231-118/037-000
231-118/037-000
    WAGO(万可电子)
    P=5mm
    接线端子 1x18P 间距:5mm 排数:1 每排Pin数:18
231-118/037-000 数据手册
Data sheet  |  Item number: 231-118/037-000 1-conductor female plug; Locking lever; 2.5 mm²; Pin spacing 5 mm; 18pole; 2,50 mm²; gray www.wago.com/231-118_037-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 1/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 L = pole no. x pin spacing 2- to 3-pole female connectors – one latch only Item description Universal connection for all conductor types Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation Integrated test ports With coding fingers Safety information 1: The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 2/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 16 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per UL 1977 Rated voltage UL 1977 600 V Rated current UL 1977 15 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0,08 … 2,5 mm² / 28 … 12 AWG Fine-stranded conductor 0,08 … 2,5 mm² / 28 … 12 AWG Fine-stranded conductor; with insulated ferrule 0,25 … 1,5 mm² Fine-stranded conductor; with uninsulated ferrule 0,25 … 2,5 mm² Strip length 8 … 9 mm / 0.31 … 0.35 inch Pole No. 18 Total number of connection points 18 Total number of potentials 18 Number of connection types 1 Number of levels 1 Conductor entry direction to mating direction 0  ° Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 3/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Conductor entry direction to mating direction 0  ° Geometrical Data Pin spacing 5 mm / 0.197 inch Width 106,6 mm / 4.197 inch Height 14,3 mm / 0.563 inch Depth 29,6 mm / 1.165 inch Plug connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for conductor Mismating protection No Locking of plug-in connection locking lever Material Data Color gray Material group I Insulation material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load 0.485 MJ Weight 33 g Environmental Requirements Limit temperature range -60 … +85 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin DE GTIN 4044918342582 Customs tariff number 85366990990 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 4/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 CSA DEKRA Certification B.V. C22.2 1466354 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z UL-Approvals Logo Certificate name Approval Additional Approval Text UL Underwriters Laboratories Inc. UL 1059 20190731E45172 UR UL International Germany GmbH UL 1977 E45171 Counterpart Item no.231-618 1-conductor male connector; 2.5 mm²; Pin spacing 5 mm; 18-pole; 2,50 mm²; gray www.wago.com/231-618 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 5/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Item no.231-148/001-000 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 18-pole; gray www.wago.com/231-148/001-000 Item no.231-448/001-000 THT male header; 1.0 x 1.0 mm solder pin; angled; Pin spacing 5 mm; 18-pole; gray www.wago.com/231-448/001-000 Compatible products Marking accessories Item no.: 210-331/500-103 Marking strips; as a DIN A4 sheet; MARKED; 1-12 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /500-103 Item no.: 210-331/500-104 Marking strips; as a DIN A4 sheet; MARKED; 13-24 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /500-104 Item no.: 210-332/500-202 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-202 Item no.: 210-332/500-204 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length /500-204 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-332/500-205 Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-205 Item no.: 210-332/500-206 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length /500-206 182 mm; Horizontal marking; Self-adhesive; white check Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 210-137 Test plug; 2.3 mm Ø; with 500 mm cable; yellow www.wago.com/210-137 Item no.: 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/231-661 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 6/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Item no.: 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray www.wago.com/231-661 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-104 Item no.: 216-106 Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated www.wago.com/216-106 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-121 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-122 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-123 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 ferrule Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight www.wago.com/216-142 crimped; acc. to DIN 46228, Part 1/08.92 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-144 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-152 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-152 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 7/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-243 Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-263 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-301 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 8/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 231-902 Jumper; for conductor entry; gray www.wago.com/231-902 Item no.: 231-903 Jumper; for conductor entry; 3-way; insulated; gray www.wago.com/231-903 Item no.: 231-905 Jumper; for conductor entry; 5-way; insulated; gray www.wago.com/231-905 Item no.: 231-907 Jumper; for conductor entry; 7-way; insulated; gray www.wago.com/231-907 Item no.: 231-910 Jumper; for conductor entry; 10-way; insulated; gray www.wago.com/231-910 Jumper General accessories Item no.: 231-668 Lockout caps; for covering unused clamping units; gray www.wago.com/231-668 Item no.: 231-670 Insulation stop; 0.08-0.2 mm² / 0.2 mm² “s”; white www.wago.com/231-670 Item no.: 231-671 Insulation stop; 0.25 - 0.5 mm²; light gray www.wago.com/231-671 Item no.: 231-672 Insulation stop; 0.75 - 1 mm²; dark gray www.wago.com/231-672 Item no.: 209-130 Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material www.wago.com/209-130 Item no.: 209-132 Operating tool; for connecting comb-style jumper bar; 2-way; of insulating material www.wago.com/209-132 Item no.: 231-131 Push-button; loose www.wago.com/231-131 Item no.: 231-159 Operating tool; natural www.wago.com/231-159 Insulation stop tools Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 9/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Operating tool; natural Item no.: 231-231 Combination operating tool; red www.wago.com/231-231 Item no.: 231-291 Operating tool; loose; red www.wago.com/231-291 Item no.: 280-432 Operating tool; made of insulating material; 2-way www.wago.com/280-432 Item no.: 280-433 Operating tool; made of insulating material; 3-way www.wago.com/280-433 Item no.: 280-434 Operating tool; made of insulating material; 4-way www.wago.com/280-434 Item no.: 280-435 Operating tool; made of insulating material; 5-way; gray www.wago.com/280-435 Item no.: 280-436 Operating tool; made of insulating material; 6-way www.wago.com/280-436 Item no.: 280-437 Operating tool; made of insulating material; 7-way www.wago.com/280-437 Item no.: 280-438 Operating tool; made of insulating material; 8-way www.wago.com/280-438 Item no.: 280-440 Operating tool; made of insulating material; 10-way www.wago.com/280-440 Downloads CAD/CAE-Data CAD data 2D/3D Models 231-118/037-000 URL Download EPLAN Data Portal 231-118/037-000 URL Download ZUKEN Portal 231-118/037-000 URL Download CAE data Installation Notes Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 10/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Inserting a conductor via 3.5 mm screwdriver – CAGE CLAMP® actuation parallel to conductor entry. Inserting a conductor via 3.5 mm screwdriver – CAGE CLAMP® actuation perpendicular to conductor entry. Inserting a conductor into CAGE CLAMP® unit via operating lever (231-291). Inserting a conductor via operating tool. Coding Coding a female connector – removing coding finger(s). Testing Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 11/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 Testing perpendicular to conductor entry via 2 or 2.3 mm Ø test plug – female connector with CAGE CLAMP®. Installation Male connector with strain relief plate Strain relief housing shown with a male connector equipped with CAGE CLAMP® Marking Labeling via direct marking or self-adhesive strips. Product family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 12/13 Data sheet  |  Item number: 231-118/037-000 www.wago.com/231-118_037-000 MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 13/13
231-118/037-000 价格&库存
很抱歉,暂时无法提供与“231-118/037-000”相匹配的价格&库存,您可以联系我们找货
