289-102
289-102
    WAGO(万可电子)
289-102 数据手册
Data sheet | Item number: 289-102 PCB for self-assembly; with 8 mounting positions; 2,50 mm² www.wago.com/289-102 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.04.2021    Page 1/6 Data sheet | Item number: 289-102 www.wago.com/289-102 Data Electrical data Operating voltage ≤ AC/DC 250 V Nominal current 3  A Safety and protection Protection type IP00* Note on protection type *Notice! Live parts can be easily touched! Protection against direct contact must be provided by the equipment manufacturer, e.g., using a WAGO 709 Series Cover (see “Accessories”) or a similar cover. The installation guidelines must be observed for each individual application. Connection data Connection technology CAGE CLAMP® WAGO Connector WAGO 236 Series Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Strip length 5 … 6 mm / 0.2 … 0.24 inch Note (conductor cross-section) 12 AWG: THHN, THWN Physical data Width 47 mm / 1.85 inch Height from upper-edge of DIN-rail 31.5 mm / 1.24 inch Depth 65.5 mm / 2.579 inch Mechanical data Mounting type Mounting on DIN-rail via DIN-rail adapter Housing design PCB Material data Fire load 0.778 MJ Weight 22.2 g Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.04.2021    Page 2/6 Data sheet | Item number: 289-102 www.wago.com/289-102 Environmental requirements Surrounding air temperature (operation) -25 … 40 °C Commercial data Product Group 6 (Interface Electronics) Packaging type BOX Country of origin DE GTIN 4045454192754 Customs tariff number 85369010000 Compatible products Marking accessories Item no.: 210-831 Marking strips; on reel; 2.3 mm wide; plain; Self-adhesive; white www.wago.com/210-831 Item no.: 210-832 Marking strips; on reel; 3 mm wide; plain; Self-adhesive; white www.wago.com/210-832 General accessories Item no.: 288-001 Mounting carrier; gray www.wago.com/288-001 Item no.: 288-002 Universal mounting foot; snap-fit type; suitable for DIN 15, 35 and 32 rails; gray www.wago.com/288-002 Item no.: 709-153 Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent www.wago.com/709-153 Item no.: 709-167 Cover carrier; Type 1; incl. fixing/retaining screws and knurled nut; suitable for 279 to 282 and 880 Series rail-mounted terminal blocks; suitable for 264 Series miniature rail-mounted terminal blocks; suitable for 270 Series sensor and actuator terminal blocks; gray www.wago.com/709-167 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 assembling ferrule Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.04.2021    Page 3/6 Data sheet | Item number: 289-102 www.wago.com/289-102 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 tools Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.04.2021    Page 4/6 Data sheet | Item number: 289-102 www.wago.com/289-102 tools Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Downloads Documentation Bid Text 289-102 2019 Feb 19 xml 3.2 kB Download 2015 Feb 11 doc 25.1 kB Download pdf 1.3 MB Download pdf 265.8 kB Download URL Download EPLAN Data Portal 289-102 URL Download WSCAD Universe 289-102 URL Download ZUKEN Portal 289-102 URL Download URL Download X81 - Datei 289-102 doc - Datei Instruction Leaflet Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 CAD/CAE-Data CAD data 2D/3D Models 289-102 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 289-102 PCB for self-assembly; with 8 mounting positions; 2,50 mm² Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.04.2021    Page 5/6 Data sheet | Item number: 289-102 www.wago.com/289-102 PCB for self-assembly; with 8 mounting positions; 2,50 mm² Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.04.2021    Page 6/6
289-102 价格&库存
很抱歉,暂时无法提供与“289-102”相匹配的价格&库存,您可以联系我们找货
