2061-901
2061-901
    WAGO(万可电子)
    Board-to-Board Link, Pin spacing 6 mm, 1-pole, Length 30 mm
2061-901 数据手册
Data sheet  |  Item number: 2061-901 Board-to-Board Link; Pin spacing 6 mm; 1-pole; Length: 30 mm; white www.wago.com/2061-901 Color: Item description Verbindungselement zum vereinfachten Aneinanderreihen von LED-Platinen Einfache Handhabung durch direktes Stecken und Trennen ohne Drückerbetätigung 05.09.2019    Page 1/4 Data sheet  |  Item number: 2061-901 www.wago.com/2061-901 Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 250 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 9  A Connection data Total number of potentials 1 Number of connection types 1 No. of poles 1 Geometrical Data Pin spacing 6 mm / 0.236 inch Width 5.7 mm / 0.224 inch Height 2.5 mm / 0.098 inch Depth 30 mm / 1.181 inch Mechanical data Mating cycles 10 Number of mating cycles max. 10 mating cycles Material Data Color white Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating silver-plated Weight 0.283 g Environmental Requirements 05.09.2019    Page 2/4 Data sheet  |  Item number: 2061-901 www.wago.com/2061-901 Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Country of origin CN GTIN 4055143656856 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL7459 CCA DEKRA Certification B.V. EN 60838 NTR NL7721 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71100855 KEMA/KEUR DEKRA Certification B.V. EN 60838 71106232 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download 05.09.2019    Page 3/4 Data sheet  |  Item number: 2061-901 www.wago.com/2061-901 CAD/CAE-Data CAD data 3D Download 2061-901 URL Download   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.09.2019    Page 4/4
2061-901 价格&库存
很抱歉,暂时无法提供与“2061-901”相匹配的价格&库存,您可以联系我们找货
  • 1+5.636771+0.73016
  • 10+4.7758010+0.61864
  • 100+4.05602100+0.52540
  • 500+3.62019500+0.46894
  • 1000+3.447221000+0.44654
  • 5000+3.077095000+0.39859
  • 10000+2.9302810000+0.37958
库存:10
