2706-103
2706-103
    WAGO(万可电子)
    插件,P=7.5mm
    接线端子 间距:7.50mm 每排针脚数:3 排数:单排
2706-103 数据手册
Printview: Terminal strips with operating levers; 2 solder pins/pole; 3-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot - Item No.: 2706-103 . Terminal strips with operating levers; 2 solder pins/pole; 3-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot Item No.: 2706-103 . Terminal strips with operating levers; 2 solder pins/pole; 3-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot . Marking . Business data Supplier WAGO Item no. 2706-103 GTIN / EAN 4050821092995 Content 1 Order amount 55 Customer item number . Notes High-current terminal strips with lever-actuated CAGE CLAMP®Tool-free opening and closing – fingers open/close leversSeveral clamping units can be held open simultaneously – convenient for terminating multi-core cablesTwo solder pins per contact point for high mechanical stability600V UL for 12.5mm pin spacing Technical data Miscellaneous No. of poles 3 Pin Spacing 7.5 mm (0.295 in %) Total number of connection points 3 Total number of potentials 3 Color gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Terminal strips with operating levers; 2 solder pins/pole; 3-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot - Item No.: 2706-103 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 630 [V] Rated surge voltage (1) [kV] 6 [kV] Nominal current [A] 41 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 1000 [V] Rated surge voltage (2) [kV] 6 [kV] Nominal current (2) [A] 41 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 500 [V] Rated surge voltage (3) [kV] 6 [kV] Nominal current (3) [A] 41 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.5 … 6 mm² / 20 … 10 AWG Fine-stranded wires 1 0.5 … 6 mm² / 20 … 10 AWG Fine-stranded wires with insulated ferrule 1 0.5 … 6 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.5 … 6 mm² / … Strip length 1 11 … 12 mm / 0.43 … 0.47 in Conductor entry angle to the PCB 1 [°] 30 [°] Solder pin arrangement in-line solder pin Solder pin length [mm] 4.5 [mm] Solder pin width A [mm] 1 [mm] Solder pin width B [mm] 1.4 [mm] Tolerance of drilled hole [mm] 1.8(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Terminal strips with operating levers; 2 solder pins/pole; 3-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot - Item No.: 2706-103 Technical data Fire load [MJ] 0.285 [MJ] Weight [g] 15.419 [g] Width 22.5 mm / 0.886 in Height 30 mm / 1.181 in Height from the surface 25.5 mm / 1.004 in Length 26 mm / 1.024 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Terminal strips with operating levers; 2 solder pins/pole; 3-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot - Item No.: 2706-103 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Terminal strips with operating levers; 2 solder pins/pole; 3-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot - Item No.: 2706-103 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
2706-103 价格&库存
很抱歉,暂时无法提供与“2706-103”相匹配的价格&库存,您可以联系我们找货
  • 1+83.735481+10.85372
  • 10+59.4089210+7.70053
  • 25+52.4314625+6.79612
  • 50+48.1864950+6.24589
  • 100+44.73571100+5.79860
  • 250+41.21078250+5.34170
  • 500+39.18755500+5.07946
  • 1000+37.605791000+4.87443
库存:237
