4-CONDUCTOR MINIATURE
THROUGH TERMINAL BLOCK
CENTRE MARKING for DIN 35 rail
264-731
PDF Datasheet
© 1992 - 2011 CADENAS GmbH
264-731
PDF Datasheet
ITEM-NO. (ITEM-NO.)
264-731
Cross section1 (Cross section / mm²)
0.08 - 2.5
Cross section2 (Cross section / AWG)
28 - 12
Strip length (Strip length / mm)
8-9
Measured voltage (Measured voltage / V)
800
Measured shock voltage (Measured shock voltage / kV)
8
Pollution degree (Pollution degree)
3
Current intensity (Current intensity / A)
24
Height (Height / mm)
24.5
Width (Width / mm)
10
Depth (Depth / mm)
38
No. of connection Points (No. of connection Points)
4
No. of potentials (No. of potentials)
1
COLOR (COLOR)
grau
WEIGHT (WEIGHT / g)
6.17
Comment (Comment)
很抱歉,暂时无法提供与“264-731”相匹配的价格&库存,您可以联系我们找货
