Data sheet from 03.04.2013
Item no.:
218-108
Product description:
1-conductor PCB terminal strip 8-pole 2 solder pins/pole, in line
with locking slide Pin spacing 2.5 mm / 0.098 in
Produkt kann von Bild abweichen / product may differ
Packing unit 220 4*55 pieces
RoHS compliant
Product group
4 (Printed Circuit)
Weight
2.636 g
Color
grey
No. of connection Points
8
No. of potentials
8
pole count
8
Height
8.1 mm
Height
0.319 in
Width
21.5 mm
Width
0.846 in
Depth
13 mm
Depth
0.512 in
Pin spacing from
2.5 mm
Pin spacing from
0.098 in
Rating based on
IEC/EN 60664-1
Overvoltage category EN I
III
Pollution degree
2
Measured voltage EN
160 V
Measured shock voltage
1 von 5
2.5 kV
Current intensity EN
6A
Overvoltage category EN II
II
Pollution degree
2
2 von 5
Measured voltage EN
320 V
2.5 kV
6A
Overvoltage category EN III
III
Degree of pollution
3
Rated voltage EN
80 V
Rated surge voltage
2.5 kV
Nominal current
6A
Connection method
CAGE CLAMP®CONNECTION
Cross section [mm²]
0.08 - 0.5 mm²
Wiring method
solid
Cross section [mm²]
0.08 - 0.5 mm²
Wiring method
fine-stranded
Cross section to [mm²]
0.25 mm²
Wiring method
fine-stranded (with ferrule and plastic collar)
0.25 mm²
Wiring method
fine-stranded (with ferrule, without plastic collar)
Cross section [AWG]
28 - 20 AWG
Strip length from
5 mm
Strip length to
6 mm
Strip length from [inch]
0.2 in
Strip length up to [inch]
0.24 in
3 von 5
Conductor entry angle to the PCB (degrees)
40 °
Solder pin length [mm]
2.8 mm
Solder pin width A [mm]
0.5 mm
Solder pin width B [mm]
0.75 mm
Diameter of drilled hole [mm]
1.1 mm
Tolerance of drilled hole diameter [mm]
0.1 mm
Material group
I
Insulating material
PA 6.6
Temperature stability
-60 °C to +105 °C
Flammability category, based on UL 94
0V
Clamping spring material
Nickel-chromium spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
xxx-xxx/000-005
red
xxx-xxx/000-006
blue
xxx-xxx/000-012
orange
xxx-xxx/000-023
green
4 von 5
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
218-108
CCA
NL5749
250
6
0,08-0,5
218-108
CSA
154112-1565656
150
4
28-20
218-108
KEMA
2082146.01
250
6
0,08-0,5
218-108
UR
E45172
150
4
28-20
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
5 von 5
很抱歉,暂时无法提供与“218-108”相匹配的价格&库存,您可以联系我们找货
