Printview: Female connector with gripping plate; Cable bundle function and unlocking aid; 4-pole; Pin
spacing 3.5 mm / 0.138 in - Item No.: 2091-1104/002-000
unlocking aid; 4-pole; Pin spacing 3.5 mm / 0.138 in
Female connector with gripping plate; Cable bundle function and unlocking aid; 4-pole; Pin spacing 3.5 mm / 0.138 in
Marking
Business data
Supplier
WAGO
Item no.
2091-1104/002-000
GTIN / EAN
4050821411642
Content
1
Order amount
100
Customer item number
Notes
Universal connection of all conductor types Simple, push-in termination of solid and ferruled conductorsEasy-to-use
design does not require special toolsAbility to wire while mated or unmatedTesting parallel to conductor entry – tip
contactAlso available with gripping plates Integrated locking latches prevent accidental disconnection
Technical data
Miscellaneous
No. of poles
4
Pin Spacing
3.5 mm (0.138 in %)
Total number of connection points
4
Total number of potentials
4
Color
light gray
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Pollution degree (1)
2
Rated voltage EN (1) [V]
160 [V]
Rated surge voltage (1) [kV]
2.5 [kV]
Nominal current [A]
10 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
320 [V]
Rated surge voltage (2) [kV]
2.5 [kV]
Nominal current (2) [A]
10 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
160 [V]
Rated surge voltage (3) [kV]
2.5 [kV]
Nominal current (3) [A]
10 [A]
Number of individual connection objects at the product
1
Connection technology (1)
Push-in CAGE CLAMP®
Solid sizes 1
0.2 … 1.5 mm² / 24 … 14 AWG
Fine-stranded wires 1
Fine-stranded wires with insulated ferrule 1
0.25 … 0.75 mm² / …
Fine-stranded wires with uninsulated ferrule 1
0.25 … 1.5 mm² / …
Strip length 1
8 … 9 mm / 0.31 … 0.35 in
Material group
I
Insulating material
Polyphtalamid (PPA GF)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 100 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.049 [MJ]
Weight [g]
1.9 [g]
Width
14 mm / 0.551 in
Height
31 mm / 1.22 in
Length
12.4 mm / 0.488 in
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2091-1104/002-000”相匹配的价格&库存,您可以联系我们找货
