Data sheet | Item number: 2787-2144
Power supply; Pro 2; 1-phase; 24 VDC output voltage; 5 A output current;
TopBoost + PowerBoost; communication capability
www.wago.com/2787-2144
Item description
Features:
Power supply with TopBoost, PowerBoost and configurable overload behavior
Configurable digital signal input and output, optical status indication, function keys
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at {0}.
23.03.2020 Page 1/8
Communication interface for configuration and monitoring
Optional connection to IO-Link
Suitable for both parallel and series operation
Natural convection cooling when horizontally mounted
Pluggable connection technology
Electrically isolated output voltage (SELV/PELV) per EN 61010/UL 61010
Marker slot for WAGO Marker Cards (WMB) and WAGO Marking Strips
Data
Technical Data
Input
Phases
1
Nominal input voltage Ui nom
AC 100 … 240 V
Input voltage range
AC 90 … 264 V; DC 130 … 373 V
Nominal mains frequency range
47 … 63 Hz; 0 Hz
Input current Ii
≤ 1 A (240 VAC; Nominal load); ≤ 1,8 A (100 VAC; Nominal load)
Inrush current
≤ 9 A (after 1 ms)
Power factor correction (PFC)
Active
Mains failure hold-up time
≥ 20 ms (230 VAC)
Output
Nominal output voltage Uo nom
DC 24 V (SELV)
Output voltage range
DC 24 … 28 V (adjustable)
Factory preset
DC 24 V
Nominal output current Io nom
5 A (24 VDC)
Nominal output power
120 W
Adjustment accuracy
≤ 1 %
Residual ripple
≤ 70 mV (peak-to-peak)
Current limitation
1.1 x Io nom (typ.)
Overload behavior
TopBoost/PowerBoost/Time-limited constant current mode (other
overload behaviors can be set)
PowerBoost
DC 7,5 A (5 s)
Signaling
and communication
Hansastr. 27
32423 Minden
23.03.2020 Page 2/8
Signaling and communication
Signaling
Optical status indication (DC OK; load; warning and error states)
Digital signal input and output (DI/DO)
Communication
Communication interface, can be used with WAGO USB
Communication Cable (750-923) or WAGO IO-Link Communication
Module (2789-9080)
Efficiency/Power losses:
Power loss Pl
≤ 1 W (stand-by); ≤ 2 W (no load); ≤ 10 W (230 VAC; nominal load)
Efficiency (typ.)
93,8 % (230 VAC; 5 ADC; 25 °C)
Fuse protection:
Internal fuse
T 6.3 A / 250 VAC
External fuse (required)
An external DC fuse is required for the DC input voltage.
External fuse (recommended)
16 A (for USA/Canada: 15 A)
Safety and protection:
Insulation voltage (SEC-GND)
DC 0,5 kV
Insulation voltage (SEC-Signal)
DC 0,5 kV
Protection class
I
Protection class
IP20 (per EN 60529)
Feedback voltage
≤ DC 35 V
Overvoltage category
III (≤ 2000 m a. s.l.); II (> 2000 m a. s.l.)
Transient protection, primary
Yes
Overvoltage protection, secondary
Internal protective circuit
≤ 35 VDC (in the event of a fault)
Short circuit protection
Yes
No-load proof
Yes
Parallel operation
Yes
Series connection
Yes
MTBF
> 1,000,000 h (per IEC 61709)
Connection data
Connection type (1)
Input/Output/Signaling
Connection technology
CAGE CLAMP®
WAGO terminal
WAGO 721 Series
Solid conductor
0,08 … 2,5 mm² / 28 … 12 AWG
Hansastr. 27
32423 Minden
23.03.2020 Page 3/8
Solid conductor
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0,25 … 1,5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar
0,25 … 2,5 mm² / 20 … 14 AWG
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Geometrical Data
Width
35 mm / 1.378 inch
Height
130 mm / 5.118 inch
Length from upper-edge of DIN-35 rail
130 mm / 5.118 inch
Note on dimensions
Height without connector
Height with connector: 166 mm
Mechanical data
Type of mounting
DIN-35 rail (EN 60715)
Material Data
Weight
650 g
Environmental Requirements
Surrounding air (operating) temperature
-25 … 70 °C (Device starts at −40 °C (type-tested))
Surrounding air (storage) temperature
-40 … 85 °C
Relative humidity
5 … 96 % (no condensation permissible)
Derating
See instruction leaflet
Pollution degree
2
Climatic category
3K3 (per EN 60721)
Max. operating altitude
5000 m
Standards and specifications
Conformity marking
CE
Standards/specifications
EN 61010-1; EN 61010-2-201; EN 61204-3; UL 61010-1; UL 610102-201
Commercial data
Packaging type
BOX
Country of origin
CN
GTIN
4055143907415
Hansastr. 27
32423 Minden
23.03.2020 Page 4/8
GTIN
4055143907415
Customs Tariff No.
85044082900
Approvals / Certificates
UL-Approvals
Logo
Approval
Additional Approval Text
Certificate
name
UL
Underwriters Laboratories Inc.
UL 61010-2-201
E255817
Counterpart
Compatible products
General accessories
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
/000-024
Item no.: 2789-9080
Communication module; IO-Link; communication capability
www.wago.com/2789-9080
Item no.: 750-923
Configuration cable; USB connector; Length: 2.5 m; black
www.wago.com/750-923
Marking accessories
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
/000-006
Item no.: 2009-115/000-007
Hansastr. 27
32423 Minden
23.03.2020 Page 5/8
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft
www.wago.com/210-721
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
tools
ferrule
Item no.: 216-243
Hansastr. 27
32423 Minden
23.03.2020 Page 6/8
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Item no.: 750-923/000-001
Configuration cable; USB connector; Length: 5 m
/000-001
Downloads
Documentation
Instruction Leaflet
WAGO Pro 2 Power Supplies
1-phase; 24 VDC / 5 A
V 1.0.0
Oct 16, 2019
pdf
4.4 MB
Download
V 1.0.0
pdf
265.8 kB
Download
Additional Information
Disposal; Electrical and electronic equipment, Packaging
Engineering-Software
Hansastr. 27
32423 Minden
23.03.2020 Page 7/8
Software for Interface-Products
WAGO Interface Configuration Software G2 FULL
1.0.1.29
The full setup, in addition to the WAGO Interface Configuration Software G2, includes Aug 26, 2019
the installation for the Microsoft .NET Framework.
exe
97.4 MB
Download
WAGO Interface Configuration Software G2 SMALL
exe
13.4 MB
Download
The full setup only includes the WAGO Interface Configuration Software G2.
1.0.1.29
Aug 26, 2019
Installation Notes
Product family
Pro 2
Show all products from the family
Hansastr. 27
32423 Minden
23.03.2020 Page 8/8
很抱歉,暂时无法提供与“2787-2144”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2118.739061+275.33555
- 10+1862.1765010+241.99459
- 25+1768.9443125+229.87883
- 50+1701.5357850+221.11892
