2001-410
    WAGO(万可电子)
2001-410 数据手册
Data sheet  |  Item number: 2001-410 Jumper; 10-way; insulated; light gray www.wago.com/2001-410 Color: Data Electrical data Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 800 V Rated current 18 A Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 1/5 Data sheet  |  Item number: 2001-410 www.wago.com/2001-410 Approvals Ex Rated current (Ex e II) 16 A Geometrical Data Width 40,8 mm / 1.606 inch Height 19 mm / 0.748 inch Depth 4,1 mm / 0.161 inch Material Data Color light gray Fire load 0.03 MJ Weight 3.9 g Commercial data Product Group 22 (TOPJOB S) Packaging type bag Country of origin DE GTIN 4055143699440 Customs tariff number 85366990990 Counterpart Downloads Documentation Bid Text 2001-410 Apr 27, 2017 doc 24.1 kB Download Feb 19, 2019 xml 2.6 kB Download URL Download doc - Datei 2001-410 GAEB X81 - Datei CAD/CAE-Data CAD data 2D/3D Models 2001-410 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 2/5 Data sheet  |  Item number: 2001-410 www.wago.com/2001-410 CAE data EPLAN Data Portal 2001-410 URL Download WSCAD Universe 2001-410 URL Download ZUKEN Portal 2001-410 URL Download Installation Notes Commoning The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Removing a push-in type jumper bar. Insert the operating tool between the jumper and and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. Commoning Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 3/5 Data sheet  |  Item number: 2001-410 www.wago.com/2001-410 Custom push-in type jumper bars are created by breaking off jumper contacts. Marking a push-in type jumper bar using a felt-tip pen. 500 V 300 V Commoning Stepping down via push-in type jumper bar. Stepping down via push-in type jumper bar. Stepping down via push-in type jumper bar. Commoning via closed terminal side with end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to 6 mm² (10 AWG) or from 6 mm² (10 AWG) to 2.5 mm² (14 AWG) (see illustration above). Commoning via open terminal side with end plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and 10 mm² (8 AWG) and one cross-section size for 6/4/2.5 mm² (10/12/14 AWG). An example: from 16 mm² (6 AWG) to 6 mm² (10 AWG) (see illustration above) or from 10 mm² (8 AWG) to 4 mm² (12 AWG). Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 4/5 Data sheet  |  Item number: 2001-410 www.wago.com/2001-410 Note: The total current of the outgoing circuits shall not exceed the nominal current of the step-down jumper/push-in type jumper bar. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 5/5
2001-410 价格&库存
很抱歉,暂时无法提供与“2001-410”相匹配的价格&库存,您可以联系我们找货
    • 1+1100.59679
    库存:50
    2001-410
      • 40+24.77447
      • 150+23.79510
      • 450+22.91245
      • 2000+22.01772
      • 4000+21.13508
      库存:32
