2857-570/024-000
2857-570/024-000
    WAGO(万可电子)
    WAGO - 2857-570/024-000 - 3-PH PMM3X400/690V/RC M RTU 07AH1734
2857-570/024-000 数据手册
Data sheet | Item number: 2857-570/024-000 3-Phase Power Measurement Module; 3x400/690 V/RC; Modbus RTU; Digital output; Configuration via software; Supply voltage: 24 VDC www.wago.com/2857-570/024-000 i Picture differs from the item. Item description Short description:WAGO's 3-Phase Power Measurement Module in a DIN-rail-mount enclosure measures electrical data in three-phase supply networks – remotely from the control level. Measured variables such as active/apparent/reactive power, energy consumption, power factor, phase angle and frequency can be accessed via Modbus® interface. In addition, the measured variables can be stored on a microSD card. Features: Current measurement via Rogowski Coils RC xxx Mobile measurement and storage of measured values on microSD card Configuration and display of measured values during operation via configuration interface Compact device in DIN-rail-mount enclosure saves space used for building technology Communication of measured values via Modbus® interface Configurable digital signal output as pulse output Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 1/8 Data sheet | Item number: 2857-570/024-000 www.wago.com/2857-570/024-000 Note: Additional setting options via the WAGO Interface Configuration Software Data Technical data Configuration Configuration options WAGO Interface Configuration Software Input Input signal type Voltage Current Network configuration 3-phase power measurement with N-conductor (4-conductor) 3-phase power measurement without N-conductor (3-conductor) Input signal (voltage) AC  400 V (ULN); AC  690 V (ULL); AC 90 mV (WAGO Rogowski Coils RC xxx) Sensitivity 22.5 mV/kA (WAGO Rogowski Coils RC xxx) Measurement range (current) 4 x AC 4000 A (WAGO Rogowski Coils RC xxx) () Frequency range 45 … 65 Hz (Harmonics analysis: 0 … 3.3 kHz) Output – digital Switching voltage (DO) (max.) Supply voltage (applied) Continuous current (DO) (max.) 100 mA (no internal restriction) Configurable functions (DO) Threshold value switch Pulse output (S0 interface) Communication Communication Modbus® RTU Interface RS-485 (2-wire) via RJ-45 Number of devices (max.) 32 Addressing Via Interface configuration software Signal processing Measurement method True RMS measurement (measured value acquisition with 8 kHz) Measured variables (calculated) Line-to-line voltage Outputs Energy sources Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 2/8 Data sheet | Item number: 2857-570/024-000 www.wago.com/2857-570/024-000 Energy sources Power factors Mains frequency Harmonics analysis (up to 41st harmonic) Total harmonic distortion (THD) Signal form Any periodic signals (considering the threshold frequencies) Limit frequency 15.9 kHz Memory card type WAGO 758-879/000-3102 (microSD; 2 GB) Measurement error Transmission error (max.) ≤ 0.5 % for current and voltage (of the full scale value) Supply Power supply type 24 VDC Nominal supply voltage US DC 24 V (SELV) Supply voltage range ±30 % Power consumption at nominal supply voltage ≤ 50 mA (+ IDO) Safety and protection Line-to-neutral conductor voltage AC / DC 600 V Overvoltage category III Pollution degree 2 Safe isolation Input/supply and communication per EN 61010-1 Requirement (N input) Shall not be dangerously active Requirement (ILx input) Coils/converters with basic insulation Protection type IP20 Test voltage Test voltage (input/output/supply) AC 3.51 kV; 50 Hz; 1 min Connection data Connection type (1) Voltage Connection technology Push-in CAGE CLAMP® WAGO Connector WAGO 804 Series Solid conductor 0.25 … 2.5 mm² / 20 … 12 AWG Fine-stranded conductor 0.25 … 2.5 mm² / 22 … 12 AWG Strip length 10 … 11 mm / 0.39 … 0.43 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 3/8 Data sheet | Item number: 2857-570/024-000 www.wago.com/2857-570/024-000 Fine-stranded conductor 0.25 … 2.5 mm² / 22 … 12 AWG Strip length 10 … 11 mm / 0.39 … 0.43 inch Connection type 2 Current/Power supply/DO Connection technology 2 Push-in CAGE CLAMP® WAGO Connector 2 WAGO 741 Series Solid conductor 2 0.2 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor 2 0.2 … 1.5 mm² / 24 … 16 AWG Strip length 2 9 … 10 mm / 0.35 … 0.39 inch Connection type (3) Modbus® communication Pluggable connectors 2 x RJ-45 (daisy chain configuration) Physical data Width 72 mm / 2.835 inch Height from upper-edge of DIN-rail 55 mm / 2.165 inch Depth 90 mm / 3.54 inch Mechanical data Mounting type DIN-35 rail Material data Fire load 0.047 MJ Weight 117.6 g Environmental requirements Surrounding air temperature (operation) -40 … 70 °C Surrounding air temperature (storage) -40 … 85 °C Relative humidity 5 … 95 % (non-condensing) Standards and specifications Conformity marking CE EMC immunity to interference EN 61000-6-2 EMC emission of interference EN 61000-6-3 Standards/Specifications EN 61010-1 Commercial data PU (SPU) 1 Stück Packaging type box Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 4/8 Data sheet | Item number: 2857-570/024-000 www.wago.com/2857-570/024-000 Packaging type box Country of origin DE GTIN 4055143829199 Customs tariff number 85437090300 Approvals / Certificates Ship Approvals Logo Approval Additional Approval Text Certificate name DNV GL Det Norske Veritas, Germanischer Lloyd - TAA00001ZY Optional accessories Interface module Item no.: 289-175/790-108 Interface module; RJ-45; PCB terminal blocks, double-row; Cat. 5; in mounting carrier; with shield connection; with shield clamping saddle www.wago.com/289-175 /790-108 Item no.: 289-176 Interface module; RJ-45; with power jumper contacts; RJ-45; Cat. 5; in mounting carrier www.wago.com/289-176 Item no.: 758-879/000-3102 Memory Card SD Micro; 2 GByte www.wago.com/758-879 /000-3102 Memory card Cables and pluggable connectors Item no.: 750-923 Configuration cable; USB connector; Length: 2.5 m www.wago.com/750-923 Item no.: 750-923/000-001 Configuration cable; USB connector; Length: 5 m www.wago.com/750-923 /000-001 Item no.: 750-978/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief www.wago.com/750-978 /000-011 General accessories Item no.: 855-8001 Power tap; with fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); Phase Item no.: 855-8002 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/855-8001 www.wago.com/855-8002 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 5/8 Data sheet | Item number: 2857-570/024-000 www.wago.com/2857-570/024-000 Item no.: 855-8002 Power tap; without fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); N-conductor www.wago.com/855-8002 Item no.: 855-8003 Power tap; with fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); Phase www.wago.com/855-8003 Item no.: 855-8004 Power tap; without fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); N-conductor www.wago.com/855-8004 Item no.: 855-8006 Power tap; for busbar; with fuse; Mounting screw M6 www.wago.com/855-8006 Item no.: 855-8008 Power tap; for busbar; with fuse; Mounting screw M8 www.wago.com/855-8008 Item no.: 855-8015 Power tap; for busbar; with fuse; Clamping connection www.wago.com/855-8015 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Tool Power supplies Item no.: 787-2850 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 1.25 A output current www.wago.com/787-2850 Current transformers Item no.: 855-9150/2000-1251 Rogowski coil; Primary rated current 4000 A; Output signal 22.5 mV per kA; Cable length: 1.5 m; Feedthrough for measurement conductor 125 mm www.wago.com/855-9150 /2000-1251 Item no.: 855-9150/2000-1751 Rogowski coil; Primary rated current 4000 A; Output signal 22.5 mV per kA; Cable length: 1.5 m; Feedthrough for measurement conductor 175 mm www.wago.com/855-9150 /2000-1751 Item no.: 855-9150/2000-701 Rogowski coil; Primary rated current 4000 A; Output signal 22.5 mV per kA; Cable length: 1.5 m; Feedthrough for measurement conductor 70 mm www.wago.com/855-9150 /2000-701 Item no.: 855-9450/2000-1251 Rogowski coil; Primary rated current 4000 A; Output signal 22.5 mV per kA; Cable length 4.5 m; Feedthrough for measurement conductor 125 mm www.wago.com/855-9450 /2000-1251 Item no.: 855-9450/2000-1751 Rogowski coil; Primary rated current 4000 A; Output signal 22.5 mV per kA; Cable length 4.5 m; Feedthrough for measurement conductor 175 mm www.wago.com/855-9450 /2000-1751 Item no.: 855-9450/2000-701 Rogowski coil; Primary rated current 4000 A; Output signal 22.5 mV per kA; Cable length 4.5 m; Feedthrough for measurement conductor 70 mm www.wago.com/855-9450 /2000-701 Downloads Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 6/8 Data sheet | Item number: 2857-570/024-000 www.wago.com/2857-570/024-000 Downloads Documentation Manual 3-Phase Power Measurement Module V 1.0.0 pdf 16.4 MB Download 15 Jul 2019 xml 8.7 kB Download 15 Jul 2019 docx 20.3 kB Download V 1.1.0 pdf 1.2 MB Download V 1.0.0 pdf 265.8 kB Download 1.0.0 28 Feb 2019 zip 2.2 MB Download 1.0.6.18 The full setup, in addition to the WAGO Interface Configuration Software G2, includes 8 Apr 2021 the installation for the Microsoft .NET Framework. exe 113.9 MB Download WAGO Interface Configuration Software G2 SMALL exe 30.0 MB Download Bid Text 2857-570/024-000 X81 - Datei 2857-570/024-000 docx - Datei Instruction Leaflet 3-Phasen-Leistungsmessmodul Additional Information Disposal; Electrical and electronic equipment, Packaging Libraries Library Library for the Wago 3-Phase Powertransducer module 2857-570 WAGO-I/O-PRO Library for 2857-0570/0024-000x 3-Phase Powertransducer modules Engineering-Software Software for Interface-Products WAGO Interface Configuration Software G2 FULL The full setup only includes the WAGO Interface Configuration Software G2. 1.0.6.18 8 Apr 2021 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 7/8 Data sheet | Item number: 2857-570/024-000 www.wago.com/2857-570/024-000 CAD/CAE-Data CAD data 2D/3D Models 2857-570/024-000 URL Download URL Download URL Download CAE data ZUKEN Portal 2857-570/024-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 2857-570/024-000 3-Phase Power Measurement Module; 3x400/690 V/RC; Modbus RTU; Digital output; Configuration via software; Supply voltage: 24 VDC Installation Notes Configuration Configuration via WAGO Interface Configuration Software Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 8/8
2857-570/024-000 价格&库存
很抱歉,暂时无法提供与“2857-570/024-000”相匹配的价格&库存,您可以联系我们找货
    • 1+9476.616081+1227.55322
