231-380/001-000
231-380/001-000
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 1x20P 间距:5.08mm 排数:1 每排Pin数:20
231-380/001-000 数据手册
Wago Online Katalog Page 1 of 1 Data sheet Item no.: Product description: 231-380/001-000 HEADER; STRAIGHT SOLDER PIN, 1.2 X 1.2 MM /0.047 X 0.047 IN; 20 POLE; PIN SPACING 5.08 MM / 0.2 IN; MATING DIRECTION PERPENDICULAR TO PCB; WITH CLOSED END Packing unit 50 5*10 pieces Pin spacing from Pin spacing from pole count Voltage CSA Voltage UL Current UL Current CSA Measured voltage EN Measured shock voltage Pollution degree Current intensity EN Weight Color Height Height Width Width Depth Depth 5,08 mm 0,2 in 20 300 V 300 V 15 A 15 A 250 V 4 kV 3 16 A 7,92 g orange 12 mm 0,472 in 104,8 mm 4,126 in 8,4 mm 0,331 in © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 5/28/2006
231-380/001-000 价格&库存
很抱歉,暂时无法提供与“231-380/001-000”相匹配的价格&库存,您可以联系我们找货
