Data sheet from 26.01.2009
Item no.:
237-136
Product description:
MODULAR TERMINAL BLOCK; WITH WIRE PROTECTION; 6
POLE; PIN SPACING 5 MM / 0.197 IN; SCREW CLAMP
CONNECTION
Packing unit 300 3*100 pieces
Product group
4 (Printed Circuit)
Pin spacing from
5 mm
Pin spacing from
0,197 in
pole count
6
Cross section from [mm²]
0,5 mm²
Cross section to [mm²]
2,5 mm²
Cross section from [AWG]
20 AWG
Cross section to [AWG]
14 AWG
Connection method
SCREW CONNECTION
Measured voltage EN
250 V
Measured shock voltage
2,5 kV
Pollution degree
2
Current intensity EN
16 A
Weight
5,716 g
Color
grey
Wiring type
Side-entry
No. of connection Points
6
No. of potentials
6
Height
11 mm
Height
0,433 in
Width
5 mm
Width
0,197 in
1 von 3
Depth
9 mm
Depth
0,354 in
Strip length from
5 mm
Strip length to
7 mm
Strip length
0,24 in
2 von 3
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
237-136
CBcertificateINDIEN
98-02629
250
16
0,5-2,5
237-136
CCA
NL6290
250
24
0,5-2,5
237-136
CSA
18677-6
300
10
20-14
237-136
KEMA
110204.13
250
24
0,5-2,5
237-136
RMR
11130002
250
16
0,5-2,5
237-136
UR
E45172
150
10
18-14
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
很抱歉,暂时无法提供与“237-136”相匹配的价格&库存,您可以联系我们找货
