Data sheet | Item number: 260-301
2-conductor terminal block; with fixing flange; for screw or similar mounting
types; Fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail
www.wago.com/260-301
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
400 V
Rated impulse voltage (III / 3)
6 kV
Rated current
18 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Aluminum
Solid conductor
0.08 … 1.5 mm² / 28 … 16 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 Inch
Total number of connection points
2
Total number of potentials
1
Number of levels
1
Type of wiring
Side-entry wiring
03.09.2018 Page 1/2
Geometrical Data
Width
5 mm / 0.197 inch
Height from the surface
17 mm / 0.669 inch
Depth
25 mm / 0.984 inch
Mechanical data
Design
horizontal
Mounting type
Mounting flange
Marking level
Side marking
Material Data
Color
gray
Fire load
0.032 MJ
Weight
1.63 g
Commercial data
Country of Origin
CH
GTIN
4044918593359
Product Group
9 (Std. Chassis Mt. Blocks)
Subject to changes.
WAGO Corporation
Germantown, WI 53022
32423 Minden
Phone: +49571 887-0 | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at {0}.
03.09.2018 Page 2/2
很抱歉,暂时无法提供与“260-301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.22720
- 10+4.12560
- 50+3.57480
- 100+3.03480
- 500+2.71080
- 国内价格 香港价格
- 1+15.849881+2.05703
