Data sheet from 29.11.2010
Item no.:
243-208
Product description:
Micro push-wire connector for junction boxes 8-conductor
terminal block
Produkt kann von Bild abweichen / product may differ
Packing unit 500 10*50 pieces
Product group
7 (Push Wire Conn.)
pole count
8
Connection method
PUSH WIRE®
Cross section [AWG]
22 - 20 AWG
Diameter from
0.6 mm
Diameter to
0.8 mm
Measured voltage EN
100 V
Measured shock voltage
1.5 kV
Pollution degree
2
Current intensity EN
6A
Weight
1.44 g
Color
dark grey
Wiring type
Side-entry
No. of connection Points
8
No. of potentials
1
Height
6.8 mm
Height
0.268 in
Width
18.4 mm
Width
0.725 in
Depth
10 mm
1 von 3
Depth
0.394 in
Strip length from
5 mm
Strip length to
6 mm
Strip length
0.22 in
2 von 3
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
243-208
ABS
04-HG476172/1-PDA
100
6
0,5-0,75
243-208
ABS
10-HN17750340X
100
6
4x0,5-1,0
243-208
CSA
18677-31
150
7
22-20
243-208
DEMKO
105047
100
6
4x0,5-1,0
243-208
KEMA
123448.01
100
6
05-1,0 sol
243-208
LR
04/20013(E3)
100
6
0,5-0,75
243-208
RMR
11130002
100
6
0,5-0,75
243-208
SEMKO
9144043
100
6
0,33-0,52/4x0,82
243-208
UR
E45172
150/150
7
22-18
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
很抱歉,暂时无法提供与“243-208”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.986191+0.77593
