221-615
221-615
    WAGO(万可电子)
    Splicing Connectors, 5-conductor connector, with operating
221-615 数据手册
Data sheet  |  Item number: 221-615 COMPACT Splicing Connectors; 5-conductor connector; with operating levers; Max.ambient operating temp. 85 °C www.wago.com/221-615 Data Electrical data Ratings per EN 60664 Rated voltage (II / 2) 450 V Rated impulse voltage (II / 2) 4 kV Rated current 41 A Legend (ratings) (II / 2) ≙ Overvoltage category II / Pollution degree 2 22.05.2018    Page 1/3 Data sheet  |  Item number: 221-615 www.wago.com/221-615 Connection data Connection technology CAGE CLAMP® Actuation type Lever Connectable conductor materials Copper Nominal cross section 6 mm² Solid conductor 0.5 … 6 mm² / 20 … 10 AWG Stranded conductor 0.5 … 6 mm² / 20 … 10 AWG Fine-stranded conductor 0.5 … 6 mm² / 20 … 10 AWG Strip length 12 … 14 mm / 0.47 … 0.55 Inch Total number of connection points 5 Total number of potentials 1 Type of wiring Side-entry wiring Geometrical Data Width 36.7 mm / 1.445 Inch Height 10.1 mm / 0.398 Inch Depth 21.1 mm / 0.831 Inch Material Data Color transparent Flammability class per UL94 V2 Weight 7.13 g Environmental Requirements Surrounding air temperature (operation) 85 °C Continuous operating temperature up to 105 °C T-Marking per EN 60998 T85 Commercial data Country of rigin DE GTIN 4055143715478 Customs Tariff No. 85369010000 22.05.2018    Page 2/3 Data sheet  |  Item number: 221-615 www.wago.com/221-615 Country specific Approvals Logo Approval Certificate name KEMA/KEUR DEKRA Certification B.V. 71-101850   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2018    Page 3/3
221-615 价格&库存
很抱歉,暂时无法提供与“221-615”相匹配的价格&库存,您可以联系我们找货
  • 1+17.996201+2.33907
  • 10+15.2962410+1.98814
  • 25+14.3333825+1.86299
  • 50+13.6487450+1.77401
  • 100+12.99599100+1.68917
  • 250+12.18190250+1.58335
  • 500+11.60037500+1.50777
  • 1000+11.046721000+1.43581
  • 2500+10.355472500+1.34596
库存:23918
