Printview: Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; with LED indicator;
AC/DC 24 V; 6 mm wide - Item No.: 281-512/281-501
x 25 mm; with LED indicator; AC/DC 24 V; 6 mm wide
Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; with LED indicator; AC/DC 24 V; 6 mm
wide
Marking
Business data
Supplier
WAGO
Item no.
281-512/281-501
GTIN / EAN
4050821276265
Content
1
Order amount
50
Customer item number
Notes
Safety information 1: Electrical ratings are given by the fuse and blown fuse indication.
Technical data
Miscellaneous
Color
gray
Rated voltage EN (1) [V]
250 [V]
Nominal current [A]
6.3 [A]
Marking level
Center marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.081 [MJ]
Weight [g]
6.679 [g]
Width
6 mm / 0.236 in
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Safety information 2
Leakage current in case of blown fuse: 5 … 20mA
2
Images & drawings
3
4
5
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
6
很抱歉,暂时无法提供与“281-512/281-501”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+288.112631+37.27177
- 10+244.9042810+31.68211
- 25+229.5707425+29.69848
- 50+218.6204150+28.28189
- 100+208.19288100+26.93293
- 250+195.17473250+25.24883
