Page 3/5 Data sheet  |  Item number: 2091-1108 www.wago.com/2091-1108 CB DEKRA Certification B.V. IEC 61984 NL-49736 CSA DEKRA Certification B.V. C22.2 2362521 KEMA/KEUR DEKRA Certification B.V. EN 61984 71102260 Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 UR Underwriters Laboratories Inc. UL 1977 20170428E45171 UR Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Compatible products Coding Item no.: 2091-1610 Coding key carrier; suitable for 3.5 mm pin spacing www.wago.com/2091-1610 Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Item no.: 210-719 Operating tool with partially insulated shaft; Type 1, blade (2.5 x 0.4) mm www.wago.com/210-719 check tools Downloads Documentation Additional Information Technical explanations 03-Apr-2019 pdf Download 24.06.2019    Page 4/5 Data sheet  |  Item number: 2091-1108 www.wago.com/2091-1108 Technical explanations 03-Apr-2019 pdf 3.6 MB Download URL Download CAD/CAE - Smart Data CAD data 3D Download 2091-1108 Product family picoMAX Learn more about the product family. Show all products from the family   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at {0}. 24.06.2019    Page 5/5
2091-1108 价格&库存
很抱歉,暂时无法提供与“2091-1108”相匹配的价格&库存,您可以联系我们找货
