Data sheet from 04.02.2009
Item no.:
232-116/026-000
Product description:
ANGLED FEMALE PLUG; 16 POLE; PIN SPACING 5 MM /
0.197 IN; WITH CODIG FINGERS; WITH INTEGRATED
FIXING FLANGES; CONDUCTER EXIT OPPOSIDE TO
LATCHES
Packing unit 25 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
5 mm
Pin spacing from
0,197 in
pole count
16
Cross section from [mm²]
0,08 mm²
Cross section to [mm²]
2,5 mm²
Cross section from [AWG]
28 AWG
Cross section to [AWG]
12 AWG
Connection method
CAGE CLAMP®CONNECTION
Measured voltage EN
250 V
Measured shock voltage
4 kV
Pollution degree
3
Current intensity EN
14 A
Weight
29,816 g
Color
grey
No. of connection Points
16
No. of potentials
16
Height
23,9 mm
Height
0,941 in
Width
82,4 mm
Width
3,244 in
Depth
22,75 mm
1 von 3
Depth
0,896 in
Strip length from
8 mm
Strip length to
9 mm
Strip length
0,33 in
2 von 3
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
232-116/026-000
BV
11915/A0
400
16
2,5
232-116/026-000
CCA
5764
250
12
0,08-2,5
232-116/026-000
CSA
154112-1466354
300
15
22-12
232-116/026-000
DEMKO
88126
250
232-116/026-000
KEMA
2083746.02
250
12
0,08-2,5
232-116/026-000
KR
HMB05880-EL003
250/400
12/16
2,5
232-116/026-000
NEMKO
P94101840
250
232-116/026-000
UR
E45171
600
15
12
232-116/026-000
UR
E45172
300
15
22-12
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
2,5
2,5
很抱歉,暂时无法提供与“232-116/026-000”相匹配的价格&库存,您可以联系我们找货
