Data sheet from 02.02.2009
Item no.:
231-104/031-000
Product description:
FEMALE PLUG; WITH FIXING FLANGE; 4 POLE; PIN
SPACING 5 MM / 0.197 IN; WITH CODIG FINGERS; WITH
INTEGRATED FIXING FLANGES
Packing unit 50 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
5 mm
Pin spacing from
0,197 in
pole count
4
Cross section from [mm²]
0,08 mm²
Cross section to [mm²]
2,5 mm²
Cross section from [AWG]
28 AWG
Cross section to [AWG]
12 AWG
Connection method
CAGE CLAMP®CONNECTION
Measured voltage EN
250 V
Measured shock voltage
4 kV
Pollution degree
3
Current intensity EN
16 A
Weight
8,036 g
Color
grey
No. of connection Points
4
No. of potentials
4
Height
14,3 mm
Height
0,563 in
Width
34,8 mm
Width
1,37 in
Depth
26,45 mm
1 von 3
Depth
1,041 in
Strip length from
8 mm
Strip length to
9 mm
Strip length
0,33 in
2 von 3
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
231-104/031-000
ABS
04-HG469925-PDA
400
16
5,0
231-104/031-000
BV
11915/A0
400
16
2,5
231-104/031-000
CCA
5764
250
16
0,08-2,5
231-104/031-000
CSA
154112-1466354
300
15
22-12
231-104/031-000
DEMKO
88126
250
16
2,5
231-104/031-000
GL
17296-00HH
400
16
5,0
231-104/031-000
KEMA
2083746.02
250
16
0,08-2,5
231-104/031-000
KR
HMB05880-EL003
250/400
12/16
2,5
231-104/031-000
LR
96/20035
400
16
5,0
231-104/031-000
NEMKO
P94101840
250
231-104/031-000
RMR
11130002
400
16
5,0
231-104/031-000
UR
E45171
600
15
12
231-104/031-000
UR
E45172
300
15
22-12
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
2,5
很抱歉,暂时无法提供与“231-104/031-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+81.316351+10.57087
