Data sheet | Item number: 734-270
THT male header; 1.0 x 1.0 mm solder pin; angled; 100% protected against
mismating; Pin spacing 3.81 mm; 10-pole; orange
www.wago.com/734-270
Color:
L = (pole no. – 1) x pin spacing + 5.9 mm
Item description
05.09.2019 Page 1/4
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
100 % protected against mismating; only mating halves with the same number of poles can be connected together
Coding via coding fingers
Safety information 1:
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS
Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are
not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
160 V
Rated impulse voltage (III / 3)
2.5 kV
Rated voltage (III / 2)
160 V
Rated impulse voltage (III / 2)
2.5 kV
Rated voltage (II / 2)
320 V
Rated impulse voltage (II / 2)
2.5 kV
Rated current
10 A
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Total number of potentials
10
Number of connection types
1
Number of levels
1
No. of poles
10
Geometrical Data
05.09.2019 Page 2/4
Geometrical Data
Pin spacing
3.81 mm / 0.15 inch
Width
40.19 mm / 1.582 inch
Height
12.3 mm / 0.484 inch
Height from the surface
8.5 mm / 0.335 inch
Depth
10.3 mm / 0.406 inch
Solder pin length
3.8 mm
Solder pin dimensions
1 x 1 mm
Drilled hole diameter (tolerance)
1.4(- … +0.1) mm
Plug connection
Contact type (pluggable connector)
Male connector/plug
Connector connection type
for PCBs
Mismating protection
Yes
Mating direction to the PCB
0 °
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire male connector, in line
Number of solder pins per potential
1
Material Data
Color
orange
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.041 MJ
Weight
2.7 g
Environmental Requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
Country of origin
DE
GTIN
4044918872645
Customs Tariff No.
85366990990
05.09.2019 Page 3/4
Customs Tariff No.
85366990990
Compatible products
Coding
Item no.: 734-130
Coding key; to be snapped above top level; white
www.wago.com/734-130
Item no.: 734-159
Coding key; to be snapped above top level; black
www.wago.com/734-159
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
3D Download 734-270
EPLAN
EPLAN Data Portal
Download
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
05.09.2019 Page 4/4
很抱歉,暂时无法提供与“734-270”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+47.054731+6.09524
