2604-3105
2604-3105
    WAGO(万可电子)
    插件,P=5mm
    接线端子 间距:5.00mm 每排针脚数:5 排数:单排
2604-3105 数据手册
Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® - Item No.: 2604-3105 . PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5pole; Push-in CAGE CLAMP® Item No.: 2604-3105 . PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® . Marking . Business data Supplier WAGO Item no. 2604-3105 GTIN / EAN 4055143564748 Content 1 Order amount 70 Customer item number . Notes Item description:PCB terminal blocks with lever-actuated Push-in CAGE CLAMP® connectionPush-in termination of solid and ferruled conductorsIntuitive and tool-free operationSeveral clamping units can be held open simultaneously – convenient for terminating multi-core cablesTesting can be performed both parallel and perpendicular to conductor entry Technical data Miscellaneous Available upon request (depending on quantity required): Other pole numbers Packaging type BOX WAGO Kontakttechnik GmbH & Co. KG 1 Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® - Item No.: 2604-3105 Technical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) [V] 320 [V] Rated impulse voltage (III / 3) [kV] 4 [kV] Rated voltage (III/2) [V] 400 [V] Rated impulse voltage (III / 2) [kV] 4 [kV] Rated voltage (II / 2) [V] 630 [V] Rated impulse voltage (II / 2) [kV] 4 [kV] Rated current [A] 32 [A] Legend (ratings) (III / 2) Overvoltage category III / Pollution degree 2 No. of poles 5 Total number of connection points 5 Total number of potentials 5 Number of connection types 1 Number of levels 1 Connection technology Push-in CAGE CLAMP® Actuation type Operating lever Solid conductor 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 2.5 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 2.5 mm² / … Strip length 9 … 11 mm / 0.35 … 0.43 Inch Conductor entry angle to the PCB [°] 90 [°] Pin spacing 5 mm (0.197 in) Width 27.4 mm / 1.079 Inch Height 25.3 mm / 0.996 Inch Height from the surface 21.3 mm / 0.839 Inch Depth 16.7 mm / 0.657 Inch Solder pin length [mm] 4 [mm] Solder pin dimensions 0.8 x 1 mm Drilled hole diameter (tolerance) [mm] 1.3(+ 0.1) [mm] PCB contact THT Solder pin arrangement over the entire terminal strip, in line Number of solder pins per potential 2 Color gray WAGO Kontakttechnik GmbH & Co. KG 2 Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® - Item No.: 2604-3105 Technical data Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.121 [MJ] Actuating element color orange Weight [g] 8.51 [g] Limit temperature range -60 … 105 °C Pin spacing from [mm] 5 [mm] Main product function PCB terminal block Product type PCB terminal blocks WAGO Kontakttechnik GmbH & Co. KG 3 Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® - Item No.: 2604-3105 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® - Item No.: 2604-3105 WAGO Kontakttechnik GmbH & Co. KG 5 Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® - Item No.: 2604-3105 WAGO Kontakttechnik GmbH & Co. KG 6 Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 5-pole; Push-in CAGE CLAMP® - Item No.: 2604-3105 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 7
2604-3105 价格&库存
很抱歉,暂时无法提供与“2604-3105”相匹配的价格&库存,您可以联系我们找货
    • 1+83.596661+10.77723
    • 10+59.2925810+7.64396
    • 25+52.3273325+6.74601
    • 50+48.0885750+6.19955
    • 100+44.64341100+5.75540
    • 250+41.12332250+5.30159
    • 500+39.10279500+5.04111
    • 1000+37.523161000+4.83746
    库存:180
