Data sheet | Item number: 2773-403
COMPACT splicing connector; for solid and stranded conductors; max. 4
mm²; 3-conductor; transparent housing; orange cover; Surrounding air
temperature: max 85°C (T85); 4,00 mm²; transparent
www.wago.com/2773-403
Item description
Advantages:
Convenient wiring via extremely compact design
Push-in termination of up to eight solid and stranded conductors
Conductor range: 0.75 … 4 mm² “s” and 1.5 … 4 mm² “st”
Any combination of conductor sizes is possible
PUSH WIRE® connection terminates solid (“s”) copper conductors
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60998
Nominal voltage (II/2)
450 V
Rated surge voltage (II/2)
4 kV
Rated current
32 A
Legend (ratings)
(II / 2) ≙ Overvoltage category II / Pollution degree 2
Ratings per UL
Approvals per
UL 486C
Rated voltage UL (Use Group C)
600 V
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
28.05.2021 Page 1/5
600 V
Rated current UL (Use Group C)
20 A
Connection data
Connection technology
PUSH WIRE®
Actuation type
Push-in
Connectable conductor materials
Copper
Solid conductor
0.75 … 4 mm² / 20 … 12 AWG
Stranded conductor
1.5 … 4 mm² / 18 … 12 AWG
Conductor diameter
1.6 … 2 mm
Strip length
13 mm / 0.51 inch
Total number of connection points
3
Total number of potentials
1
Wiring type
Side-entry wiring
Physical data
Width
16.4 mm / 0.646 inch
Height
6.3 mm / 0.248 inch
Depth
18.6 mm / 0.732 inch
Material data
Color
transparent
Cover color
orange
Flammability class per UL94
V2
Fire load
0.007 MJ
Weight
1.6 g
Environmental requirements
Surrounding air temperature (operation)
85 °C
Continuous operating temperature
-40 … +105 °C
Temperature marking per EN 60998
T85
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4055143927550
Customs tariff number
85369010000
Hansastr. 27
32423 Minden
28.05.2021 Page 2/5
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 60998
NL-49187
KEMA/KEUR
EN 60669
71101844
Approval
UL
Underwriters Laboratories Inc.
UL 467
UL-Approvals
Logo
Certificate
name
20180215E201573
Optional accessories
Mounting adapter
Item no.: 2773-500
Mounting carrier; for single- and double-row con.; 2773 Series; for DIN-35 rail mounting/screw
mounting; orange
www.wago.com/2773-500
Downloads
Documentation
Additional Information
Technical explanations
2019 Apr 3
pdf
2.2 MB
Download
Installation Notes
Conductor termination
Hansastr. 27
32423 Minden
28.05.2021 Page 3/5
Strip solid or stranded conductor to 13 mm
(0.51 inch).
The transparent housing shows if
conductors are fully inserted; within the
colored base, a clear port shows if the
conductor's strip length is correct.
Conductors are correctly stripped if the
clear port shows no bare conductor on the
unprinted connector side. Picture shows
center conductor with exceeded strip length.
Termination: Insert the stripped conductor
until it hits the backstop.
Removal: Hold solid conductor to be
removed and twist alternately left and right
while pulling the connector.
Solid conductors are inserted into the
connector by simply pushing them in.
Stranded conductors are inserted into the
Testing
Hansastr. 27
32423 Minden
28.05.2021 Page 4/5
Testing via test port opposite to conductor
entry.
Application
Thanks to their flat and compact design,
these connectors are ideal for wiring in flushmount switch boxes.
With six variants, always have the right
connector.
Hansastr. 27
32423 Minden
28.05.2021 Page 5/5
很抱歉,暂时无法提供与“2773-403”相匹配的价格&库存,您可以联系我们找货
