805-104
    WAGO(万可电子)
    插件,P=3.5mm
805-104 数据手册
Printview: PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø - Item No.: 805-104 . PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø Item No.: 805-104 . PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø . Marking . Business data Supplier WAGO Item no. 805-104 GTIN / EAN 4045454731526 Content 1 Order amount 80 Customer item number . Notes Terminal strips with push-button actuated Push-in CAGE CLAMP®Push-in termination of solid and ferruled, finestranded conductorsPush-buttons that close flush with minimal force for convenient termination/removal of finestranded conductorsConvenient, tool-free operationVersions with/without test slots and spacersVersions available with custom internal commoning (factory assembly), e.g., commoning ground conductor Technical data Miscellaneous No. of poles 4 Pin Spacing 3.5 mm (0.137 in %) Total number of connection points 4 Total number of potentials 4 Color gray WAGO Kontakttechnik GmbH & Co. KG 1 Printview: PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø - Item No.: 805-104 Technical data Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 17.5 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 17.5 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 250 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 17.5 [A] Number of individual connection objects at the product 1 Connection technology (1) Push-in CAGE CLAMP® Solid sizes 1 0.2 … 1.5 mm² / 24 … 16 AWG Fine-stranded wires 1 0.2 … 1.5 mm² / 24 … 16 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 1 mm² / … Strip length 1 9 … 10 mm / 0.35 … 0.39 in Type of wiring Side-entry wiring Solder pin arrangement staggered solder pin Solder pin length [mm] 3.2 [mm] Solder pin width A [mm] 0.5 [mm] Solder pin width B [mm] 0.75 [mm] Tolerance of drilled hole [mm] 1.1(+ 0.1) [mm] Material group I Insulating material Polyamide 46 (PA 46) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) WAGO Kontakttechnik GmbH & Co. KG 2 Printview: PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø - Item No.: 805-104 Technical data Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.041 [MJ] Weight [g] 1.926 [g] Width 15.5 mm / 0.61 in Height 13.7 mm / 0.539 in Height from the surface 10.5 mm / 0.413 in Length 13.6 mm / 0.535 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø - Item No.: 805-104 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø - Item No.: 805-104 . WAGO Kontakttechnik GmbH & Co. KG 5 Printview: PCB terminal strip; 1 solder pin/pole, staggered; 4-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test port for test plug up to 2 mm Ø - Item No.: 805-104 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 6
805-104 价格&库存
很抱歉,暂时无法提供与“805-104”相匹配的价格&库存,您可以联系我们找货
    • 320+6.82887
    库存:320
    805-104
    • 1+3.372201+0.40331
    • 80+3.3206980+0.39715
    库存:1
    805-104
      • 1+10.11568
      库存:1
