Printview: PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 4-pole; Push-in CAGE CLAMP®
- Item No.: 2604-1104
PCB terminal block; operating lever; 4 mm²; Pin spacing 5 mm; 4pole; Push-in CAGE CLAMP®
Item No.: 2604-1104
Marking
Business data
Supplier
WAGO
Item no.
2604-1104
GTIN / EAN
4055143564311
Content
1
Order amount
100
Customer item number
Notes
Item description:PCB terminal blocks with lever-actuated Push-in CAGE CLAMP® connectionPush-in termination of
solid and ferruled conductorsIntuitive and tool-free operationSeveral clamping units can be held open simultaneously
– convenient for terminating multi-core cablesTesting can be performed both parallel and perpendicular to conductor
entry
Technical data
Miscellaneous
Available upon request (depending on quantity required): Other pole numbers
Packaging type
BOX
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Ratings per
IEC/EN 60664-1
Rated voltage (III / 3) [V]
320 [V]
Rated impulse voltage (III / 3) [kV]
4 [kV]
Rated voltage (III/2) [V]
400 [V]
Rated impulse voltage (III / 2) [kV]
4 [kV]
Rated voltage (II / 2) [V]
630 [V]
Rated impulse voltage (II / 2) [kV]
4 [kV]
Rated current [A]
32 [A]
Legend (ratings)
(III / 2) Overvoltage category III / Pollution degree 2
No. of poles
4
Total number of connection points
4
Total number of potentials
4
Number of connection types
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating lever
Solid conductor
0.2 … 4 mm² / 24 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 2.5 mm²
Fine-stranded conductor with ferrule without plastic collar 0.25 … 2.5 mm² / …
Strip length
9 … 11 mm / 0.35 … 0.43 Inch
Pin spacing
5 mm (0.197 in)
Width
22.4 mm / 0.882 Inch
Height
20.7 mm / 0.815 Inch
Height from the surface
16.7 mm / 0.657 Inch
Depth
19.2 mm / 0.756 Inch
Solder pin length [mm]
4 [mm]
Solder pin dimensions
0.8 x 1 mm
Drilled hole diameter (tolerance) [mm]
1.3(+ 0.1) [mm]
PCB contact
THT
Solder pin arrangement
over the entire terminal strip, in line
Number of solder pins per potential
2
Color
gray
Material group
I
2
Technical data
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.085 [MJ]
Actuating element color
orange
Weight [g]
6.268 [g]
Limit temperature range
-60 … 105 °C
Pin spacing from [mm]
5 [mm]
Main product function
PCB terminal block
Product type
PCB terminal blocks
3
Images & drawings
4
5
6
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
7
很抱歉,暂时无法提供与“2604-1104”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+85.294811+11.08805
- 10+53.0381810+6.89479
- 25+52.5106125+6.82621
- 50+41.7303450+5.42481
- 100+31.14263100+4.04844
- 250+30.82616250+4.00730
- 500+30.13145500+3.91699
- 1000+28.984881000+3.76794
