2050-1204
2050-1204
    WAGO(万可电子)
    WAGO - 2050-1204 - DIN Rail Mount Terminal Block, Miniature, 2 Ways, 24 AWG, 16 AWG, 1 mm², Clamp, 1...
2050-1204 数据手册
Data sheet | Item number: 2050-1204 2-conductor miniature through terminal block; with operating slots; 1 mm²; with test port; side and center marking; for DIN-15 rail; Push-in CAGE CLAMP®; 1,00 mm²; blue www.wago.com/2050-1204 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 1/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 500 V Rated surge voltage (III/3) 6 kV Rated current 13.5 A Rated current 2 17.5 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 300 V Rated current UL (Use Group C) 10 A Ratings per CSA Approvals per C22.2 No 158 Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group C) 300 V Rated current CSA (Use Group C) 10 A Ex information Ratings per ATEX: PTB 19 ATEX 1019 U / IECEx: PTB 19.0050U (Ex eb IIC Gb) Rated voltage EN (Ex e II) 352 V Rated current (Ex e II) 13.5 A Rated current (Ex e II) with jumper 12 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Operating tool Connectable conductor materials Copper Copper Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 2/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Copper Nominal cross-section 1 mm² Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Solid conductor; push-in termination 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.14 … 0.75 mm² / 24 … 18 AWG Fine-stranded conductor; with ferrule; push-in termination 0.5 … 0.75 mm² / 20 … 18 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 9 … 11 mm / 0.35 … 0.43 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Wiring direction Front-entry wiring Number of jumper slots 1 Physical data Width 3.5 mm / 0.138 inch Height 34.1 mm / 1.343 inch Depth from upper edge of DIN-rail 27.9 mm / 1.098 inch Mechanical data Design horizontal type Mounting type DIN-15 rail Marking level Center/side marking Material data Color blue Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.049 MJ Weight 2.4 g Commercial data Packaging type BOX Country of origin DE GTIN 4055143965132 Customs tariff number 85369010000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 3/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Customs tariff number 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 E185892 ATEX Physikalisch Technische Bundesanstalt EN IEC 60079-0 PTB 19 ATEX 1019 U (II 2G Ex eb IIC Gb or I M 2 EX eb I Mb) CCCEx CQST/CNEx CNCA-C23-01 2020312313000289 IECEx Physikalisch Technische Bundesanstalt IEC 60079 IECEx PTB 19.0050 U (Ex eb IIC Gb or EX eb I Mb) Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7839 CCA DEKRA Certification B.V. EN 60998 NTR NL 7840 CSA CSA C22.2 No. 158 80034182 KEMA/KEUR DEKRA Certification B.V. EN 60947 71113930 KEMA/KEUR DEKRA Certification B.V. EN 60998 71113957 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 4/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 UL-Approvals Logo Approval Additional Approval Text cURus Underwriters Laboratories Inc. UL 1059 Certificate name E4517220200212 Required accessories End plate Item no.: 2050-1291 End and intermediate plate; 1.1 mm thick; gray www.wago.com/2050-1291 Optional accessories Testing and measuring Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 210-137 Test plug; 2.3 mm Ø; with 500 mm cable; yellow www.wago.com/210-137 Item no.: 2000-402 Jumper; 2-way; insulated; light gray www.wago.com/2000-402 Item no.: 2000-402/000-005 Jumper; 2-way; insulated; red www.wago.com/2000-402 /000-005 Item no.: 2000-402/000-006 Jumper; 2-way; insulated; blue www.wago.com/2000-402 /000-006 Jumpers Item no.: 2000-402/000-018 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 5/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Item no.: 2000-402/000-018 Jumper; 2-way; insulated; yellow-green www.wago.com/2000-402 /000-018 Item no.: 2000-403 Jumper; 3-way; insulated; light gray www.wago.com/2000-403 Item no.: 2000-403/000-005 Jumper; 3-way; insulated; red www.wago.com/2000-403 /000-005 Item no.: 2000-403/000-006 Jumper; 3-way; insulated; blue www.wago.com/2000-403 /000-006 Item no.: 2000-404 Jumper; 4-way; insulated; light gray www.wago.com/2000-404 Item no.: 2000-404/000-005 Jumper; 4-way; insulated; red www.wago.com/2000-404 /000-005 Item no.: 2000-404/000-006 Jumper; 4-way; insulated; blue www.wago.com/2000-404 /000-006 Item no.: 2000-405 Jumper; 5-way; insulated; light gray www.wago.com/2000-405 Item no.: 2000-405/000-005 Jumper; 5-way; insulated; red www.wago.com/2000-405 /000-005 Item no.: 2000-405/000-006 Jumper; 5-way; insulated; blue www.wago.com/2000-405 /000-006 Item no.: 2000-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2000-405 /011-000 Item no.: 2000-406 Jumper; 6-way; insulated; light gray www.wago.com/2000-406 Item no.: 2000-406/000-005 Jumper; 6-way; insulated; red www.wago.com/2000-406 /000-005 Item no.: 2000-406/000-006 Jumper; 6-way; insulated; blue www.wago.com/2000-406 /000-006 Item no.: 2000-406/020-000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 6/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Item no.: 2000-406/020-000 Delta jumper; insulated; light gray www.wago.com/2000-406 /020-000 Item no.: 2000-407 Jumper; 7-way; insulated; light gray www.wago.com/2000-407 Item no.: 2000-407/000-005 Jumper; 7-way; insulated; red www.wago.com/2000-407 /000-005 Item no.: 2000-407/000-006 Jumper; 7-way; insulated; blue www.wago.com/2000-407 /000-006 Item no.: 2000-408 Jumper; 8-way; insulated; light gray www.wago.com/2000-408 Item no.: 2000-408/000-005 Jumper; 8-way; insulated; red www.wago.com/2000-408 /000-005 Item no.: 2000-408/000-006 Jumper; 8-way; insulated; blue www.wago.com/2000-408 /000-006 Item no.: 2000-409 Jumper; 9-way; insulated; light gray www.wago.com/2000-409 Item no.: 2000-409/000-005 Jumper; 9-way; insulated; red www.wago.com/2000-409 /000-005 Item no.: 2000-409/000-006 Jumper; 9-way; insulated; blue www.wago.com/2000-409 /000-006 Item no.: 2000-410 Jumper; 10-way; insulated; light gray www.wago.com/2000-410 Item no.: 2000-410/000-005 Jumper; 10-way; insulated; red www.wago.com/2000-410 /000-005 Item no.: 2000-410/000-006 Jumper; 10-way; insulated; blue www.wago.com/2000-410 /000-006 Item no.: 2000-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2000-433 Item no.: 2000-433/000-005 Jumper; from 1 to 3; insulated; red www.wago.com/2000-433 /000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 7/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Item no.: 2000-433/000-006 Jumper; from 1 to 3; insulated; blue www.wago.com/2000-433 /000-006 Item no.: 2000-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2000-434 Item no.: 2000-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2000-435 Item no.: 2000-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2000-436 Item no.: 2000-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2000-437 Item no.: 2000-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2000-438 Item no.: 2000-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2000-439 Item no.: 2000-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2000-440 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 249-101 Screwless end stop; 6 mm wide; for WMB markers; gray www.wago.com/249-101 Mounting Push-in type wire jumper Item no.: 2009-402 Push-in type wire jumper; 0.75 mm²; insulated; 60 mm long; gray www.wago.com/2009-402 Item no.: 2009-404 Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; gray www.wago.com/2009-404 Item no.: 2009-406 Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; gray www.wago.com/2009-406 Protective warning marker Item no.: 2000-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2000-115 Item no.: 210-111 Steel carrier rail; 15 x 5.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; silver-colored www.wago.com/210-111 Carrier rail Item no.: 210-295 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 8/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Item no.: 210-295 Steel carrier rail; 15 x 5.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-295 Item no.: 210-296 Aluminum carrier rail; 15 x 5.5 mm; 1 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-296 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured www.wago.com/210-647 Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Tool Marking accessories Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-113 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white www.wago.com/2009-113 Item no.: 2009-113/000-002 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; yellow www.wago.com/2009-113 /000-002 Item no.: 2009-113/000-005 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; red www.wago.com/2009-113 /000-005 Item no.: 2009-113/000-006 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; blue www.wago.com/2009-113 /000-006 Item no.: 2009-113/000-007 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; gray www.wago.com/2009-113 /000-007 Item no.: 2009-113/000-012 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; orange www.wago.com/2009-113 /000-012 Item no.: 2009-113/000-017 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; light green www.wago.com/2009-113 /000-017 Item no.: 2009-113/000-023 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; green www.wago.com/2009-113 /000-023 Item no.: 2009-113/000-024 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; violet www.wago.com/2009-113 /000-024 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 9/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; violet /000-024 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 793-3501 WMB marking card; as card; plain; snap-on type; white www.wago.com/793-3501 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Ferrule Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Downloads Documentation Additional Information Technical explanations 3 Apr 2019 pdf 2.2 MB Download URL Download ZUKEN Portal 2050-1204 URL Download EPLAN Data Portal 2050-1204 URL Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2050-1204 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 2050-1204 2-conductor miniature through terminal block; with operating slots; 1 mm²; with test port; side and center marking; for DIN-15 rail; Push-in CAGE CLAMP®; 1,00 mm²; blue Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 10/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Installation Notes Conductor termination Insert solid conductors via push-in termination. Insert ferruled conductors via push-in termination. Insert fine-stranded conductors via operating tool. Remove all conductors via operating tool. Commoning Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 11/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Insert a jumper (delta jumper) and push down until it hits the backstop (picture shows terminal blocks with push-buttons). Marking strip (2009‑110) inserted in the marking slot with jumper symbols of the inserted jumper (picture shows terminal blocks with push-buttons) Insert a jumper (star point jumper) and push down until it hits the backstop (picture shows terminal blocks with push-buttons). Marking strip (2009‑110) inserted in the marking slot with jumper symbols of the inserted jumper (2000‑405/011‑000 Delta Jumper) (picture shows terminal blocks with push-buttons) Testing Testing with a 2 mm Ø 210‑136 Test Plug (max. 42 V). Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 12/13 Data sheet | Item number: 2050-1204 www.wago.com/2050-1204 Snapping a WMB marking strip into a marker slot. Snapping a marking strip (2009‑110) into a marker slot. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 13/13
2050-1204 价格&库存
很抱歉,暂时无法提供与“2050-1204”相匹配的价格&库存,您可以联系我们找货
    • 1+26.35743
    • 25+23.39990
    • 100+21.09844
    • 500+16.79752
    • 1000+16.46428
    库存:12
    2050-1204
    • 1+32.792681+4.25589
    • 10+23.3450610+3.02977
    • 25+20.4035325+2.64801
    • 50+18.5594250+2.40868
    • 100+17.02714100+2.20982
    • 250+15.43043250+2.00259
    • 500+14.49876500+1.88168
    • 1000+13.762731000+1.78615
    • 5000+12.617245000+1.63749
    库存:8
