PCB Terminal Blocks and Pluggable Connectors
for Power Electronics
More Power on Your PCB
MORE POWER
ON YOUR PCB
More Power no Longer Means More Space
The trend toward electronic miniaturization
requires that both power and signal levels be integrated on PCBs. This results in increased power
density, requiring connection technologies and
pluggable connectors suited for both compact
and high-performance PCB terminal blocks.
Connection technology is also a basic criterion
for selecting the right terminal block in demanding
applications, such as power supplies, frequency
inverters or servo drives. Additional decisive factors include simple and easy operation, as well as
wiring flexibility.
Every Advantage – All in One
WAGO combines all these criteria into a comprehensive and varied range of PCB terminal blocks
2
for power electronics. WAGO‘s PCB terminal
blocks are rated for 4 mm², 6 mm² and 16 mm²
conductor cross-sections and can be operated
either with or without a tool.
The WAGO MCS MAXI 16 Pluggable Connector
has a conductor size of 16 mm² (6 AWG). Integrated levers enable intuitive actuation without tools
for simple, secure in-hand wiring.
The blocks also offer a unique space-saving
feature: Beyond their nominal cross-section, the
PCB terminal blocks and pluggable connectors
connect most solid and fine-stranded conductors
up to the next larger cross-section size. This saves
space on the PCB and reduces device connection
costs.
Thanks to WAGO’s innovative spring pressure
connection technology, the WAGO PCB Terminal
Blocks for all applications ideally blend ergonomics and safety. Push-in CAGE CLAMP® enables
solid and ferruled conductors to be connected
by simply pushing them into the unit, while guaranteeing secure and maintenance-free connections
for all conductor types. Furthermore, our products
are not only simple and easy to use, but also offer
maximum wiring flexibility.
Advantages:
• Comprehensive product line
ranging from 0.2 to 25 mm²
• Push-in CAGE CLAMP® termination
• Wider conductor range and
higher current carrying capacity
• Conductor connection and mating direction
both horizontal and vertical to the PCB
• Testing both parallel and perpendicular to
conductor entry
Learn more at:
www.wago.com/powerelectronics
3
PCB TERMINAL BLOCKS WITH
Push-in CAGE CLAMP®
2624, 2626, 2636 Series
WAGO‘s PCB terminal blocks with Push-in CAGE
CLAMP® are ideal for compact device connections. They are compatible with existing industrial
solutions and can be perfectly integrated into both
space-limited and panel feedthrough applications.
Advantages:
• Compact device connection
• Ideal for panel feedthrough and spacerestricted applications
• Operation parallel to conductor entry
• Compatibility with existing industrial
solutions
• For applications complying with EN and
UL 61800-5-1 (details upon request)
Push-in CAGE CLAMP® is suitable for all conductor
types and enables solid and ferruled conductors to
be connected by simply pushing them into the unit.
Tool-actuated termination is performed parallel to
conductor entry. WAGO‘s PCB terminal blocks terminate conductors both horizontally and vertically
to the PCB. Furthermore, they can be tested both
parallel and perpendicular to conductor entry.
Conductor Ranges:
[mm2]
0.2
2626 Series
All conductor types
[AWG]
24
2624 Series
2636 Series
0.34
0.5
All conductor types
22
1.5
All conductor types
18
16
All conductor types including ferruled without restriction
4
2.5
14
“s”
4
12
6
“s” + “f-st”
10
Only solid conductors
10
16
“s” + “f-st”
8
6
25
“f-st”
4
[mm2]
Pin spacing: 5 / 7.5 / 11.5 mm
Pin spacing: 7.5 mm
Pin spacing: 10 mm
[AWG]
“f-st” Only fine-stranded conductors
Push-in CAGE CLAMP® AND LEVER
2604, 2606, 2616 Series
WAGO‘s lever-equipped PCB terminal block variants offer faster and easier wiring. They combine
a compact design, high current carrying capacity
and the advantages of Push-in CAGE CLAMP®
with the benefits of intuitive lever operation.
The lever permits 100% tool-free operation and
provides a secure connection when the easy-touse lever closes the clamping unit. The lever also
clearly locks in position (open/close) with a tactile
and audible click. WAGO‘s PCB terminal blocks
with levers terminate conductors both horizontally
and vertically to the PCB. Furthermore, they can
be tested both parallel and perpendicular to conductor entry.
Advantages:
• Faster and easier wiring
• Tool-free, intuitive lever operation
• Secure connection via easy and effortless
lever actuation into closed position
• Lever clearly locks in position (open/close)
Conductor Ranges:
[mm2]
2604 Series
2606 Series
2616 Series
[AWG]
0.2
0.34
0.5
All conductor types
All conductor types
24
22
1.5
2.5
All conductor types
18
16
14
“s”
4
“s” + “f-st”
12
6
10
16
“s” + “f-st”
10
8
6
25
“f-st”
4
[mm2]
Pin spacing: 7.5 mm
Pin spacing: 10 mm
[AWG]
5
2624 SERIES
• PCB terminal block (4 mm²)
with tool operation and
Push-in CAGE CLAMP®
• Straight or angled type
• Ideal for panel feedthrough applications via operation parallel to
conductor entry
Push-in termination of solid
conductors
Insert fine-stranded conductors and
remove all conductor types via operating tool.
PCB terminal block for panel feedthrough connections
5 mm
Ratings per
IEC/EN 60664-1
Conductor Data
Push-in CAGE CLAMP®
Nominal voltage (III / 3)
320 V
630 V
1000 V
Conductor range:
solid
0.2 … 6 mm²
Rated voltage (III / 2)
400 V
630 V
1000 V
Conductor range:
fine-stranded
0.2 … 6 mm²
630 V
1000 V
1000 V
Conductor range:
fine-stranded
0.25 … 2.5 mm²
Rated surge voltage
4 kV
6 kV
8 kV
Conductor range:
fine-stranded
0.25 … 2.5 mm²
Rated current
32 A
AWG
24 … 10
26 A
150 V
26 A
600 V
Strip length
10 … 12 mm
0.8
8.2
8.2
15.4
15.4
1
1.5
2.75
15.4
8.2
2624-3101
2624-3102
2624-3302
2624-3502
3
2624-1103
2624-1303
2624-1503
2624-3103
2624-3303
2624-3503
4
2624-1104
2624-1304
2624-1504
2624-3104
2624-3304
2624-3504
5
2624-1105
2624-1305
2624-1505
2624-3105
2624-3305
2624-3505
6
2624-1106
2624-1306
2624-1506
2624-3106
2624-3306
2624-3506
7
2624-1107
2624-1307
2624-1507
2624-3107
2624-3307
2624-3507
8
2624-1108
2624-1308
2624-1508
2624-3108
2624-3308
2624-3508
9
2624-1109
2624-1309
2624-1509
2624-3109
2624-3309
2624-3509
10
2624-1110
2624-1310
2624-1510
2624-3110
2624-3310
2624-3510
11
2624-1111
2624-1311
2624-1511
2624-3111
2624-3311
2624-3511
12
2624-1112
2624-1312
2624-1512
2624-3112
2624-3312
2624-3512
4.2
16.3
4.2
11.5
1
11.5
1.5
0.8
) 5
4.2
5
Ø 1.3
2624-1502
> 8.2
2.7
2624-1102
1
0.8
5.6 8.2
16.3 >
1.5
Pin spacing Pin spacing
)4
1
4
11.5 mm
Straight
4
7.5 mm
15.4
(with uninsulated ferrule)
5 mm
11.5
__>
11.5 mm
11.5
7.5 mm
Angled
(with insulated ferrule)
4.2
Conductor range:
fine-stranded
16.7
25.8
630 V
1.5
1
_____>
_____>
Nominal voltage (II / 2)
Conductor range:
fine-stranded
1
3.8
18.4
Conductor Data
很抱歉,暂时无法提供与“832-3602”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+54.982101+7.14750
- 10+46.7294510+6.07468
- 100+39.71261100+5.16251
- 500+35.45075500+4.60849
- 1000+33.760271000+4.38873
