890-113
890-113
    WAGO(万可电子)
    P=4.4mm
    接线端子 间距:4.40mm
890-113 数据手册
Plug; with strain relief housing; 3-pole; for cable diameter 4.5 - 10 mm Item #890-113 Note: All connectors for fixed installations (snap-in versions for lighting fixtures, devices or all types of PCBs and distribution cabinets) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for “flying leads” (plug/socket). 2 Mating cycles: 100, with resistive load IN = 16 A, tested (1.5 mm /AWG 16) Item Properties Name Value Unit No. of Poles 3 Total number of connection points 3 Total number of potentials 3 Color black Coding A Pollution degree (1) 3 Rated voltage EN (1) [V] 250 V Rated surge voltage (1) [kV] 4 kV Nominal current [A] 16 A Mating cycles 200, without resistive load Connection technology (1) CAGE CLAMP® S Nominal cross section 1 1.5 mm² / 16 AWG Solid sizes 1 0.25 … 1.5 mm² / 22 … 16 AWG Fine-stranded wires 1 0.25 … 1.5 mm² / 22 … 16 AWG Fine-stranded wires with insulated ferrule 0.25 … 0.75 mm² / 22 … 20 AWG 1 Fine-stranded wires with uninsulated ferrule 1 0.25 … 1 mm² / 22 … 18 AWG stranded, connectable 1 0.25 … 1 mm² / 22 … 18 AWG Strip length 1 9 mm / 0.35 in Mating force of a plug-in connection approx. 20–70N (depending on number of poles) Retention force of a plug-in connection when locked: > 80N Insulating material Polyamide 6.6 V0, halogen-free (except cable) Clamping spring material Stainless steel Contact material Copper or copper alloy, surface-treated Processing temperature -5°C ... +40°C Fire load [MJ] 0.238 MJ Weight [g] 6.95 g Width [mm] 17.9 mm Width [in] 0.705 in Height [mm] 14 mm Altitude [in] 0.551 in Length [mm] 63.6 mm Length [in] 2.504 in
890-113 价格&库存
很抱歉,暂时无法提供与“890-113”相匹配的价格&库存,您可以联系我们找货
    • 50+24.28800
    库存:78
    890-113
