862-504
862-504
    WAGO(万可电子)
    接线端子 每排针脚数:4 排数:单排
862-504 数据手册
Data sheet  |  Item number: 862-504 4-conductor chassis-mount terminal strip; 4-pole; without ground contact; for 3 mm ø screw and nut; 4 mm²; 4,00 mm²; black www.wago.com/862-504 Dimensions (in mm) for chassis-mount terminal strips Color: Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 500 V Rated impulse voltage (III / 3) 6 kV Rated current 32 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology Push-in CAGE CLAMP® Actuation type Operating tool Push-button Connectable conductor materials Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Copper Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/8 Data sheet  |  Item number: 862-504 www.wago.com/862-504 Connectable conductor materials Copper Solid conductor 0.5 … 4 mm² / 20 … 12 AWG Solid conductor, push-in termination 0.75 … 4 mm² / 18 … 12 AWG Stranded conductor 0.5 … 4 mm² / 20 … 12 AWG Fine-stranded conductor 0.5 … 4 mm² / 20 … 12 AWG Fine-stranded conductor with ferrule with plastic collar 0.5 … 2.5 mm² / 20 … 12 AWG Fine-stranded conductor with ferrule, push-in termination, from 0.75 mm² / 18 AWG Strip length 10 … 11 mm / 0.39 … 0.43 inch No. of poles 4 Total number of connection points 16 Total number of potentials 4 Type of wiring Side-entry wiring Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Geometrical Data Pin spacing 12 mm / 0.472 inch Width 48 mm / 1.89 inch Height from the surface 22.3 mm / 0.878 inch Depth 35 mm / 1.378 inch Mechanical data Mounting type Screw mounting Marking plain Material Data Color black Fire load 0.503 MJ Weight 27.3 g Commercial data Packaging type bag Country of origin DE GTIN 4045454750268 Customs Tariff No. 85369010000 Approvals / Certificates Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/8 Data sheet  |  Item number: 862-504 www.wago.com/862-504 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 60947 2146425.01 CCA DEKRA Certification B.V. EN 60947 NTR NL 6912 CSA DEKRA Certification B.V. C22.2 No. 158 1505030 ENEC 15 UL International Germany GmbH EN 60998 143856-01 Approval Additional Approval Text Certificate name DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) Ship Approvals Logo UL-Approvals Logo Approval Additional Approval Text UL UL International Germany GmbH UL 1059 Certificate name E45172 sec. 39 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/8 Data sheet  |  Item number: 862-504 www.wago.com/862-504 Compatible products Marking accessories Item no.: 709-177 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent www.wago.com/709-177 Item no.: 709-178 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white www.wago.com/709-178 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-144 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 ferrule Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 210-137 Test plug; 2.3 mm Ø; with 500 mm cable; yellow www.wago.com/210-137 check Jumper Item no.: 862-482 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/862-482 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/8 Data sheet  |  Item number: 862-504 www.wago.com/862-504 Item no.: 862-482 Comb-style jumper bar; for conductor entry; insulated; terminated conductor entry; black www.wago.com/862-482 tools Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 Downloads Documentation Bid Text 862-504 Feb 19, 2019 xml 3.8 kB Download Jun 12, 2017 doc 25.1 kB Download Apr 3, 2019 pdf 2.1 MB Download URL Download X81 - Datei 862-504 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 862-504 CAE data EPLAN Data Portal 862-504 Download WSCAD Universe 862-504 Download Installation Notes Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/8 Data sheet  |  Item number: 862-504 www.wago.com/862-504 Cost-effective features: WAGO’s 862 Series Chassis-Mount Terminal Strips were developed specifically to minimize wiring costs, while accommodating requirements for flexible mounting, multiple connection points and easy handling: Equipped with Push-in CAGE CLAMP®, the 862 Series connects up to four conductors sized 0.5 … 4 mm² (20 … 12 AWG). Due to multiple connection points per pole, different conductor sizes can be used within the same terminal block position. For factory wiring, Push-in CAGE CLAMP® Connection Technology allows solid conductors, finestranded conductors with ferrules or ultrasonically bonded conductors from 0.5 … 4 mm² (20 … 12 AWG) to be terminated by simply pushing them into unit (length of bonded conductor end: min. 10 mm). Convenient automatic grounding contact optional Snap-in mounting feet for fast assembly Push-buttons for easy installation with an operating tool or by hand Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/8 Data sheet  |  Item number: 862-504 www.wago.com/862-504 Built-in test points simplify testing with 2 mm Ø test plug. Flexible marking options with standard marking (pre-marked), marking strip or custom marked for large orders Terminating four conductors per pole – solid and fine-stranded. Inserting a conductor via push-button. Commoning using a comb-style jumper bar (862‑482). Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/8 Data sheet  |  Item number: 862-504 www.wago.com/862-504 Testing with a 2 mm Ø test plug. Dimensions in mm Marking by direct, one-side printing and/or marker strips Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 8/8
862-504 价格&库存
很抱歉,暂时无法提供与“862-504”相匹配的价格&库存,您可以联系我们找货
  • 1+40.32720
  • 10+34.07400
  • 30+30.27240
库存:18
862-504
  • 1+49.673371+6.45633
  • 10+35.2727910+4.58461
  • 25+30.9455725+4.02217
  • 50+28.2690150+3.67429
  • 100+26.06689100+3.38806
  • 250+23.79423250+3.09267
  • 500+22.47863500+2.92168
  • 1000+21.444281000+2.78724
库存:5238
862-504
    • 10+30.46985
    • 100+29.55447
    库存:430
